Things you need
Laptop
CROSSOVER Ethernet cable (You can't use the one included with the xbox. But chances are that you have one lying around. Most will be labeled saying crossover. Thanks to sk8erek who reminded me to edit this.
Xbox
I Edited this to show how to do it with Vista and Mac, so this will work for all 3. The one done by me is for Windows XP. Step 4 is Windows Vista. Step 5 is Mac OSX, both Leopard and Tiger
P.S.- This is new information. I just edited this on January 3, 2008. If you do this, you won't be able to connect to the internet through your Ethernet port anymore. Only providing internet will be possible. If you want to know how to fix this, scroll down to my comment about it.
EDIT: A fix for the above problem was posted in a comment by timheppner. I have not tried this myself, but he says it will work, so try it out.
"EDIT 2:" A guy named bsblade told me that my instructions on doing this on a mac were wrong, so I updated it according to his instuctable. To see changes, check out step 5
Step 1: Connect Your Ethernet Cable to Your Computer and Xbox
Step 2: Change Your Internet Properties
Step 3: Repair the Ethernet Connection
Pictures say it all.
Right click the non blurred icon. Then hit repair. It shouldn't have a red X though.
Step 5: For Mac Users
What you'll need
You don't really need much to do this. All you need is: A Mac (this guide is for 10.4 but im sure it would be very similar on 10.5) And XBOX 360 (duh) A wireless ne&
step 2
To begin
1. Open up system preferences and go to Network. 2. Make sure location is set to "Automatic" and show is set to "Built-in Ethernet." 3. Now where is says "Configure IPv4,&
step 3
Now
Your router should have an IP Address, and it is usually 192.168.1.1, check on the bottom of the router to make sure. There should also be a username and password down the&
step 4
Back to System Preferences
1. Go back to System Preferences now and click on "Sharing." 2. Click on the "Internet" tab. 3. Make sure that on the drop down menu Airport is selected. 4. Click on the&
step 5
Now on your XBOX
1. Go to the "System" blade on your dashboard. 2. Go down to "Network Settings." 3. Now select "Edit Settings." 4. Select your IP settings and choose "Manual." 5. Now e&
step 6
Congratulations
Congrats. You are now connected to XBOX Live without having to have bought one of those ridiculously expensive wireless adapters. Have Fun!
Thanks to bsblade for his instructable. To see the whole instuctable, go to http://www.instructables.com/id/Use-your-Mac-OSX-as-a-Wirelss-Adapter-for-you-XBOX/
Visit Our Store »
Go Pro Today »
I am running Vista
To use the existing cable with XP:
1. Click START > SETTINGS > NETWORK SETTINGS.
2. Click SET UP A HOME OR SMALL OFFICE NETWORK.
3. Make sure all necessary adapters and/or cables are attached.
4. Click NEXT twice. If something isn't connected, you'll get a CONNECTIONS screen. You can click IGNORE DISCONNECTED NETWORK HARDWARE for the time being and then click NEXT to continue.
5. Click THIS COMPUTER CONNECTS DIRECTLY TO THE INTERNET... and click NEXT.
6. Click your INTERNET CONNECTION and click NEXT.
7. Click your PRIVATE CONNECTION and click NEXT.
8. Click NEXT 4 more times. Note, that you may edit pieces before the final click of NEXT, but this comment isn't in response to those details. Also, this part may take a moment to finalize.
9. Once that is finished, REBOOT your system. You MUST do this step or it will not work.
10. Once your system reboots, wait for it to connect to the internet. Make sure your Xbox 360 is connected to your computer BEFORE you turn the system on.
11. If everything went smoothly, you will connect to Xbox Live whenever you load a Xbox Live profile.
A few notes:
1. If you get kicked offline due to internet issues, you have to renew the connection to your PC to connect back to Xbox Live.
2. If your computer enters HIBERNATION and/or SLEEP mode, the connection will sever.
3. If your computer is REBOOTED and/or SHUTDOWN, the connection will sever.
4. Your computer must ALWAYS be online first.
5. If your console won't connect, you must manually set your DNS and IP ADDRESS settings on your WIRED CONNECTION. Do NOT use your DNS ADDRESS for your router, or it will prevent connection to the internet at some point. I typically use 192.168.0.1 for my internet's DNS ADDRESS and 10.0.0.1 for my Xbox 360's DNS ADDRESS. The IP ADDRESS shouldn't have to be modified.
6. Your FIREWALL can either be on or off. It does not matter. This has been tested with WINDOWS FIREWALL, PC TOOLS FIREWALL, and COMMODO FIREWALL.
PS: Not trying to steal your thunder. Just trying to offer some extra tips, as I have done this before.
Thanksss!!!
go to start and type in "view network connections" click on it
After that you should have local area connection and wireless network connection
Highlight them both and right click one of them and there will be something called bridge connections click on it "make sure everything is enabled in network connections"
and then try the network setup on both ps3/xbox :DDDDDD
"Your network does not have a sufficient MTU setting. Xbox LIVE requires a minimum MTU setting of 1364."
I looked it up and found out that I need to open some ports. So after checking the two boxes on the "Sharing" tab of Vista/7, I clicked on the "Settings" button and checked/added the following ports:
Port 88 (UDP)
Port 3074 (UDP and TCP)
Port 53 (UDP and TCP)
Port 80 (TCP)
For the ports that list both UDP and TCP, I added the port twice, making sure one was for TCP and one was for UDP (adding UDP to the end of that port name to differentiate between the two). Port 80 was covered under "Web Server (HTTP)" so I didn't have to add that one individually.
After making sure these ports were added and checked, I was able to connect to XBox Live with no problems.
Um where it says above the 2 edits, about fixing the internet from not being able to use it anymore, which then goes onto say see walmoonbeems comment about it; could someone leave me a link or page number or inbox me please.
Greatly appreciated.
