Use Sugru Cold Set Rubber to Cover Exposed Metal Threads
950
Posted
Introduction: Use Sugru Cold Set Rubber to Cover Exposed Metal Threads
You can use Sugru to cover up normally sharp edges. In this case, I had an exposed metal thread at the junction between a pipe and a flange it screwed into. When Sugru sets, it becomes relatively hard and can prevent incidental scratches and cuts.
Step 1: Find Something That You Might Cut Yourself On.
Step 2: Apply Enough Sugru to the Area to Create a Thick Barrier
Be careful that you don't push too hard while the Sugru is still soft and accidentally cut yourself.
Step 3: Use a Flat Object (like the Edge of a Credit Card) to Make the Edges Look Neat.
Follow the directions on the package. Once you have exposed the Sugru to air, you have a limited time to make changes before it begins to harden. Work smoothly and you will have more than enough time to clean up the appearance.
Step 4: Allow 24+ Hours for the Sugru to Set. Enjoy Your Newly Safe Object!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
