loading
Step 3: The Level Shifter
Note : If you bought a bluetooth module from sparkfun , skip this step, and head to step four.
Since the Arduino's serial output (Tx pin) is 5-volt logic, if we connect it directly to the Rx pin of the Bluetooth module - which is using 3.3-volt logic -  it will fry the Bluetooth chip. Fortunately, the Arduino supports 3.3-volt logic in reception (Rx pin), so no complex circuit is needed. All we have to build is a simple voltage divider :
- take your breadboard
- grab the resistors and some jumper wires
- connect one end of the 20k resistor to the ground
- connect the other end of the 20k to the 10k resistor
- connect these two ends to the Rx pin of the Bluetooth module
- connect the last end of the 10k resistor to the Tx pin of the Arduino (pin 1)
- check the photos to see if you've wired it correctly
- you're done
Now, head over to step 4 : Wiring everything
<p>https://youtu.be/rLdNCTqWL8E App that is better?</p>
Yeah this instructable is quite old there are much better (and easier to use) apps available now ;)
For the blind person I will have distance sensor info and acceleramoter will indicate he will hit wall too soon but how do i get the android to vibrate or beep. I need a signal to be sent to android because will be sending devices where need to keep cost of components as low as possible. Any help would be appreciated.
<p>Hi, <br>Thank you for that great tutorial! I am working on a little game and I was wondering if it would be possible to connect multiple android phones via bluetooth to arduino at the same time..<br><br>Thank you!</p>
<p>Can the above instructable be used to send data from more than one sensor at the same time?how?</p>
Yes! Have a look at the examples included in the Amarino library. The procedure is :<br>Add a sensor in the amarino app (the + icon), and choose an identifier for the sensor (usually a letter 'A' or 'C' etc...)<br><br>Add a event object with the same letter id in the arduino code<br><br>Repeat for each sensor you want to add (light, magnetic, accel etc)<br><br>Boom ! Multiple sensors<br><br> john
<p>thank you john</p>
<p>it is nice concept but i want to do my android mobile GPS interface with arduino using Bluetooth module device so please give me suggestion or tell me how it is possible?</p>
<p>excellent article.</p><p>man, people like you makes me fell proud of been human, thanks!!</p>
<p>Hi this is really useful XD, a mate used this an iphone with a bluetooth connection in the same way for a glider but the communication between the code, instumentation and servos were too slow, can the android phone be connected with a direct cable instead of wireless communication with the arduino?</p>
You're looking for this :&nbsp;https://www.sparkfun.com/products/11343<br> But you'll have to write some java code for the android phone or use one of the many apps available on the android market (just search ioio on play store)
<p>Is there a way to send data through the USB port instead bluetooth?</p>
<p>Great Project.</p><p>Is there any way to use my <strong>Android</strong> Amarino App data of <strong>accelerometer</strong> or <strong>orientation</strong> sensor to control the RGB hex?</p>
Try to combine the servo example and the multicolorlamp one. (I just replied to your PM btw)
<p>To get the Servo example to work I had to change &quot; int pos = 0; &quot; with just &quot;int pos;&quot; ... otherwise the servo just went to it's mid point position and stayed there. Thanks for the tutorial though, it was helpful! :)</p>
Would this work with the BLE Shield made by RedBearLab?
Hi, <br> <br>that was the problem. I did manage to get an app that can 'discover' Class 0 devices..and I was able to pair the device to my phone. But, Amarino still tries to find new devices...and doesn't see the already paired Bluetooth device. So it doesn't connect. Any ideas ? <br> <br>Thanks, <br>Nooman
Hi. <br>Having the same problem as you describe. Did you figure out a way to connect the jy-mcu to your phone? What app did you use to make your phone find and pair with the jy-mcu? <br>Thanks
Hi, i am going to build a quad copter controlled by an an arduino one and i would like to use my phone's sensors. do you know how fast can the data be transmitted, what is the delay it has? it has to read and send data many times per second to work stabilizing the quad copter. thank you for this awsome tutorial
Actually you can, BUT imagine the quadricopter falls into a pool or something: you won't have your phone anymore. If you want cheap sensors, check out this page (http://www.multiwii.com/). There's also a good community working on these softwares too: <br>http://code.google.com/p/arducopter/<br>http://aeroquad.com/showwiki.php?title=Book:AeroQuad+Manual<br><br>The &quot;smartphone on quadricopter&quot; thing is a bad idea, trust me
Hi, can I use HC06 Serial Bluetooth module?
Yep
hi i am doing a project on android car.i.e controlling a toy car with mobile phones accelerometer.i am using AUBTM-20 bluetooth module and atmega8 microcontroller.i am able to pair my phone with this bluetooth module.but i am not getting any signal at the controller output.could you please help me.my e-mail id is sunandsuresh92@gmail.com
J'adore vos projets. A1R est toujours actif ?
Ouaip ! Bon je l'ai un peu delaiss&eacute; l'ann&eacute;e derniere mais la je travaille sur un nouveau projet (donc un nouveau instructable) avec un pote...
Hi Guys, <br> <br>Hope someone can help me. I am trying to pair my Android phone to a JY-MCU bluetooth module I bought from dealextreme. My phone can't find the device when it does a search (it finds other peoples laptops, etc. in my building but not the bluetooth device next to it). <br> <br>I did try another non-Android old phone and it is able to both see and pair with the bluetooth module. Could this be a Baud rate issue ? Or an Android software issue ? <br>The Android phone can also detect my older non-Andriod phone and successfully pair with it also. <br> <br>I think it has something to do with bug in the BroadComm bluetooth stack that is used by most Android phone manufacturers (LG, HTC, Samsung are affected, but not the Google Nexus phones) that prevents discovery to this and all other bluetooth devices that report their Class of Device (CoD) code as 0&times;00. <br> <br>Do you guys have any suggestions ? <br>Kind regards, <br>Nauman
Hi Guys, <br> <br>Hope someone can help me. I am trying to pair my Android phone to a JY-MCU bluetooth module I bought from dealextreme. My phone can't find the device when it does a search (it finds other peoples laptops, etc. in my building but not the bluetooth device next to it). <br> <br>I did try another non-Android old phone and it is able to both see and pair with the bluetooth module. Could this be a Baud rate issue ? Or an Android software issue ? <br>The Android phone can also detect my older non-Andriod phone and successfully pair with it also. <br> <br>Kind regards, <br>Nauman
Hi again! could you write a code that can control two servos for the X and Y axis as i am new to arduino. <br>Thanks <br>Nick.
Hi, when i try to upload the code to my arduino i just get this error, please help! <br> <br>In file included from Amarino_Servo.cpp:2: <br>C:\Users\Sally\Documents\Arduino\arduino-1.0.1-windows (2)\arduino-1.0.1\libraries\MeetAndroid/MeetAndroid.h:104: error: conflicting return type specified for 'virtual void MeetAndroid::write(uint8_t)' <br>C:\Users\Sally\Documents\Arduino\arduino-1.0.1-windows (2)\arduino-1.0.1\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)' <br>
Use an older version of Arduino IDE, something like 0.27 or older (the MeetAndroid library hasn't been updated for a while)
Hi. <br>I am trying to upload the sketch on my arduino but i have some errors. I have put the meetamarino library and i get this error from my arduino IDE(arduino 1.0.2): <br> <br>Compass_Led:10: error: 'MeetAndroid' does not name a type <br>Compass_Led:13: error: 'MeetAndroid' does not name a type <br>Compass_Led.ino: In function 'void loop()': <br>Compass_Led:40: error: 'meetAndroid' was not declared in this scope <br>Compass_Led.ino: In function 'void compass(byte, byte)': <br>Compass_Led:53: error: 'meetAndroid' was not declared in this scope <br> <br>What arduino IDE did u use on this tutorial? <br>pls help me :)
Yep, the meetandroid library hasn't been updated to work with the newest arduino versions. Try using an older version, like 0.27 something like that. Cheers
Arduino Uno is compatible with this kind of project? <br> <br>I saw in your video, that the car is standing on the Arduino. Is it possible to change your project in the way that the car will move on the road? i mean instead of using bluetooth to connect to the smartphone, we can make the connection between the arduino, rc car and the smartphone through wireless? <br> <br>
I like your instructable, its very good and i rate it. <br>I whant to go through this tutorial, and i don t really know what arduino microcontroller shoud i buy(i am not looking for a cheap one). <br> <br>From what i understant from your tutorial, and from the other comments i understood that i can use a Arduino BT and no bluetooth adapter, or an arduino duemilanove with bluetooth adapter. Pls corect me if i am wrong. <br> <br>I whanna know if i can use some other arduino board +/- bluetooth adapter. <br> <br>A quick reply whoud be great. <br> <br>
I whann buy this arduino duemilanove. Is there a difference between a chipset atmega128 and a atmega328? <br>I mean that if this arduino has an atmega 128, and i buy an arduino with a chipset atmega328(or any kind of chipset other than the atmega128) does this project will work? <br> <br> <br>pls reply :), sorry of my english is bad
Of course ! As long as it's an Arduino, there will be no problems man
Awesome instructable, thank you so much for all the work and the details. I got the cheaper BT module and all the steps worked great! Just one thing: the Test app in the Amarino examples is set to 57600 baud - I used it as is and nothing worked. Thought I messed up something till I decided to change it to 9600 and all worked great. It looks to me that 9600 is the default setting - is there a way to change it? Thanks again for this awesome project!
Just LOVE this!<br>Today i recived my BT module, going to solder it later, but now in trying to think about the code. <br><br>My goal is to make a rc car that you controll by tilting:) <br>How do I change the code to get the arduino to react when I tilt the phone another way? <br>Witch variable should I change??<br><br>Joachim!<br>P.s. Sorry for bad english(I'm Swedish)
Did you succeed ? <br>
yes i did:) <br>It was very easy:)
Man, dont waste your time. Check out my second instructable it's exactly what you want to do.
Which of the white, orange, red, and yellow wires are for Tx, Rx, 3.3v, and GND respectively. Assuming that we are taking about the Tx, and RX for the BlueTooth module (not Tx, Rx for the other side) <br> <br>I believe that this is the same BT module you can get for $6 ish at DealExtreme.com (dx.com ?). Look for datasheets on EGBT-046S and RF-0417C
Yup, you're right, I've swapped the ebay module with the one from DX and the car worked great !
Hello, i new in this things. <br> <br>When i'm installing the amarino arduino library it gives a &quot;Deprecated file&quot; and asks if i want to download the latest version and i download it. <br> <br>When i try to run the compass_led.pde it gives me a error: <br> <br>------D:\Programas\arduino-1.0\libraries\MeetAndroid/MeetAndroid.h:104: error: conflicting return type specified for 'virtual void MeetAndroid::write(uint8_t)' <br>D:\Programas\arduino-1.0\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'-------- <br> <br> <br>CAN ANYONE HELP ME, PLEASE !!!
I am having the same problem as HSS 1978. I am trying to complete the tutorial with the RN-42 breakout bluetooth module from sparkfun with an arduino uno. I have no problem uploading the servo sketch without anything plugged into the arduino, but when i am configuring the sketch with just the GND pin (from module) disconnected i get the error. <br> <br>processing.app.SerialException: Serial port 'COM5' already in use. Try quiting any programs that may be using it. <br> at processing.app.Serial.(Serial.java:144) <br> at processing.app.Serial.(Serial.java:76) <br> at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:75) <br> at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:88) <br> at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:66) <br> at processing.app.Sketch.upload(Sketch.java:1664) <br> at processing.app.Sketch.exportApplet(Sketch.java:1624) <br> at processing.app.Sketch.exportApplet(Sketch.java:1578) <br> at processing.app.Editor$DefaultExportHandler.run(Editor.java:2314) <br> at java.lang.Thread.run(Thread.java:619) <br>processing.app.debug.RunnerException: Serial port 'COM5' already in use. Try quiting any programs that may be using it. <br> at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:99) <br> at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:88) <br> at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:66) <br> at processing.app.Sketch.upload(Sketch.java:1664) <br> at processing.app.Sketch.exportApplet(Sketch.java:1624) <br> at processing.app.Sketch.exportApplet(Sketch.java:1578) <br> at processing.app.Editor$DefaultExportHandler.run(Editor.java:2314) <br> at java.lang.Thread.run(Thread.java:619) <br> <br> <br>any ideas? could it be because i am using an uno instead of a duemilanov? <br>
Seems like a serial port problem: disconnect the Arduino, write down all the serial ports available (in Tools --&gt; Serial Port), reconnect the Arduino and select the Serial port that has just appeared in the list.
I got it working, thanks for the help. It was a serial port problem, I was on the right port, but my bluesmirf module wasn't at the correct baud rate. I had to switch both to 115200 for it to work. Also I get the error: <br>' avrdude: stk500_getsync(): not in sync: resp=0x00' <br> if I try to upload with the Rx Tx pins connected to my UNO. I simply uploaded then connected the module and everything worked fine. <br>Thanks for the great tutorial!
Glad I stumbled on this page before my BT module showed up for a different project, probably would have cooked it with 5 V. Thanks!
Hi, <br><br>Please help me with the bluetooth module, i want to change the baud rate and the pairing info, i used a usb to ttl adapter, connected TX, RX of USB to ttl to RX, TX of Bluetooth Module respectively and applied 3.7V to the Bluetooth module(made sure that its not in paired mode, Led flashing) - The problem i have is, as soon as i open session - hyper-terminal or putty or any com tool, the BT module is contentiously sending non stop 'Y' kind of characters <br>&quot;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&yuml;&quot;<br><br>This is what i bought off ebay : &quot;NEW Serial Bluetooth RF Transceiver Module RS232 Master + backplane 4 pin TTL&quot;<br> Item No: 110805911219<br><br>I tried going through all the google searches but no vail, please help. Thanks in advance, Khan<br>
ok im sorry i really didnt read the full thing but now its working thanks!!(im not a patient boy)by the way if ur not busy could u help me with my project ???(bluetooth <br>motion sensor car?)
About This Instructable
244,116views
242favorites
License:
Bio: My name is Jonathan Rico, I'm 18 and I live in France.I'm in my first year of an electronics degree. And, the ... More »
More by a1r:WiFi Stunt Car Nunchuk-controlled Helicopter Android RC Car
Add instructable to:
