TJBot - Use Your Voice to Control a Light With Watson
22,873
61
52
Posted
Introduction: TJBot - Use Your Voice to Control a Light With Watson
This instructable guides you through connecting a Raspberry Pi to Watson Speech to Text and change the color of a LED through speech. For example, you may say "Turn the light green" to change the color of the LED to green.
Step 1: Parts
Step 2: Prepare Your Pi
If you have used Raspberry Pi before, install Node.js and the Alsa packages and go to the next step. Otherwise, follow the instructions below to set up your Pi:
Getting Started with Your Pi
Raspberry Pi is similar to a full computer, which means you need a monitor, mouse, and keyboard for it. If you have a TV around, you can connect your Pi to your TV via a HDMI cable. In most of the Pi kits, the SD card is already preloaded with an image of the Raspberry Pi Operating System. You need to put the SD card in the Pi, turn the Pi ON and follow the instructions on screen to complete the installation of the operating system. If you have problems setting up your Pi, you can troubleshoot here.
Here is an easy way to get your Pi connected to wifi.
Install Packages
Open a terminal application on the Pi and execute the following commands to install the latest version of Node.js and npm (Node Package Manager). You need these packages later to run your code.
curl -sL http://ibm.biz/tjbot-bootstrap | sudo sh -
Step 3: Assemble TJBot
Here is a quick video of how to fold the kit. The detailed instructions are available on another instructable: Build TJBot out of Cardboard
Once your TJBot is ready, get ready to connect your LED to the Pi Pins.
Attention
It's very important to make sure you connect the LED to the right pins, otherwise you may damage your LED or the Pi.
ALWAYS start with the GND pin. GND is the longest leg of your LED. The LED has a flat side. The GND is the second leg from the flat side. Again if you are unsure, DO NOT connect the LED to the Pi.
Connect the GND to GND pin on the pi (see the picture). Then connect 'Data in', the 4th leg from the flat side, to the Pi's GPIO pin. Lastly, connect the third leg from the flat side to the 3.3V on the Pi.
Step 4: Download the Sample Code
The sample code is available at github. Download or clone the sample code and execute the following commands from a terminal to install its dependencies.
Here are the instructions for how to clone a repository from github if you have not done that before.
git clone https://github.com/ibmtjbot/tjbot.git
cd tjbot/recipes/speech_to_text
npm install
Step 5: Update Your Credentials
In this step, we help you get API access to the Watson Speech to Text. Let's start with creating a Speech to Text instance on Bluemix (If you don't have a Bluemix account, follow the instructions to create a free trial).
You may leave the default values and select 'Create'.
Almost done! You just need to copy your credentials to the clipboard.
Click on 'Sevice Credentials' on the left menu and copy your credentials into the clipboard.
Now go to the speech_to_text folder and make a copy of the default config file.
cp config.default.js config.js
Open config.js file using your favorite text editor and update it with your username and password.
Step 6: Run the Code
Once done with testing the LED, you can run the main module:
sudo node stt.js
Now talk to your microphone to change the color of the LED.
Say "Turn the light blue" to change the light to blue. You can try other colors: yellow, green, orange, purple, magenta, red, blue, aqua, white). You can either say "Turn the light on" or "Turn the light off"!
Troubleshoot
Is the LED not lighting up? No worries, we can fix it.
You may test your LED setup to make sure the connections are correct and the library is properly installed. When you run the test module, it should turn your LED on.
cd tjbot/bootstrap/tests
npm install
sudo node test.led.js
If the LED does not light up, you can try moving the power from 3.3 to 5 volts. If neither the 3.3v or 5v pins work, you will need a 1N4001 diode. The diode is inserted between the power pin of the LED (the shorter of the two middle pins) and the 5v pin on the Raspberry Pi. If you have problems with the setup, please refer to Adafruit's Neopixel on Raspbeery Pi guide to troubleshoot.
The LED library uses the PWM module (GPIO 18) to drive the data line of the LEDs. This conflicts with the built-in audio hardware, which uses the same pin to drive the audio output. Depending on your configuration of Raspbian, the sound drivers may be more aggressive in taking away control of GPIO 18 from other processes. If your LED shows random colors instead of the expected color, use this trick to fix it.
cd ..
sudo cp tjbot-blacklist-snd.conf /etc/modprobe.d/
sudo update-initramfs -u
Reboot and confirm no "snd" modules are running by executing the command "lsmod".
lsmod
Enjoy! Don't forget to share a picture/video of your setup #TJBot! :-)
Step 7: What's Next?
You can add new colors to your color palette in stt.js. TJBot uses a NeoPixel RGB LED, which means it can show any combination of red, green, and blue.
We have hidden a disco party for you. Find the code for disco party in stt.js and uncomment the code. Now you can ask TJBot to show you the disco lights by saying "Let's have a disco party"!
Try implementing your own TJBot party and share it with us #TJBot!
Once ready to move on, try the next recipe to make TJBot respond to emotions using Watson.
3 People Made This Project!
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Spotless Contest
    Spotless Contest
npm disn't install during setup, so use:
sudo apt-get install npm
43 Comments
Hello there! I have a few problems, can you help me?
First off, after you upload your credentials and paste them on to the nano config.js, what do you do?
Second, when I tried to run: sudo node stt.js, it says Syntax error unexpected toke n. I dont know how to fix that.
Thanks!
Hi, everybody!
When I run sudo node stt.js, I receive the info that "TJBot is listening, you may speak now". However, right after the Console gives me the message, the program is closed.
I'm using a USB mic and no Error Message is showed for me.
I already read MauricioM82 comment, but that didn't help either. Is something related to audio configuration too?
Thank You!
Hi.
When I run stt.js program it shows the message:
"TJBot is listening, you may speak now."
but don't give me time to speak and close the program right after showing the message. No errors, nothing, just show the message and close the program.
I am using an USB sound card with both input and output. Both arecord and aplay commands works just fine, I am able to record and listen to the audio I've recorded. I am also able to use the voice control to control bb-8.
Any suggestions?
Thank you.
Hi MauricioM82,
You are correct, the issue is definitely related to the app having difficulty setting up audio. For arecord on command line, do you pass any parameters for your app to work correctly ? For example if your sound input might be listed with an unexpected hardware ID or might need several parameters to work.
To find out your hardware device ID run arecord -L ,and then specify that as a parameter when you instantiate the mic in stt.js.
In the sample apps we provide, we use the mic npm library (
https://www.npmjs.com/package/mic) to record audio. You can provide hardware options when you instantiate your mic to record audio e.g
var micInstance = mic({ 'rate': '44100', 'channels': '2', 'debug': false, 'exitO
nSilence': 6, 'device': 'plughw:1,0' });
A related issue (solved) on recording from a bluetooth and usb mic can be found here
https://github.com/ibmtjbot/tjbot/issues/12
Hi Victordibia
First off, thanks for this fun and easy to follow recipe!
I've followed all the steps on the tutorial however i'm getting an error after running the command "sudo node stt.js".
I believe the trouble is derived from raspbian jessie not seeing my usb mic.
The error reads "the speech_to_text service returned an error" and then prints lines of code. It appears right after the console logs "TjBot initializing microphone"
I've ran asplay -l and a usb sound card does not appear. However when i go to the raspberry pi settings > preferences > audio devices> the dropdown shows my usb mic, but when I attempt at making it the default audio, it never saves the change.
I've been stuck on this problem some time, so any help would be greatly appreciated.
I'm running Raspbian 8.0 Jessie.
Thanks for reading and I hope to hear from you soon!
hi ,
I'm facing the same issue
Did you solve it .?
Great!
Thank you for your help. So, I specified the device when instantiating the mic and it worked, it now recognizes my voice.
The problem now is that the led don't change colors (it's green, and always green).
I did the suggestions on the Troubleshooting part of the article but after reboot I see several "snd" modules loaded, like
snd_usb_audio 118800 3
snd_hwdep 5727 1 snd_usb_audio
snd_usbmidi_lib 19801 1 snd_usb_audio
snd_rawmidi 18516 1 snd_usbmidi_lib
snd_seq_device 3621 1 snd_rawmidi
snd_pcm 75762 1 snd_usb_audio
snd_timer 19288 1 snd_pcm
Any suggestions?
Thank you in advance.
Maybe I found the answer.. I may be using a different type of led.
We have the ground pin and one of each other is for one color.
Does the led used on the article has a special name, or some way I can identify it to purchase in a store?
Thank you.
I live in Brazil and it's really hard to find the adafruit version or anything similar around here. And shipping from adafruit site to Brazil is way way way to expensive.
Maybe someone could ship a kit from the site to me via regular mail? :D
Thank you for all your help.
