Use Your Old Soap Scraps - and enjoy it!
 by Puzzledd
Featured
Everyone knows the feeling… you have a lovely, new bar of soap, a joy to use, but it fast deteriorates into a little scrap of soap that doesn’t lather, breaks when you use it, and slips through your fingers to sit mockingly on the shower floor- or, worse still, sets to the floor of the shower so you have to prize it off with your fingernails.
So, what do you do with the soap scraps? You can:
1) Throw them away- neither ecologically sound nor good for the budget
2) Put them by the hand basin and hope people will feel they have to use them up – unlikely, they’ll probably just sit there and dry up and look yuk while everyone avoids them
3) Save them in a container until you have a cupful, then boil them up with water in an old saucepan, mush them into goop and use it to wash your clothes – practical, but messy and not much fun
4) Put them in an old-fashioned “soap saver” (a little wire basket with a handle; you put soap inside, close it up, and agitate it under a running hot tap) to wash your dishes- but it leaves soap scum on your dishes, and where would you find a soap saver these days?
5) Put them in the cut-off leg of a stocking/pantyhose and tie to your outdoor tap for washing hands after gardening- this works with bigger bits, but scraps dry out/break up/ don’t lather
6) Leave them in the soap rack where they will fall out, or in the soap dish to go mushy/mouldy, and pretend it’s someone else’s problem- yuk (it become’s everyone’s problem)
7) Leave them in the bottom of the shower to stick on like limpets while they slowly get melted away/go mouldy/cause someone to slip and bang their head/break the shower screen etc – don’t say I didn’t warn you
8) Leave one on the kitchen sink for the mice to take - I kid you not, this happened (one day there were little teeth marks in the soap; the next morning it was gone!)
or – ta-dah!
9) Mold the scraps onto a new bar of soap, and experience the constant joy of a decent-sized piece of soap to use, whilst basking in the self-righteous glow of someone who isn’t making any mess or wasting a thing! If this is your preferred option, read on…
Step 1: Soften old and new soap
Get your scrap and your new bar* of soap, and leave them both on a damp sponge (or folded washcloth) for a few hours, until the bottom side of both pieces is softened.
Soap which has an indentation in the side works best, but a more rounded cake of soap works fine, too- just make sure it’s softened enough to work with as in the next step.
* It's easier if the new soap has been used a few times to wear down the edges and soften a bit- see the second example (white/white). I's also easier if you use your scrap before it dries out too much and hardens.
Note- I've shown a white scrap on green soap so it's clearer, but it looks much better with the same colour- e.g. white on white!
joen says: Aug 20, 2011. 5:28 PM
I can't afford to through away soap scraps like that. I found a simpler way of doing this. Start using the new bar and the old scrap of soap together and as you use it wear one side of each as flat as you can which might take several uses. Once the two pieces have a flat side, get both flat sides nice and sudsy and press the flat sides together. Let it sit and dry and by the next day they will have fused together. It may take several attempts but it will work. I have been doing that all my life and I haven't had to ask "what do I do with my soap scraps?" because I have never had any.
Thanks for putting this idea out there.
Puzzledd (author) in reply to joenAug 21, 2011. 6:17 AM
This sounds good- thanks for the comment! You may want to try scoring some lines both ways across your flat sides to help them fuse together the first time:)
Puzzledd (author) says: Mar 25, 2011. 7:24 PM
A friend who is keen on sewing and patchworking says she uses dried up soap slivers to mark her material (instead of tailor's chalk). The soap just washes out with no marks.
jameshatty says: Mar 22, 2011. 5:34 AM
Brilliant way tp save those bits of soap! But there are cheap product you can get which is made exactly for doing this... The one i use and think is a perfect solution is JoeSoap, it is a plastic disc which acts as a backbone to add soap slivers to, and make a re-usable bar of soap!
Here is one for £2.99 on ebay – bit.ly/g3va2S (copy this into address bar)
Puzzledd (author) in reply to jameshattyMar 25, 2011. 7:23 PM
Thanks for the idea and the link! Sounds as if it works well for you.
I usually just add the slivers to the new soap (which acts as the "backbone"), so it's quick and easy and always nice to use. Costs nothing, too ;)
porcupinemamma says: Oct 18, 2010. 5:21 AM
I also used to do what Nizerbean did, but because my soap is a moistrizing bar, it didn't set up very well. Cool Instructable! I actually think the two coloured bar is snazzy :0)
Puzzledd (author) in reply to porcupinemammaOct 18, 2010. 6:14 AM
Thanks! ;)
Screamo says: Oct 17, 2010. 5:48 PM
I like the mousey :D
Puzzledd (author) in reply to ScreamoOct 18, 2010. 12:53 AM
Yep, I never saw that soap again! I'm currently trying out 2 "humane mouse traps" that I've made, to try to catch and re-locate the cheeky little blighters - if they work, I'll do an Instructable on it- but I'm not holding my breath on that one. The mice have just been laughing at my traps for over a year. Maybe my new design will work....
Ninzerbean says: Oct 17, 2010. 9:51 AM
I used to something just like this by tossing all my scrap soaps in a cup under the sink and when I had enough I would add some water and moosh them all together to create a big bar. Great idea you have here!
Puzzledd (author) in reply to NinzerbeanOct 18, 2010. 12:49 AM
Yes, me too- but it gets a bit yuk. Thanks for the comment!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
