Use Spells to Control Your Computer!
 by technick29
Featured
Step 1: Download Voice Activiation Command Software
I simply googled the term, and Voice Activated Commands came up as the first choice. This program serves a useful purpose in RPGs and other computer games where voice commands can be given rather than typing in key combos. For this project, it can be used to cast "spells" on your computer to manipulate it to do your bidding.
VAC Download Page
It's currently only available for Windows XP and Vista.
Step 2: Grab Some Spells And Plug 'em in!
For researching all of those tip-of-the-tongue-can't-quite-remember spells, the coolest place I found was MuggleNet. It's the cream of the crop as Harry Potter fan sites go. Their spells section is extensive and gives a description of each spell.
Some sample spells:
Lumos
  • Brighten Screen
Nox
  • Dim Screen
Petrificus Totalus
  • Hibernate
Silencio
  • Mute
Sonorous
  • Volume Up
Stupefy
  • Stop In Web Browser
Evanesco
  • Exit application
Also, I made an action called "Marauder's Map" which is activated by saying "I solemnly swear I am up to no good." which opens the browser to the home page.
Step 3: Enter the Incantations
Boot up VACBuilder and create a new profile. Name it whatever you like: I did Harry Potter as an example.
Next, you want to start making spells. You go into the "Action Description" box and hit the "Add" button. Enter the spell name and click "OK".
After this, go over to the "Command List" box. This is where you will program what will happen when a certain phrase is said. Qualifier keys can be anything from "Alt" to "Shift", so just explore both lists. The extended keys reach almost anything, including browser commands and media player commands.
If you want to make sure you have the right key, boot up the Keyboard Tester program that came with VAC. Click the button in the top left to change it from "Disabled" to "Enabled". When enabled, your keyboard will light up buttons when you push them.
You can do multiple things with one voice command.. Just add another command and repeat the last step.
The "Command Attributes" can be used for more personal commands, dealing with the duration the combo is held, the pause before it is executed, and the number of times to repeat the combo.
"Profile Activation Keys" deal with activating and deactivating the voice commands by using key combos. I didn't bother with these in my project, but you certainly can if the mood strikes you.
Finally, you want to test your phrase to make sure the computer can recognize the voice commands. To do this, simply hit the "Test Phrase" button in the bottom right corner. If it matches your voice command with the correct spell, you're golden. If it doesn't just try again or pick a different phrase to say.
And of course, save your profile with the button in the bottom right before you close.
Step 4: Categories
If you are going to be using this program for more than one project, you may want to make categories for the different commands. To do this, go into "Tools" and "Category Setup". Hit "Add", make one, and hit "Okay." To add spells to a category, right click them in the "Action Description" box, go into "Category", and click the one you made for it.
Step 5: Boot Up The VAC System
Boot up the VAC system and a little icon with a microphone will pop up.
From the manual:
When the icon is just the microphone:
  • VAC is running and ready.
When there is a blue "P":
  • VAC is running and has a profile loaded.
And when there is a green circle and a blue "P"
  • Vac is running, has a profile loaded and the recognition is active.
To load a profile, right click the icon, go to the top and hit "Load Profile". Then, right click it again and hit "VAC On". Now you're set and ready to go!
I'll get a demonstration video up sometime soon!
My backup file is attached which contains all of the spells I have made thus far. To use them, go into VAC builder and hit "File", "Import", and "Text File (txt)".
Step 6: Your Spells!
Here's what you suggested!
Paladyn
I don't know what he uses, but I'd suggest:Imperio - Task ManagerAvada Kedavra - Shut downOblivio - RestartAlso, he has Volume up and mute, but not volume down. I'd suggest Quietus for that.
Dark_Helmet
Quietus - Reduces VolumeReducto - Closes current windowI solemnly swear that I'm up to no good - Open web browserMischief Managed - Also closes current windowLegilimens - Opens the Task ManagerImperio - Opens the Command Prompt
benthekahn suggests his own reverse psychology spells...
You should make everything a normal but different command. ie...Startup=shutdownmute=full volumeprevious song=next song
Step 7: Additional Software
Here are some other programs you can also use to have some of the same effects on your computers using speech recognition.
"'Windows"'
  • RedGuff suggests using Shoot, a similar voice recognition program.
Mac OS X
  • Munkey suggests using the default speech recognition software
"speech recognition is built into the Mac OS X system, so you can replicate this exactly without any extra software:
http://www.apple.com/macosx/features/speech/"
"'Linux"'
  • Linux.com has agreat article detailing how to install and use Perlbox, a voice command program for Linux.
  • CVoiceControl is another program similar to VAC, although the author is no longer supporting the program anymore.
1-40 of 208Next »
rjordan-1 says: Mar 14, 2011. 8:51 PM
what about win 7
JujubeanO in reply to rjordan-1Apr 27, 2011. 12:19 AM
7 is vista... they are pretty much one in the same
PCfreak in reply to JujubeanOOct 5, 2012. 4:58 AM
No, win 7 is a glorified version of vista
ALogan97 says: Aug 30, 2011. 5:34 PM
I used evanesco to minimize the browser instead, since Reducio wouldn't pick up.
ginger20037 says: Jul 7, 2011. 10:56 PM
HAHAHAHAHAHA! That's so funny xD I have to try it xD
valariebutternutcake says: Feb 23, 2011. 3:32 PM
you should put a list of reccommended spells :)
valariebutternutcake in reply to valariebutternutcakeFeb 23, 2011. 4:03 PM
never mind srry i didnt look through it :)
valariebutternutcake says: Feb 23, 2011. 4:01 PM
or you could go on wikipedia
http://en.wikipedia.org/wiki/List_of_spells_in_Harry_Potter
mguyear says: Feb 22, 2011. 7:51 AM
The download link in the instructable is linking to an old page. The correct download page is http://www.dwvac.com/download.html and the newest download file is http://www.dwvac.com/VAC_Full_2.5.0.zip
The link in the article is http://www.dwvac.com/download.htm when it should be http://www.dwvac.com/download.html . So when you go to the old page, it is linking to an old install file which is no longer being served on the server.
thepelton says: Feb 14, 2011. 9:37 AM
I should think that "Avera Kedavera" would probably cause a system crash. Wouldn't it?
thepelton says: Dec 27, 2010. 3:24 PM
What if you used "Stupefy" ?
hedzup456 in reply to thepeltonFeb 13, 2011. 5:18 AM
Stand by
avadra kedavra shut down
Ninja1507 says: Jan 15, 2011. 10:16 PM
For those of you disappointed for it not having certain functions. Just write a simple c++ app that does the command you desire. Then have VAC execute the app.
C++ is easy to learn for beginners so if you don't have coding experience don't be scared off by this option. Simple programs such as one to do a basic command could be learned in a matter of hours. Just make sure you start off with the classic "Hello World" :D and you'll be fine.
chandeepa says: Jan 6, 2011. 3:20 AM
this software cannot be downloaded
Darkheart069 in reply to chandeepaJan 15, 2011. 6:12 PM
google the Softwear there is more than one site if you ..... ya know loook-...
and there is more than one SW that will do this- iits beening used by lots of people i know on steam- so it works and -- its also on sevral sites.- i will NOT link here but google the file name and -- easy..
taywill95 says: Dec 5, 2010. 12:32 PM
The VAC builder won't open. It says "Component 'MSINET.Ocx' or one of its dependencies not correctly registered: a file is missing or invalid" I've run the repair on the installer several times and i still get this message.
johndenzell123 says: Sep 18, 2010. 12:52 AM
when i start the test, there's an error that said: SAPI falied to initialize. This application may not run correctly. What should I do?
Hwolfw in reply to johndenzell123Oct 17, 2010. 1:00 PM
Go to home then back to downloads
johndenzell123 in reply to HwolfwOct 18, 2010. 4:46 AM
thanks
pgd5000 says: Aug 20, 2010. 6:29 PM
I went to the download page and neither link is working, Help please? :)
kroq-gar78 says: Aug 3, 2010. 4:33 PM
wingaurdium leviosa - computer fans spin out of control
PyroMonger says: Sep 12, 2009. 5:52 AM
Can someone help me?....I've setup all my commands and saved the profile but when i right click the icon in the task tray it does not show my profile to be loaded...
vanman229 in reply to PyroMongerAug 2, 2010. 9:24 PM
how did you solve this problem, i seem to be having the same one
PyroMonger in reply to vanman229Aug 3, 2010. 3:25 AM
I cant remember...I havent used the program in a little while now...I will have a little play around with it and see if I remember then reply to you
PyroMonger in reply to PyroMongerSep 12, 2009. 5:59 AM
Nevermind...I've sussed it out
Amit Tulshyan says: Jul 15, 2010. 4:56 AM
will u please tell me which qualifier key or extended key is for shutdown,restart,standby,hibernate and comman commands. i can't find em. thanks in advance
piggleliggle says: May 27, 2010. 4:51 AM
 I'm kinda confused. How do you make your command actually do make your computer do something (i.e. dim the screen) ?
Blubber300 says: May 20, 2010. 3:15 PM
colloportus - sleep mode
aelita619 says: Apr 30, 2010. 6:42 PM
expecto patronum runs an anti-virus scan
aelita619 says: Apr 30, 2010. 6:40 PM
wadiwasi sends an e-mail
simrit3 says: Mar 12, 2010. 4:34 PM
Can someone help me on step 3? I cant find out what to do with the Commad List section... :(
fearme36 says: Dec 15, 2009. 8:37 PM
This instructable+ the instructable on how to make wands= A wand microphone that uses spells to do stuff!
lucek says: Nov 25, 2009. 11:00 PM
just tried this out on Cabal online. let me just put it this way be damn shore that it can recognize the word "Heal" befor you star playing.
lucek says: Nov 25, 2009. 9:24 PM
I got a program from a box of frosted flakes that can do this. still cool. actually cooler that talking tony a free program they toss into a cereal box can do this.
1spartan95 says: Oct 19, 2009. 2:47 PM
protego= opens anti-virus
morsmordre= open internet explorer  XD
Louxy says: Nov 3, 2007. 10:14 AM
where can i find a crack or serial for VAC 2.1.4? :) thx
zupperzipper in reply to LouxyApr 4, 2009. 7:55 AM
I need it too :( PLS help
PyroMonger in reply to zupperzipperSep 12, 2009. 6:14 AM
VAC 2.2.6 is out now and u dont need cracks...the program is free anyway
mutant in reply to LouxyJun 17, 2008. 9:24 PM
We're probably not supposed to talk about it on the forums.. but for all who want to crack it, Crackteam.ws is your best bet.
ReCreate in reply to mutantFeb 18, 2009. 5:45 PM
no its ok we can talk about everything,from warez to bugs
1-40 of 208Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
