3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Use a Vacuum cleaner to build your own Skateboard
Step 2Building the mold
Building the mold
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\moldside.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5192657.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\clapstyle.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5212689.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\moldcurve.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5192669.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5192666.jpg
The mold is what the plywood is squashed against forcing it to take the curvy shape of the skateboard. It will be made from stacked cross sections of spruce plywood. First create a cardboard template of the mold cross sections(fig.2a) and use it to trace out 15 versions on to the spruce plywood sheets.(fig.2b) Cut out the cross-section layers then glue the layers together and squeeze with clamps,(fig.2c) wipe off the excess glue that squeezes out.
Once dry, remove clamps and use rasp or belt sander to remove any differences in the cross sections so the surface of the mold is smooth.
Mark off area for inner concave where material needs to be removed.(fig.2d)Make a template of the desired inner curve(fig.2e) so you know exactly what material needs to be removed with the rasp or belt sander.(fig.2f) Refine surface of the mold first with the coarse and then with the smooth sandpaper.
11 comments
Apr 18, 2010. 4:16 PMiTinkers says:
This kind of mould can be made from foam as well. The process is much simpler and the mould much lighter.
You just use the pink insulation foam and a hot wire cutter.  If you don't have a hot wire cutter knives, and saws, will do.  The foam is strong enough to resist compression once in the bag
Apr 18, 2010. 7:49 PMoakspoor says:
construction foam would collapse against the wood as the vacuum pulled out the foam's gas
Apr 18, 2010. 11:22 PMiTinkers says:
Pics for proof :)
I can't find the pics of it in the vacuum bag, but I found the compression ones.  It's the same kind of mould but you only need one half for the bag.
not all these pics are from the same deck press. I just picked ones that showed it best :)
The pic of the mould is after it was used.  As you can see it shows some signs of pressure but it maintained its shape. It was used again a number of times.
The second pic is the wood in the press.  This shows you another way to press a deck using threaded rod as a pressure source.  It's a little more cumbersome and more work than a bag.
The last pic is the board that was pressed from that mould.
Apr 6, 2011. 6:13 PMgruffy says:
Hey iTinkers, sorry to revive this year-old thread, but you seem like you have some experience in this field. I'm curious about the permanency of the foam you used in your mold, because if I wind up making a mold that I like I'll want it to be able to produce many a deck. How long did your foam mold last?
I'm also curious about the differences between vacuum bagging and bolt pressing. Does one have an advantage over the other when using foam? (foam fatigue due to vacuuming is my concern)
Finally, is it a good idea to use the foam in the same way that gregy (the author of the instructable) used plywood? I want to create a decent looking concave and it seems like the method used in this instructable might be better than the method you used in that respect.
Apr 7, 2011. 1:03 PMiTinkers says:
The mold in the pic was used to press a couple of decks before being discarded. There was no real wear on the foam it was just a switch to the vacuum bag to make life easier.
The vacum bag is a much better system than the threaded rod. It cuts your time down considerably, is easier for one man to use alone, you only need half the mold, and you get more even pressure. The foam is dense enough that it resists compression quite well. You do see some wear, and it gets worse with time, but it work very well.
As to the durability of the foam....it depends. It depends on the type of deck you wanna build. Most of the boards my buddy makes are drop down decks, like the one in the pic. The drop down creates a bit of a weak spot in the mold. Mainly because you need to use some clamps around that area even when u are using the bag. It just helps you get cleaner, sharper bends. Unfortunately it causes some extra stress and compression on the foam.
I'd say you can average about 3-5 decks per mold before it deforms too much.
Now if you were building flat decks with just some concave...you could probably get a few more presses. It all depends on what you want out of the deck.
The beauty of it is that the foam is pretty cheap so it's not a huge burden to remake a mold after a few presses. It doesn't take long to do so either.
You could use foam in the same way as he used the plywood but you wouldn't gain much for the amount of extra effort. The only reason I would think you'd wanna do that is if you had some thin, but real dense, foam and wanted to use it. Otherwise it is simpler to just lay the foam flat and cut the contour out of one piece. If you need more height glue two together. I doubt you'll put more that 2-4 inches of curve in it. If you put too much concave in the board it becomes a big trough and a little uncomfortable to stand on. If you put too much arch in it then you'll mess up your wheel base.
The plywood method makes a more durable mold but it is more labor intensive and not very adjustable. The foam is cheap, easy to work with, and you can make adjustments and corrections on it (sometimes).
Apr 18, 2011. 6:17 PMgruffy says:
You may be thinking that your in-depth response was a waste by now. This is not the case: I just popped my board out of my FOAM press and cut it out. I'm going to stain it and post pictures.
For now though, I just want to thank you for helping me out.
Apr 24, 2011. 10:16 PMiTinkers says:
Awesome! Can't wait to see what you made.
Apr 26, 2011. 6:43 PMgruffy says:
ahh it's not letting me post the images for some reason!
Apr 18, 2010. 11:10 PMiTinkers says:
A good friend of mine has been pressing long boards using this method for a while now.  All the moulds he ever used were made of insulation foam.
The stuff you need for it is the rigid panel insulation.  it's about 2 inches thick and comes in various sizes. It works beautifully.
Also used it to make a positive and negative for a mould that used threaded rod to provide compression.  Worked beautifully like that too.
The good thing is that its 2 inches thick so it works for mostly any curve you'd want on a board.  It works for a nice 2 inch drop in long boards as well.  And if you need more height you just glue 2 panels together to boost you up to 4 inches.
It is a much faster and easier method than cutting this many layers of wood and sanding them to the shape.
Oct 16, 2008. 10:19 PMIkilledEMOcity says:
would it be possible to use an old board as a mold? I have an almost board that I don't use so would i just but the veiner on top of that?? Please get back to me!!
Nov 20, 2008. 5:58 PMpower says:
board too weak. requires a mold
Jan 3, 2009. 1:34 PMtieguy says:
professionals use foam, which is considerably weaker than plywood.
Dec 4, 2010. 9:25 PMbigjeff5 says:
High density foam resists compression very well, but does not resist cutting well, which is why they use it.  Being a dense foam, the air cannot be sucked out with pressures even remotely close to that of a household vacuum cleaner.
Using a skateboard as the mold is a bad idea because it will flex when compressed, especially under the heavy compression of the vacuum, so any board you make using a skateboard as the mold is going to be warped.
To see what I mean about flimsy substances that can resist compression, find some packing cardboard used in shipping large objects - it has a honeycomb structure that resists compression extremely well.  You can walk on it without damaging it, yet it is light and flimsy enough to be torn in half by hand.  That stuff is made of paper, and not very much of it.
Apr 18, 2010. 8:46 AMFMunkey says:
I've seen similar instructions with this type of wood mold, it may be easier to cut each piece of wood individually to fit the concave, and then sand the edges so it creates a smooth drop.
Hopefully that made sense!
Apr 18, 2010. 12:11 PMnetgrazer says:
You could use a 3D program (Blender, for instance) to perfect the shape of your ideal deck, print out all the cross sections on paper, and stick them on the plywood as a template.
If you model it using spline shapes, it's relatively easy to make variations of your deck, different sizes, etc.
Mar 9, 2008. 11:02 AMcmchrist says:
that is sick
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:gregorylavoie
