Step 5Configuration and Implementation
I use two configurations (one for navigating Windows ("Windows.cfg") and one for playing games). You can download my Windows configuration at the bottom of the page here. It's made so the left thumbstick moves the pointer, A left clicks, B right clicks, X speeds up the pointer, left bumper is ALT, right bumper is TAB (I use these two together to switch between windows quickly), left trigger is ALT + SPACE + N (which minimizes a window), right trigger is ALT + F4 (which closes a window), right thumbstick scrolls up and down, and a few other buttons do things as well. The gaming configuration just mirrors the settings in SNES9X.
If you plan on using the controller as your primary input device it's important that you have JoyToKey run at startup. It has an option under "File", but I haven't had good luck with that. Instead I created a shortcut in the "Startup" folder. Then right clicked and chose "Properties". From there I changed "Run:" to "Minimized". This way not only will JoyToKey start every time Windows starts, but it'll start out of the way. (Note: I don't think a "Startup" folder is present on all computers, but you can still make JoyToKey run at startup by using msconfig. Do a search on how to use msconfig if you're not familiar with it.)
To use my configuration simply download it and put it in the root directory that JoyToKey is in. I recommend you download it, and then modify it to better suite your needs. Well, we've made it to the end. Thanks for reading, and let me know what you think.
Windows.cfg1 KB| « Previous Step | Download PDFView All Steps | Next Step » |
The other link is 404
Great instructable, BTW!
http://windows.microsoft.com/en-IE/windows-vista/Show-or-hide-file-name-extensions
Doing this will allow you to simply change the file extension to .cfg, nothing else is required, it should work once you change the extension to this.
The only issue I'm having is when left idle the cursor drifts to the left, if I point it to the left it keeps travelling. Any way to stop this?
Also thanks to asdf;sdfs1dfsdf for the file extension tip-
HELP ME !!!!!!!!
http://www.xbox.com/en-US/hardware/x/xbox360messengerkit/
If you have time, read through the following thread: http://www.mp3car.com/vbulletin/input-devices/108554-xbox360-chatpad-awsome-backlit-mini-keyboard.html
