3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a PC Gaming Headset to Xbox 360 Adapter
Step 6Ready, Set, SOLDER!
Ready, Set, SOLDER!
1) On Side A (red), solder your ground wire from the back where it was threaded through, all the way around.
2) On Side A (red), solder the point where the red wire connects to the terminal and snip off the remaining black wire ensuring that none of the black wire will come in contact with any of the other wires or solder.
3) On Side B (black), solder your ground wire from the back where it was threaded through all the way around.
4) On Side B (black), solder the point where the black wire connects to the terminal and snip off the remaining red wire ensuring that none of the red wire will come in contact with any of the other wires or solder.
5) On Side B (black), create a bridge out of a small piece of wire and connect both terminals together. Note, this is only done on the BLACK side. This is going to cause you to have pseudo Stereo sound as you're really diverting the mono signal to go through both sides of your head phones.
2 comments
Nov 4, 2010. 10:09 PMnk dtk says:
on this picture, is the black wire on the left and the red wireon the right cut down and un used?
thanks
~alex
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:poolgirlblue
