Step 3Enter the Incantations
Next, you want to start making spells. You go into the "Action Description" box and hit the "Add" button. Enter the spell name and click "OK".
After this, go over to the "Command List" box. This is where you will program what will happen when a certain phrase is said. Qualifier keys can be anything from "Alt" to "Shift", so just explore both lists. The extended keys reach almost anything, including browser commands and media player commands.
If you want to make sure you have the right key, boot up the Keyboard Tester program that came with VAC. Click the button in the top left to change it from "Disabled" to "Enabled". When enabled, your keyboard will light up buttons when you push them.
You can do multiple things with one voice command.. Just add another command and repeat the last step.
The "Command Attributes" can be used for more personal commands, dealing with the duration the combo is held, the pause before it is executed, and the number of times to repeat the combo.
"Profile Activation Keys" deal with activating and deactivating the voice commands by using key combos. I didn't bother with these in my project, but you certainly can if the mood strikes you.
Finally, you want to test your phrase to make sure the computer can recognize the voice commands. To do this, simply hit the "Test Phrase" button in the bottom right corner. If it matches your voice command with the correct spell, you're golden. If it doesn't just try again or pick a different phrase to say.
And of course, save your profile with the button in the bottom right before you close.
C++ is easy to learn for beginners so if you don't have coding experience don't be scared off by this option. Simple programs such as one to do a basic command could be learned in a matter of hours. Just make sure you start off with the classic "Hello World" :D and you'll be fine.
http://clans.gameclubcentral.com/shoot
