Introduction: ATX Power Supply for an Xbox360 and Xbox 360 Cooling Mod!
This is my updated instructable on how i used a standard pc power supply for my XBOX 360. This is not my original idea, I saw a few different ways to do this on the internet but this is what I did and it worked for me. This is an easy way to avoid speanding money on a new or 3rd party 360 power brick and be able to power some pc fans for my new cooling mod.
I warn anyone who decides to use this instructable, if your power supply doesn't meet the minimum power requirements YOU WILL KILL YOUR XBOX !!!!!!
Step 1: Power Requirements
Before you start cuting wires and buying things your going to want to know how much power your 360 needs. Turn your Xbox360 so you can see the back and look at the left side(from back). Right above the power plug is what you are looking for. My xbox360 elite uses 16.5 amps on the 12 volt rail and 1 amp on the 5 volt. The number you want to worry about is the 12 volt rail, this is what you will look for when choosing a powersupply. The supply i used supplies 25A on the 5V and 19A on the 12V.
Once you have found the power supply you will use, the next step is to connect your new power supply to your xbox360.
Step 2: Connecting the Power to Your 360
Now we need to plug the XBOX360 into its new power supply. To do this you will need:
*the xbox360 power brick
*new atx power supply or one you salvaged from an old computer
*electrical tape , scissors or knife
& for the cooling mod you will need:
*4X80mm or 70mm pc case fans
*zip ties or twist ties(wire covered in paper or plastic)
*some cardboard from a cerial box
Step 1: Take your 360 power brick and cut the power cord off. You can now keep the brick so you can destroy it later or just throw it in the garbage.
Step 2: Take the power cord you cut off the power brick and strip about 15cm(6')'of the gray insulation off exposing 8 wires inside: 3 black(ground), 3 yellow(+12v), 1 red(+5v) , and 1 blue. Strip about 10cm(4) of insulation off each of the wires EXCEPT THE BLUE WIRE! THE BLUE WIRE IS USED BY THE XBOX360 TO "TALK" TO THE 360 POWER BRICK, Then twist the 3 black wires together. Then do the same to the yellow wires.
Step 3: Take the atx power supply and cut off the 20/24pin connector, the 4pin or 8 pin motherboard connector and the 6pin or 8 pin PCI-E connectors and make sure all the newly exposed wires are untangled and cut the same length.
Step 4: Group the black(ground), yellow(+12v) and red(+5v) wires together. If the supply you choose does not have a switch you will need to keep the green wire and a black wire to make one. Cut the rest of the wires off till about 10cm(4) is left sticking out the back of the supply.
Step 5: Strip enough insulation off each of the wires so the wires of the same color can be twisted together. the final step is to twist the yellow wires of the power supply to the yellow wires of the XBOX360 power cord together. then use the electrical tape and covert wires so they are insolated from the others. Do the same with the black and red wires then cover all the wires in tape
Congratulations, you've just finished the hardest part of this instructable now onto the last step.
WE GIVE YOUR XBOX LIFE!!!!!!!
Step 3: Giving Life to Your Power Supply
Twist the green wire together with a black wire and the power supply will come to life, then hit the power button on the XBOX360 and game on!
