The thumb drive I used is a 2 Gb from Kingston. The size should be less than 4 Gb.
When you look at the sreenshots below you have to consider that it is in German.
Step 1:
Rename your thumb drive as "RAM DRIVE", so you can see that it is the one which is used as RAM.
Step 2:
Delete all the stuff one the pen drive. Look also after hidden once.
Remove these ads by
Signing UpStep 1Step 3
Step 3:
Right click on "My Computer" --> Properties
http://imageshack.us/photo/my-images/535/91066704.jpg/
http://img843.imageshack.us/img843/883/afsb.jpg
. . what should i do ?
you have missunderstood something.
This instructable doesn´t enlarge you pc-ram with the storage of an usb thumb drive, but the virtual ram of your pc. This is something different.
Because of that, you computer has still 1gb of hardware ram, but more gb of virtual ram.
Moritzb
1. So if 200GB is converted to rams; it would be about 199.9GBRAM because it's subjected by 5mb? I know I'm not gonna use up that much, but just pretend if it does hold that much.
2. Compare the performances against the real rams...
3. Can the virtual ram gets full without using it as a partition harddrive?
2. Try it out.
3. I think if you use a 2gb drive it can get full but not 200gb.
Moritzb
It can be, that the computer will just use the rest space of the drive.
But the computer also could get damage. It´s your own risk to try it, i don´t take any responsibility.
i want to know , how to speed up my ram,
i have two pc one with xp and other with windows 7
please help.
Greetings MoritzB
I renamed it like it said but yet no its not there??
Then check if it´s working on one other pc.
Otherwise i don´t know what to do else.
IN my case the memory stick had 1932 MB --> you have to enter 1927 MB.
Greetings MoritzB.
maybe your USB-port in your pc is damaged.
Does you thumb drive gets enouph voltage and current?
Usually your usb drive has to be displayed in Step 6.
It also could be the cause of a broken thump drive.
Greetings, MoritzB.
Also if you do go down this route beware of removing the usb stick, particularly if windows is accessing it to stow pages of RAM. BSoD might say boo.
If you have a desktop machine install a second disk and put your virtual memory on that away from the disk with the OS installed, this will help parallelism (machine can do more multitasking simultaneously giving the impression of enhanced speed).
thanks
I didn´t really catch your question.
The USB RAm will be used, if the intern RAM of your computer is full.
Then the files which are left, get stored ad the USB RAM.
Greetings MoritzB.
If you only declared your USB drive as virtual Ram, only this device is used when the ram is full. but when you also activate your hard drive as virtual Ram it uses in my opinion both system when the ram is full.
G-D Bless
