Introduction: Make a PC Gaming Headset to Xbox 360 Adapter
Ever been playing Xbox Live with a few friends and gotten frustrated over the quality of voice being broadcast via the Xbox Headset? Or have to purchase a whole new headset ($50+) because your wires are giving out?
Have a perfectly good headset you use for PC gaming but that doesn't quite fit into your Xbox Controller?
Heres an EASY STEP-BY-STEP Instructable that will show you how you can spend under $20 (in parts) to make that nice PC gaming headset compatible with your Xbox 360 controller.
Step 1: Gather Tools
First, you'll want to make sure that you have a few handy items to complete this project. Everything we're using can be picked up at your local Radio Shack or similar Electronics parts store. You'll need: solder, a soldering iron, wire cutters, a blade of some sort, and wire strippers (if you're not able to use a blade).
Note: you'll also need a very small piece of wire you can solder on as a bridge. But more on that in a later step.
You're also going to want a safe place to solder and you may like to use gloves if you're skin is sensitive to cutting or burning...
Step 2: Go Shopping!
Unless you have these just laying around, and believe me, I know some people who do, you're going to want to purchase the items listed below. As I said in the beginning, as long as you have all the materials listed in step 1, these parts cost less than $20. The {part numbers} are the Radio Shack part numbers if you choose to go there
You'll need:
(1) 1/8" to 3/32" Adapter {PT# 274-373}
(1) 4" Stereo Headphone Cable Y-Adapter {PT# 42-2570}
(1) 2 pk Solder-Type Stereo In-Line 1/8" Phone Jack {PT# 274-274}
And that's it!
You'll need:
And that's it!
Step 3: Preparation of the Y-Adapter
Cut the existing ends off only the top to arms of the "y" adapter.
You want to get as close as possible to the jack to leave yourself plenty of wire to work with.
Remember, only cut off the top two arms of the adapter, leave the bottom piece intact.
Step 4: Start Stripping!
1) Very carefully score about 1/2" of the black insulation off the arms of the newly cut "y" adapter.
2) Using your wire stripper or some pliers, Pull off the 1/2" of black insulation you just scored to expose a bundle of foil wrapped wires.
3) Using your Xacto blade, slit open the foil shielding to expose the Black (headset), Metal (ground), and Red (microphone) wires.
Notice in Picture 2 how the colors of the wires match up with the headphone and mic jacks on your gaming headset
4) In Picture 3 you'll see that we've slipped the plastic housing from the 1/8" phone jack over the exposed wires so after we solder we can screw it all together.
Step 5: Start Choosing Sides.
Determine which side, left or right you want to be your speaker. Don't stress too much about this as you can always flip it over and left is right and right is left!
1) On side A, strip half of the exposed Red wire.
2) On side B, strip half of the exposed Black wire.
3) {here's the tricky part} On BOTH sides, thread the ground (the silver metal wires exposed w/o stripping) through the small hole at the base of the metal jack and curl it around the base.
4) On side A, connect the Red wire to one of the terminals. You DO NOT want this to touch both terminals.
5) On side B, connect the Black wire to one of the terminals. Here, we'll be adding a bridge to connect the two terminals. A bridge can be any small piece of wire you have laying around. You only want the bridge to connect the terminals, not touch the rest of the jack. (see next step)
Step 6: Ready, Set, SOLDER!
1) On Side A (red), solder your ground wire from the back where it was threaded through, all the way around.
2) On Side A (red), solder the point where the red wire connects to the terminal and snip off the remaining black wire ensuring that none of the black wire will come in contact with any of the other wires or solder.
3) On Side B (black), solder your ground wire from the back where it was threaded through all the way around.
4) On Side B (black), solder the point where the black wire connects to the terminal and snip off the remaining red wire ensuring that none of the red wire will come in contact with any of the other wires or solder.
5) On Side B (black), create a bridge out of a small piece of wire and connect both terminals together. Note, this is only done on the BLACK side. This is going to cause you to have pseudo Stereo sound as you're really diverting the mono signal to go through both sides of your head phones.
Step 7: Time to Play!
With both sides soldered as instructed, you should be able to slide up the plastic housing and screw the jack into it.
You may want to mark which side is Headphones (black) and which side is Microphone (red) so it will be easy to hook up.
Attach the 1/8" to 3/32" adapter to the bottom of the newly modified "y" adapter and plug into your controller.
If you're having trouble with interference, try hot-gluing around your solder work to isolate the connections.
You can also use this set-up to connect your gaming headset with most cell phones too as they take the same jack.
