Introduction: Make a PC Gaming Headset to Xbox 360 Adapter
Picture of Make a PC Gaming Headset to Xbox 360 Adapter
Ever been playing Xbox Live with a few friends and gotten frustrated over the quality of voice being broadcast via the Xbox Headset? Or have to purchase a whole new headset ($50+) because your wires are giving out?
Have a perfectly good headset you use for PC gaming but that doesn't quite fit into your Xbox Controller?
Heres an EASY STEP-BY-STEP Instructable that will show you how you can spend under $20 (in parts) to make that nice PC gaming headset compatible with your Xbox 360 controller.
Step 1: Gather Tools
Picture of Gather Tools
First, you'll want to make sure that you have a few handy items to complete this project. Everything we're using can be picked up at your local Radio Shack or similar Electronics parts store. You'll need: solder, a soldering iron, wire cutters, a blade of some sort, and wire strippers (if you're not able to use a blade).
Note: you'll also need a very small piece of wire you can solder on as a bridge. But more on that in a later step.
You're also going to want a safe place to solder and you may like to use gloves if you're skin is sensitive to cutting or burning...
Step 2: Go Shopping!
Picture of Go Shopping!
Unless you have these just laying around, and believe me, I know some people who do, you're going to want to purchase the items listed below. As I said in the beginning, as long as you have all the materials listed in step 1, these parts cost less than $20. The {part numbers} are the Radio Shack part numbers if you choose to go there
You'll need:
(1) 1/8" to 3/32" Adapter {PT# 274-373}
(1) 4" Stereo Headphone Cable Y-Adapter {PT# 42-2570}
(1) 2 pk Solder-Type Stereo In-Line 1/8" Phone Jack {PT# 274-274}
And that's it!
Step 3: Preparation of the Y-Adapter
Picture of Preparation of the Y-Adapter
Cut the existing ends off only the top to arms of the "y" adapter.
You want to get as close as possible to the jack to leave yourself plenty of wire to work with.
Remember, only cut off the top two arms of the adapter, leave the bottom piece intact.
Step 4: Start Stripping!
Picture of Start Stripping!
1) Very carefully score about 1/2" of the black insulation off the arms of the newly cut "y" adapter.
2) Using your wire stripper or some pliers, Pull off the 1/2" of black insulation you just scored to expose a bundle of foil wrapped wires.
3) Using your Xacto blade, slit open the foil shielding to expose the Black (headset), Metal (ground), and Red (microphone) wires.
Notice in Picture 2 how the colors of the wires match up with the headphone and mic jacks on your gaming headset
4) In Picture 3 you'll see that we've slipped the plastic housing from the 1/8" phone jack over the exposed wires so after we solder we can screw it all together.
Step 5: Start Choosing Sides.
Picture of Start Choosing Sides.
Determine which side, left or right you want to be your speaker. Don't stress too much about this as you can always flip it over and left is right and right is left!
1) On side A, strip half of the exposed Red wire.
2) On side B, strip half of the exposed Black wire.
3) {here's the tricky part} On BOTH sides, thread the ground (the silver metal wires exposed w/o stripping) through the small hole at the base of the metal jack and curl it around the base.
4) On side A, connect the Red wire to one of the terminals. You DO NOT want this to touch both terminals.
5) On side B, connect the Black wire to one of the terminals. Here, we'll be adding a bridge to connect the two terminals. A bridge can be any small piece of wire you have laying around. You only want the bridge to connect the terminals, not touch the rest of the jack. (see next step)
Step 6: Ready, Set, SOLDER!
Picture of Ready, Set, SOLDER!
1) On Side A (red), solder your ground wire from the back where it was threaded through, all the way around.
2) On Side A (red), solder the point where the red wire connects to the terminal and snip off the remaining black wire ensuring that none of the black wire will come in contact with any of the other wires or solder.
3) On Side B (black), solder your ground wire from the back where it was threaded through all the way around.
4) On Side B (black), solder the point where the black wire connects to the terminal and snip off the remaining red wire ensuring that none of the red wire will come in contact with any of the other wires or solder.
5) On Side B (black), create a bridge out of a small piece of wire and connect both terminals together. Note, this is only done on the BLACK side. This is going to cause you to have pseudo Stereo sound as you're really diverting the mono signal to go through both sides of your head phones.
Step 7: Time to Play!
Picture of Time to Play!
With both sides soldered as instructed, you should be able to slide up the plastic housing and screw the jack into it.
You may want to mark which side is Headphones (black) and which side is Microphone (red) so it will be easy to hook up.
Attach the 1/8" to 3/32" adapter to the bottom of the newly modified "y" adapter and plug into your controller.
If you're having trouble with interference, try hot-gluing around your solder work to isolate the connections.
You can also use this set-up to connect your gaming headset with most cell phones too as they take the same jack.
brank0114 (author)2014-09-16
I went to get a 1/8 to 3/32 today and they said they didn't make them anymore. What should I do?
AkhilM1 (author)2014-09-08
how does it work if its one of the jacks that has the mic built in to the audio(like the one with the 3 strips of plastic)? Is it possible?
desmondtheredx (author)2013-03-26
you are a legend
Nazgulmagefreak (author)2009-11-14
Excellent how to.
I just did two of them today.  For one I used a 3 way splitter for 1 mic and 2 headphones, so a friend can listen in on coversations.
FYI, if you use a 3 way splitter from radioshack, red is audio positive and white is for the mic positive.  The colors are different, with white instead of black and reversed.
Also, you can bridge the mic leads to both tabs with no issues.
TerryP
NGC3714 (author)Nazgulmagefreak2012-02-10
I ordered the Xbox 360 PC Headset Adapter - Use PC Headset with Xbox 360 Live, Dual 3.5mm to 2.5mm (PC35-Xbox360) from Amazon.com. It lists for $9.95. With shipping it came to $14.10. I just tested it and it works fine.
http://www.amazon.com/gp/product/B0035AMM76/ref=oh_o00_s00_i00_details
poolgirlblue (author)2011-11-27
Hey All!,
So i haven't been on here in a very long time and i'm blown away at the comments you guys have up here. They're great!
Just an update on my part, I recently started playing again Halo Reach/Anniversary and rarely MW3) and i'm still using the SAME adapter you see in the picture there. it's still going strong. I'd say that's pretty good!
I've started doing my tutorials on my blog site now (www.todayscraft.wordpress.com) and on my youtube channel (http://www.youtube.com/user/poolgirlblue?feature=mhee) and would love for you guys to take a look and let me know how I can improve.
Thanks a TON for all the inspiration and improvements! Keep Creating!
utvak315 (author)2009-07-02
this is a great idea, notto mention the only place on the net that i cout find something like this. i just finished one tha i made for my friend tonight after seeing this yesturday. although i didnt make mine with the extra adapter on the end. i just had a male to male 2.5mm cable that i cut in half and split to the two 3.5mm jacks. essentially the same thing but a little less bulk and hopefully a little less dangerous to use during more vigorous gaming. definately glad someone posted about this. great job
lynchy4664 (author)utvak3152009-07-14
you can buy ready made 3.5 female to 2.5 male adapters ready made for 7.00 yours come to 17.00 very good tut you gave me an idea so ty
moetdod (author)lynchy46642009-07-15
Thanks for the link to Triangle Cables plus they are on sale for $3 + s/h. Think that this will work with the Plantronics Audio 370 pc headsets that I bought on Woot for $5.99 to use with Xbox 360
poolgirlblue (author)moetdod2011-11-27
well, i'm replying to this very, very late. As I'm sure you've already found out, the cables you linked in above only split audio out. They won't work for Mic in. Correct me if i'm wrong though since i haven't actually tried that.
tinyaelito (author)2011-11-21
Great tutorial, though I have some improvements on the budget side… even though you do require a little bit more experience on soldering and peeling cables:
See you don’t actually need to buy the in line phone jack… you just need to:
1. - peel the cable of the Y adapter instead of cutting it (preferably in the middle).
2. - then when you see the 3 cables (red, black, peeled) you just cut the red cable on side A and the black cable on side B.
3. - then peel the little black cable on side A and solder the red cable coming from the female jack (being careful not to solder the ground, and this is why you need more experience).
4. - then isolate the wires so no short circuits are left. And you are done ;)
WORKED FOR ME NO PROBLEMS OR STATIC ;)
Evilgoose (author)2011-09-24
Hi there I'd first like to thank you for the tutorial it's easy to follow. There's only one problem I've come across which is my mic not working. I've boiled this down to 2 things: 1) My 3.5 to 2.5 is slightly different and might be the reason. It has 3 grooves in the male connection instead of the 2 shown in the picture. 2) I messed up the soldering on the mic connection. When I was doing it my hands became shaky and I got some of the plastic from the black sleeve mixed in the solder so I may have to clean it out. Any input on what I should try to fix first would be nice.
bgallagher4 (author)2011-08-08
Ok idk what i did wrong but my mic works perfectly and im getting no sound. The headphone side looks just like yours but ive got no sound. And the red wire isnt interfering because ive got it covered with electrical tape. Any ideas????
achauvin1 (author)2011-06-22
There's a part that already does what this does and it's cheaper than buying all those parts from radio shack and making it yourself...
http://www.theheadsetbuddy.com/Xbox-360-Headset-Adapter-PC-Headset-to-Xbox-360-Controller-01-PC35-XBOX360.htm
But a nice instructable nonethless.
Cobalt59 (author)2011-04-30
Check out my wicked profile in ROBLOX, a fun creative hangout
nk dtk (author)2010-11-04
on this picture, is the black wire on the left and the red wireon the right cut down and un used?
thanks
~alex
poolgirlblue (author)nk dtk2011-01-09
correct. one side is mic, the other is audio. you isolate one on each side so that you can plug in the mic(red) and the headphones(black).
dredfu (author)2010-11-05
Alright so Im interested in doing this. But i only want to use a mic. I bought an adapter and when my mic is plugged in it doesnt work. Any suggestions? its a stereo adapter, do i need a mono one? Thanks.
reakmcfly01 (author)2010-11-05
ok i can hear everything i just can't talk back. anyone else have this problem.
viwizard (author)2010-10-22
Thanks to poolgirlblue for this article. Not having done any electrical stuff for years, this inspired me to have a go.
In the UK it is not so easy to get a "headset buddy" as the US websites have. So I had a go at building a 4-pole 3.5 jack spliter with success.
I have full stereo, and by building a test piece for a 3-pole jack I was able to test the connections though my Nokia mic attachment and identify which pole uses the mic & phones.
I ruined 2 4-pole jacks in the process but the learning experience was invaluable.
Thanks again.
Kurious Kat (author)2010-08-11
What we all want here, I think, is game audio and chat through the same headphones using a standard PC headset - you know, the ones with mint green for headphones and pink for mic.
The SteelSeries adapter works for this, except that it costs $15. All you really need are two pieces: a 2.5mm male to 3.5mm adapter and a 3.5mm extension for your headphones (mint green).
The cheapest solution I've found for these is http://www.xjacker.com or http://www.amazon.com/XBOX-360-Headset-Adapter-PC-through/dp/B003Y8GL94/ref=sr_1_1?ie=UTF8&s=videogames&qid=1281557387&sr=8-1.
For $7, I am using my Sennheiser PC350s on my XBOX 360 and it works like a charm. Saved me a bundle having to buy a separate XBOX headset - like most ppl, I'd rather spend my cash on games.
zuraine (author)2010-06-05
My splitter that i bought from radio shack didn't have silver ground wire, it only had red, yellow, and black, wires. I stripped them accordingly and used the Yellow as the ground wire because i assumed that it was the only other thing in there that could be it. But upon trying to use the adapter, I could barely hear the Chat. could this be because the type of wire i used as a bridge? I used a pretty stiff piece of metal from a wire. and The mic isn't working. Any suggestions?
geeklund (author)2010-03-21
I built myself a splitter like this some time ago, one thing that struck me is that I'm able to hear the chat in my headphones but when I connect directly to my mixer (to mix the chat with the game-sound) i get no sound at all, any ideas? Does the controller somehow sense that headphones are connected and only enable sound output then?
s3kShUn7 (author)2010-03-03
 Hey, I have a question. Actually, first I have a statement. Very good tutorial. I really appreciate this. Second: I have headphones with an inline microphone, much like the ones offered for the new iphone. So, it all goes into one jack, much like the adapter you showed here without the actual adaptor. But, when I bought the 3/32 adapter, it didn't work. I could hear people, but they couldn't hear me. Why is this? Even if you don't know, would it be wort it to try this solution. (I already have the Y-Adapter). I mean, I would only loose $4. Let me know. Thanks in advance.
exmafioso (author)2010-02-17
Great write up! it got my wheels turning on possible options. Has Anyone tried to modify their existing xbox 360 headset connector, so they have the factory connector with a Mute button?
newb09 (author)2010-01-23
This was so simple, I thank you for putting this up.  Wasted around 12 dollars for everything to work correctly :). Thank you.
Bowjangles (author)2010-01-17
the function is the same as the microsoft ones, just it is far more comfortable.
walabulu4 (author)2010-01-14
nice i should try this
daiglebw (author)2009-11-30
If you don't want to make your own (or can't see the pictures), here is another If you need a PC headset to XBox 360 adapter
Bryan
DCRD (author)daiglebw2010-01-05
I was looking at that one on amazon but I wasn't convinced that it worked with the 360. Do you have this one and know that it works good? thanks.
poolgirlblue (author)DCRD2010-01-12
after both of you put the same headset connector up, i was curious, so i bought two. one of them was broken upon receiving it. the other has pretty bad static on the head set side. They were much cheaper than mine are to make, but, my end verdict is that you get what you pay for.
daiglebw (author)poolgirlblue2010-01-12
 They have a 1 year warranty and good replacement policy, have you tried contacting them for a replacement?
poolgirlblue (author)daiglebw2010-01-13
as little as they cost to purchase, they're not worth my time since i already have my own working versions.
it is great though that someone has not only been able to produce it on a mass scale, but provides a warranty as well. for those of you not interested in making your own, it's a very good option.
daiglebw (author)DCRD2010-01-05
 Yes, it works with xbox 360 since the xbox 360 uses the same kind of 2.5mm jack as phones.
Thanks!
Bryan
christian24 (author)2010-01-13
I have a question, Why do we need that third piece that we solder on? Can't we just connect the y-adapter to the 2.5 to 3.5 converter and connect our headset to the y adapter?
poolgirlblue (author)christian242010-01-13
the third part, steps 5 and 6, are are what allow you to seperate out the Y adapter into the mic and headset portions.
you  have to isolate each side so that you can actually use it.
ChosenWon (author)2009-09-30
As great as all this sounds....it is really confusing! Am I the only one? Probably. :( the pictures are helpful but the components are so small it is to hard to see what I am looking at for connections. Some kind of wiring diagram would be extremly helpful if you had a minute to draw one up.
thebigstro (author)ChosenWon2010-01-11
Check this out too. http://www.amazon.com/gp/offer-listing/B002D41HKS/ref=dp_olp_0?ie=UTF8&condition=all
Wolf in command (author)2008-11-07
Awsome. Just what I need
it's so much more comfortable than the ones that microsoft makes becuase you can find whatever style headset you like and you're not limited to one or two choices.
mangumboy77 (author)poolgirlblue2009-11-11
Thanks for the info, I just bought 2 of these tho
http://www.steelseries.com/us/products/accessories/xbox_360_headset_connector/information
hopefully they will work out.
AlexPeegs (author)mangumboy772009-12-16
 are these working better than microsoft's one or the same or better?
jknorr99 (author)2009-11-18
 Is it possible to do this with a USB PC headset?  I have a Plantronics GameCon USB headset that I'd like to use on my 360, but am not sure if that can convert.
Any ideas?
sudochuckwalla (author)2009-11-05
How much different would this be if one wanted to simply convert a mic, not the headphones and the mic, for use with the xbox?
DannyHR (author)2009-07-14
Thank you very much for this, will try it ASAP!
atedioussheep (author)2009-05-28
Great Instructable! I've got a broken xbox headset at home, so I'm going to combine that and this project. Hope it turns out well.
benoheno (author)2009-05-26
I think the white is earth, Red = microphone and Blue headset?
send me a email at sail_spiky@hotmail.com as im rarely on here
Hi, i love ur idea and im in the process of actually making one!! I live in Hk and i got the parts but in my Y adapter the wires are Red, Blue and white. Which is which??
About This Instructable
319,813views
63favorites
License:
More by poolgirlblue:Make a PC Gaming Headset to Xbox 360 Adapter
Add instructable to:
