3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Use a Vacuum cleaner to build your own Skateboard
Step 4Make a Skateboard
Make a Skateboard
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\grain.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252769.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5242759.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5242751.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5242744.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5242753.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5242745.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5242747.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\PUSH.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\HITSPOTS.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5212680c.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\Copy of board dimenions2.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5212684c.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5212686c.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252763.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252766.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252770.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252771.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252775.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252776.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252778.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252780.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P5252785.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P6022960.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P6022964.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P6022969.jpg
  • C:\Documents and Settings\Owner\Desktop\building skateboard2\compressed\P6022991.jpg
  • last photo ←
Now you are ready to make the skateboard.
Cut seven 34inch x 11inch sheets of the maple veneer (the sheets need to be larger than the final board because there will be waste wood formed on the edges from the bending process). Three should have the grain going lengthwise (easier to bend the short way) and four should have the grain going widthwise (easier to bend the long way).(fig.4a) Be sure to sand off any chipping on the edges so that the wood is smooth.(fig.4b)
Take layer one (grain going widthwise) and apply a coat of wood glue over the surface all the way to the edges,(fig.4c) place layer 2 (grain going lengthwise) on top and apply glue over the surface all the way to the edges then place layer 3 (grain going widthwise) on top. Now stack the 3 glued layers centered on top of the mold.(fig.4d) You can put four tabs of masking tape on the edges of the wood to make sure it does not slide around when you put it into the bag.
Take a large, mesh dishwashing scrubby, unroll it(fig.4e)and cover the mold and wood veneers with the mesh.(fig.4f)This will allow air to flow around the mold and be sucked into the vacuum easily. You do not want to have any trapped air pockets. Slide the finished compilation of the mold, the glued veneers and mesh into the center of the bag-press and close the seal.(fig.4g) Hook up the vacuum and turn it on.(fig.4h) Keep the bag from sucking itself under the maple veneers by pushing the tips of the veneers down when you turn on the vacuum.(fig.4i) As the air is removed the bag will force the wood to conform to the mold. Once all the air is out gently hit the inner concave with the rubber mallet to help bring in the curve.(fig.4j)
Let the wood press for at least 4 hours before opening the bag and removing the bent board. Remove the mesh and masking tape. Now repeat the last steps to apply the final 4 veneers on top of the 3 first ones.
Once the curved board is dry, make a paper template of the shape you want the board to be(fig.4l) and trace it onto the curved wood.(fig.4m) Carefully cut out the shape with a scroll saw.(fig.4n) Refine the shape with files and sand paper and round all the edges.
Locate where you want your wheels attached and mark the location for the holes with a pencil on the bottom of the deck.(fig.4o)Drill the first hole then screw the truck in place. You can then use the holes in the truck as a guide to drill the next holes, guaranteeing they will line up properly. Once the holes are all drilled remove the screws and use a counter sink on the tops of the holes so that the screw will lie flush with the board.(fig.4p)
At this point you can paint and seal the board to help protect the wood and make it the colour you want.
The board itself is complete,(fig.4q) now you just need to apply the grip tape.(fig.4r) Don't peel all the backing off the roll and just stick it on because this will create bubbles. Instead, start at one end and peel off only a little backing at a time, working it down as you go.(fig.4s)
Once the grip tape is on,(fig.4t) you need to trim it to match the edges. Take an old piece of sand paper and rub the excess grip tape on the edges, this will soften it and leave a mark were you need to cut.(fig.4u) Take an exacto knife and run it around the edges.(fig.4v) If there is any little pieces remaining you can use the sand paper and sand them off. Next, feel out where the truck holes are on the top and stab/trim them out with the knife.(fig.4w)
Now attach your trucks and wheels... and you are ready to go.(fig.4z)
33 comments
Jun 29, 2007. 8:32 AMbryceronie says:
This is absolutely amazing! I love your work and how you put this together!! It would have felt awesome to ride it after, I usually go through 2 boards a month so I would be a little mad to break it , but it would be cheaper !
Dec 9, 2007. 4:54 PMphilreeper13 says:
how do you go through two board a month. r u stupid or just dont know how to skate.
Mar 3, 2011. 9:08 AMlovemachinesix says:
LOL, seriously kid, the better you get the more you thrash your boards. A board a week is pretty average- thats a good week mind you, back weeks and big tricks kill boards. Maybe you should push yourself a bit more if you skate.
Oct 18, 2008. 4:08 PMSpencerr says:
Pro skaters go through boards in just a week. You probably didnt know this, but Unfortunately when a Skateboard gets used alot, it becomes weaker, and gets scratched up too the point where its not safe. Boards crack man, your just not skating hard enough
Apr 18, 2010. 10:18 AMarticice says:
Actually, it depends much on how dry the board is. Dry boards crack immediately; new and "wet" boards live longer (until they get dry or you smack them real hard).
When buying a board turn it upside down, take by the tail(nose) and hit against the ground; if you feel it's vibration - then it's "wet". If it just flaps - it's dry and will break fast. In theory, this ability to vibrate saves the board when it hits the ground (ask your physics teacher why ;) ).
I bet the skate shop dudes push boards that have been lying around for some time (and got dry) to n00bz (because they don't skate hard enough anyway) or to just random unlucky or dumb-looking ppl.
Aug 13, 2009. 3:41 PMStarshipMcGee says:
Pro skaters also don't have to buy there own decks..... Man, use the deck until it cracks then buy a new one, a little bit of scratches wont hurt.. dont wast your money. Great instructable buy the way. I didnt think that a household vacuum could bend 7 layers of veneer.
Dec 9, 2007. 5:24 PMbryceronie says:
lol skating sets, handrails, trust me they do break , not often but pro decks break and if I made them and took the time, I try to keep the pop
Nov 11, 2008. 11:32 AMpdub77 says:
my buddy weighed about 170 pounds when we skated back in the day. landing slightly off your trucks down a staircase can snap a board like it's nothing. i've seen him snap more than one board in a week.
Mar 16, 2010. 2:19 PMIdrisB says:
 I know exactly what your friend feels like. I'm bout 170, and its expensive as hell to buy new decks.
Apr 18, 2010. 7:56 AM--scare-- says:
lol try this:
railing out of the skateshop stairs with the new board, and landing on the nose...
70$ wasted in 5 seconds... it's really sad... but the dude in the skateshop saw the whole thing and sponsored us the next week... less sad!! yay!
Jun 18, 2008. 10:59 PMfreshmanfred0000 says:
How well would it work if you replaced a few layers with carbon fiber? or is it possible to make an entire board with carbon fiber?
Jul 14, 2010. 11:40 AMkatz4ever15 says:
carbon fiber does it's job best on the bottom layer because it resists the stretch that happens in the bottom layer when the board flexes, but in a skateboard, where you do tricks in which you smash the bottom layer a lot, it's sort of a waste, imo. you could put it in to replace the layer above that and it might work well
May 22, 2009. 9:29 PMProp says:
I dont think carbon between veneer is a great idea but you can use fiberglass....and you can make the whole thing from carbon but you might need a different prosses
Apr 18, 2010. 8:16 AMjwilliamsen says:
Carbon fiber would probably *not* be an ideal material seeing as it's "strength" is in it's lack of flexibility.  You could, of course, orient the fibers so that you had flex in the desired direction, but the advantage that CF would have over fiberglass is questionable, while undoubtetdly costing a heck of a lot more.....  The process would be similar, but use different materials
Apr 18, 2010. 8:52 AMFMunkey says:
 Actually, carbon fiber is a very common material in longboards. It's expensive, but it does it's job of stiffening the board while lowering the weight. Foam core boards are also possible, though very hard to get right and are very expensive to buy,
Apr 18, 2010. 9:20 AMsnowboardchamp says:
 Carbon fiber is not too common, only in the higher end/ really expensive boards. But it has been used before with good results. People have used CF and fiberglass to replace a layer of veneer, or to make a flexy board stiffer. It is generally fiberglass that is used because it is cheaper and easier to locate/ buy.
Jul 14, 2010. 11:35 AMkatz4ever15 says:
Sector Nine makes a deck with a few strips of carbon carbon for about 100. It's not exclusive to high end expensive decks.
Jul 14, 2010. 12:54 PMProp says:
My last post I made on this is was over a year ago and I know a lot more now about deck building.... carbon stringers in a maple deck will stiffen the deck significantly... you have to use resin instead of wood glue but if you can get carbon it should be easy to get the right resin.... also you can use carbon on top and bottom just for effect if you want... Roarockit skateboard company specializes in supplying materials for making decks and in their tutorials you can find out how to use carbon in a maple deck. http://www.roarockit.com/
Aug 21, 2010. 2:37 PMthemadtreky says:
there's a guy in jacksonville that makes long boards out of layers of carbon fiber and fiber glass. they're light, springy (you can jump on them like a trampoline, and they carve beautifully.
May 2, 2010. 12:22 PMgibbon says:
This reminds me of the H-Street "hell concave".  My feet are getting sore just looking at that deck.  Great instructable!
Apr 19, 2010. 7:43 PMCamaroSSNitro says:
 Dude you dont use cardboard. You use WOOD
Apr 21, 2010. 11:35 AMhyookami says:
He used wood for the board... Maple veener... it says at the begining of this step, the cardboard was to guive form to the mold
Apr 18, 2010. 10:00 AMarticice says:
the nose seems way too sharp.. don't you think?
Apr 18, 2010. 8:59 AMdakellymon says:
 Very nice. Thanks
Apr 18, 2010. 8:41 AMjwilliamsen says:
Given the life of the average skateboard deck this may not be that important - but it's worth mentioning for anyone who wants to build a really fancy board or one that lasts a long time: Don't use aliphatic resin (yellow) glues - substitute epoxy or polyurethane glues instead.  Why?  Because aliphatic resin glues never actually become a "solid" - they, like glass and asphalt - are considered liquids even when they are "hard".  Over time, a piece such as a skateboard or other object that is built from bent or pressure-formed laminations will delaminate - i.e. the plys will separate, and/or the curves will flatten out.  I know because I've been there, used the wrong glue, and watched a project self-destruct over a period of a few months.
Polyurethane glues sand better and take finish better than aliphatics, and are much stronger.  In addition, spraying a tough solvent-based finish - like urethane - over aliphatic resins will cause them to swell and bond poorly - so the edges of your board will look bumpy even if  your sanding job is perfect (polyurethane / epoxy won't swell or react).
If you do use polyurethane glue, make sure to follow the instructions - specifically the part where it says to dampen the wood with water.  Polyurethane glues need water to cure and make a strong bond - without it, they make very weak joints.  Stay away from Titebond or Elmers brand polyurethanes - in my experience, they're quality is spotty at best.  Gorilla Glue has never let me down....
Other than these minor comments - great instructable!  :)
Jun 28, 2008. 12:27 PMskidude says:
Do you need to leave the vacuum sucking for the full 4 hours?
Apr 18, 2010. 8:20 AMjwilliamsen says:
See the reply to zero4everk above....
Nov 4, 2008. 11:10 AMdirtlooper says:
can you find most of the materials at a home depot or lowes?
Apr 18, 2010. 8:19 AMjwilliamsen says:
Pretty much everything except the veneers and skateboard parts....
Apr 9, 2009. 7:00 PMzero4everk says:
how long do you leave the vacuum on?:)
Apr 18, 2010. 8:18 AMjwilliamsen says:
If you install a valve in the vacuum line, and you don't have any leaks, you can just shut the valve off once maximum vacuum has been achieved.  It would be a really good idea, however, to check every half-hour or so to make sure that the bag and valve were holding vacuum (at which point, if you find it's not, you just turn on the vacuum, open the valve, and tighten up the vacuum).
Apr 18, 2010. 8:08 AMdimovi says:
You can have the grip tape cut and the board etched at CutYourWay.com
Jan 17, 2010. 10:32 PMnonoodlez says:
This is a really neat idea even if you don't go through a lot of boards. I would go with a little bit of a different shape. Maybe a little less pointy on the nose (errr, tail?) but great work nonetheless!
Aug 10, 2009. 12:11 PMguy90 says:
This is ideal, and the vacuum bag idea seems cheaper, and easier to understand then the ones I've seen elsewhere.You've got a deck you can print make designs onto now ; ) Just a thought, at my college we'd use these huge A3 sized bags, to hold our artwork, maybe one of them for the bag? Although I have no adhesives to seal my bag, I usually place it inbetween two sheets of brown paper, and iron around the edges, the heat creates a really strong bond between the two layers, and an extra bit of duct tape is whats finally needed to perform the air tight seal.
Jun 18, 2009. 2:02 PMpetoa says:
Awesome, i've been thinking about making a skateboard mold for a few years now. How did the deck hold up after a few months? You said you just used wood glue?
May 13, 2009. 11:26 AMdyno21 says:
dude you got waaaay too much front kick on that thing. also, have you heard about using baltic birch veneers? if so do you think they are better than maple?
May 22, 2009. 9:26 PMProp says:
If you want a really flexible board or your building a longboard baltic birch is great....i build a longboard using baltic birch plywood and it works great....really flexible....then again if your trying to get a lot of flex id recommend bamboo veneer and if you feel ambitious use fiberglass between the veneers
Apr 29, 2009. 6:57 AMbeiko says:
i dont understand what happend to the other 4 pieces of maple veneer? from what i understood you only glued 3 pieces of wood together then put them on the mold
Oct 30, 2007. 2:30 PMbassplayer27 says:
How do you apply a graphic to your board once you are finished?
Nov 24, 2007. 7:22 AMlespaulsrule says:
spray paint and clear coats
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:gregorylavoie
