You can wall mount your monitor, tiger direct
has a good mount, but it doesn't swivel. I got it, and it was easy to setup and install. Also you can connect your computer to the monitor for an extra usage. I also chose to connect the power cable of my monitor to my cable box so I could turn it off and on by turning my cable box off and on via remote. This may not be a feature on all cable boxes. My monitor also happens to return to its last state when it is plugged in (So if I turn the cable box off when it was on, when I turn the cable box on again, the monitor will turn on). This also may not be true of your monitor, but it is easy to test. Just leave your monitor on and unplug it, if it turns back on when you plug it in, then this trick will work.
