WARNING: If you do not want stains on the inside of the sash, then do not do this.
Materials:
1 bottle of Gorilla Glue Super Glue
At least one merit badge
A BSA merit badge sash
Remove these ads by
Signing UpStep 1Put Glue On
My daughter was in the Brownies. Her badges were actually iron on badges. I would usually iron them on when in a hurry. I am a big procrastinator. I then would run the sewing machine around later when I had more time.
Stitch witch is a brand name of iron on tape. It is a webbed version of hot glue. You cut the size you want and put it between the two fabrics. You then iron it with a dry iron. For badges I would recommend two layers of the stitch witch.
I do feel however that you should bear a couple of things in mind.
Super Glues the world over are generally a cyanoacrylate formula & not exactly famous for being flexible, with this in mind I would be reluctant to use it to fix fabrics which by their very nature are very flexible as however strong the glue may be it will invariably tear off of a fabric.
You really need a flexible glue that has a some streching properties.
More importantly you should be aware that cyanoacrylate glues can have an exothermic reaction with cotton or wool which can cause burns & in extreme cases start a fire.
http://en.wikipedia.org/wiki/Cyanoacrylate#Reaction_with_cotton
I found this out to my cost trying to make a quick fix a few years ago.
It may be a good idea to add a line or two about this in your ible to let people know to check what the fabrics they intend to glue are made of.
I know the super glue is not flexible. The Electronics badge (the one with the hand holding the lightning bolts) came off but that was after a rough week at Scout Camp. But other than that, they stay on for about 6 months or more and when they do start peeling off, just glue them back on.
