3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Use a Steel Square as a Try Square
I like using a Try Square.  Sometimes I wish my small steel square could function as a try square, too.  With the piece of wood shown in the photo, that is easily done.
Step 1Begin with a piece of wood
Begin with a piece of wood 3/4 inch thick and nearly as long as the longest leg on your steel square.  Make it a bit wider than the longest leg of the steel square is wide.  Make certain the edges on the long sides of the wood are truly parallel to each other.  One way to insure this would be to run the piece of wood between a fence on a router table and a straight bit in the router.
15 comments
Feb 15, 2012. 2:24 AMbroken board says:
very simple, very clever
ill try it tomorrow if its not too hot.
thanks
Jan 11, 2010. 2:16 PMkarossii says:
While a LOT of people mis-spell it, the actual name of this piece of equipment is a TRI square.
There're enough who spell it wrong that you can easily google a "try square" and find out what a tri square is... and probably not be told you spelled it wrong. But check a dictionary or other similar reference source; tri square is the proper spelling.
Dec 30, 2010. 8:45 AMILikeRust says:
Actually, it is correctly a TRY square. Similar to a TRY plane (a/k/a trying plane or fore plane). This comes from an earlier form of English than most of us practice these days. When using this instrument , it was said that the workman was "trying" the work - i.e., checking the work to see if it was square. Thus, this tool is a square for trying the squareness of the work - a try square. A trying plane is for trying a piece of work to assure its flatness.
Jan 14, 2010. 5:27 PMPATSY001 says:
You may also let the know at Merriam Webster know that they too misspelled "Try Square". Also ask them to include the new contraction "There're"  I searched the online dictionary for both "Tri square" and "There're" and both resulted with "not found"
www.merriam-webster.com/dictionary/Try%20square
Jan 1, 2011. 4:46 PMRe-design says:
THis "tri-cornered" argument is "trying" my patience.
Jan 12, 2010. 10:37 AMGoodluck says:
Nice little adapter. I might have to make myself one as the tri-square I have is often too small. It might be a good idea to check it for square too (both with and without the adapter). It's easy enough to draw a line, flip the square and check that the line is still parallel to the square.
Jan 11, 2010. 4:22 PMrimar2000 says:
Very clever as always, Phil. Thanks.
Jan 11, 2010. 2:10 PMjimofoz says:
 It's clever, but why not just rest the inside of the steel square against the wood being measured? That way you don't add two more surfaces to increase the inaccuracy. Not only does the kerf need to be straight and parallel to the back of the wood, but the back of the wood must be kept straight and "undinged" as well.
Jan 11, 2010. 1:22 PMlemonie says:
You don't stop with these handy tricks, so simple, but rather clever too.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
478
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
