3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Use Your Camera To Capture "3D" Anaglyphs
Step 7Cut Out The Stop And Apertures
Cut out the disc. You now have two options:
1. Using the disc as a template, drill the aperture holes into a lenscap.
2. Cut out the apertures. Using scissors, this is easiest if you temporarily fold the disc along the center line through the two apertures and then cut the folded piece. For the truly tiny apertures that are commonly needed with compact cameras, it is easier to use a pin or needle to make the holes.
If you have access to a stencil or laser cutter, that is the most precise way to do this!
In any case, you now have a stop with left and right apertures.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:ProfHankD(Prof. Hank Dietz)
I'm an Electrical and Computer Engineering Professor at the University of Kentucky. I'm probably best known for things I've done involving Linux PC cluster supercomputing; I built the world's first b...
more »
