Use your laptop as an Xbox/Xbox 360 "Wireless Adapter" on Windows XP/Vista, and Mac OSX
Step 2Change Your Internet Properties
We have to change the internet properties so that your computer will share wireless internet with the Ethernet adapter. See pictures. They are in order as they should. They also have notes. After doing what all the pictures say, hit ok.
109 comments
1-40 of 109next »
Dec 23, 2011. 4:16 PMxboxlive12 says:
i have a LG computer what steps do i have to do?
Oct 9, 2011. 1:54 PMmjohnston10 says:
ok my problem is i dont have a sharing tab so what am i supposed to do now im running on windows 7 on a dell mini help plz
Oct 11, 2011. 5:58 PMrobijussin says:
when you are in the "network and internet" window of your control panel, there should be a category labeled "network and sharing center." click on that, then to the left there should be an option, "change adapter settings." In there you want to bridge your wireless and local area connections. This should allow you to access xbox live. Did for me at least.
Nov 13, 2011. 2:11 AMKings_Fool says:
Thaaanks. That worked for me very well.
Aug 2, 2011. 1:38 PMMicah667 says:
xbox says it cant obtain IP address
Jun 30, 2011. 6:58 PMETXElectronix says:
@macauleyw34 : On WIndows Vista or Windows Se7en, go to your Control Panel>Category View>Network and Internet>Manage Internet Connections (or Manage Wireless Networks)>Adapter Properties>"Sharing" tab
Jul 5, 2011. 8:10 PMblewis8 says:
Thank you!
Jan 26, 2011. 1:02 PMmacauleyw34 says:
does anyone knw how to do that step on vista basic coze i cnt find it
Dec 19, 2010. 11:09 PMeirmanz says:
Internet connection sharing cannot be enabled A LAN connection is already configured with the IP address that is required for automatic IP adressing
Oct 1, 2010. 2:41 PMGerman Jake says:
Step 2 isnt working for me when i click ok an error message comes up and says "Internet connection sharing cannot be enabled. A LAN connection is already configured with the IP address that is required for automatic IP addressing." If you know how to fix this please tell me. Im using windows xp.
Dec 19, 2010. 10:59 PMeirmanz says:
same here
Feb 13, 2010. 1:01 PMjcarlsoniv says:
 I have looked through most of these comments and solutions and I can still not solve this problem.  When I was home, my brother set my computer to allow the sharing of devices so that I could use my xbox wirelessly.  However, now that I am at school, and I do not have a wireless connection in my dorm, my computer will not connect through the ethernet port to the internet.  My laptop does just fine, but my desktop will not.  I am using Vista, and when I go to the wireless network's status, there is no "Sharing" tab, and thus, no check box to uncheck.  This is really frustrating me and making me hate Vista even more than I already do.  Hopefully I'll have Windows 7 soon.
Aug 30, 2010. 7:21 PMAzuraith says:
scratch what i just said the limited or no connectivity is now gone i fixed it, but still cannot connect...
Aug 30, 2010. 7:19 PMAzuraith says:
hey im having some problems connecting my laptop to my xbox. ive done every thats been said including what was in your comment, but still cannont connect my local area conection says it has limited or no connectivity after i changed the tcp/ip properties.... help?? plz
Apr 11, 2010. 4:31 PMKoenigg says:
I have the same exact problem, but i still have xp pro. and the only options under the advanced tab is firewall settings no (internet connection sharing)
Jul 9, 2010. 11:57 AMyumchikinstrips says:
what you do is you go through the setup wizard again and make sure you check the box that say use this computer as a gateway. I had the same problem but it is now fixed
Apr 11, 2010. 10:00 PMjcarlsoniv says:
 I eventually got my computer working.  Turns out, I had to update the ethernet port driver.  However, in order to do that, I had to lug my entire computer over to the student union (where there is wireless) so I could download the driver.  Took me about 2 hours worth of trouble shooting once I had the wireless internet to actually get it working though.
Aug 15, 2010. 11:46 AMchaosbrae says:
there is no "advanced" options on mine. just connection and security. im using vista
Aug 17, 2010. 4:17 PMFartybarty123 says:
On vista under properties in the network settings you have to find the button that says allow other network users to connect via this computers Internet acess click ok and connect your xbox on test connection. I hope this helped (I am not the person who wrote the article but did it today took a while but did it in the end)
Aug 4, 2010. 8:10 PMtofood says:
In the advanced tab for my wireless network connection's properties, I do not have the option to allow other network users to connect through this computer's internet. In fact, the whole box below the "Windows Firewall" box isn't even there. I'm on XP and I am the administrator on my computer. Also, does anybody have any idea how to use this concept with my laptop to my desktop? The router on my desktop broke, and it'd be nice if I could use my laptop instead of
Jul 23, 2010. 8:58 AMspartangzz says:
this is vista i own windows 7
May 10, 2010. 7:30 PMJojomojo19 says:
 Anyone with windows 7, this is how you do it.
Right click on the internet connection tab on the bottom right corner and click "open network and sharing center". On the left side of that window, "click change adapter settings". Left click and hold it to highlight "Local area connection", and the wireless connection you are connected to, and let go. Then right click on the selection and press "Bridge connections". Then just connect your xbox to your laptop via ethernet cable, and test your connection through your xbox. Obviously, make sure you're connected on your laptop to the internet.
Jun 28, 2010. 11:15 AMCyanmonke says:
This worked amazingly. Thank you so much for this information, I tried bridging and it worked!!! I love you man omggg lmao <333333
Jun 27, 2010. 10:24 PMjhamre says:
My problem is this: When I try to bridge the connections between my 360 and my laptop (with Windows 7 Professional), an error message pops up that reads: "To create a Network Bridge, you must select at least two LAN or High-Speed Internet connections that are not being used by Internet Connection Sharing." Any hints as to what I'm doing wrong?
Feb 28, 2010. 8:03 AMtomclark10 says:
It wont let me bridge connections and when i check the share box it says error! what can i do?? help please!
Mar 31, 2010. 11:04 PMone hd says:
all you have to do is left click on the wireless connection then go into properties and tick the bottom box and it should now work.
Mar 31, 2010. 11:19 AMdjkleyweg says:
Dude im stuck and lost im trying to use it with my dell inspiron mini and i keep getting an error when i click join them could some one please help me out?
Sep 19, 2009. 10:42 PMMaster_Keith says:
For people having trouble doing this with Vista: This step actually didn't work for me. I fiddled with it for at least an hour and couldn't get it to work. In the end, I didn't do this step. I did not select the "Allow other users to connect through this computers internet connection" option.but instead bridged my local connection (the xbox and laptop) to my wireless connection (laptop and wireless router) and it worked.
Feb 22, 2010. 6:04 PMjonram28 says:
ok i got a question .. so im at this step with vista and it says the error thing so what do i do now the only connection i got is the one that i have to turn the sharing on so do i try and bridge anyways??plz help
Dec 16, 2009. 2:47 PMjman11927 says:
thanks a ton for the instructable. worked great and i am running windows 7 ultimate
Jan 28, 2010. 9:49 PMxBeg4mercy says:
Hey im running Windows 7 Home. I'm kind of lost with these intructions haha can you help me out please? since your using windows 7 also.
Jan 29, 2010. 9:11 PMjman11927 says:
Yeah what part are you lost with?
Jan 15, 2010. 9:45 PMjonathan23 says:
i cant find the internet connection sharing page somebody help me
Jan 11, 2010. 12:49 PMjjkoolj8282 says:
i cant find the share wireless network thing or whatever
Jan 10, 2010. 7:25 AMceath says:
 thanks worked first time no problems
Mar 21, 2009. 12:32 AMfoteye says:
having an issue. Please help very soon. I'm getting an error when i try to share the connection. The error states: "An error occurred while internet connection sharing was enabled ICS cannot be enabled. A LAN connection is already configured with the IP adress that is required for automatic IP adressing."
Dec 24, 2009. 2:32 AMGroovyG0D says:
Its been a long time since you posted this comment for help, so I am assuming that you might have found a answer to your problem. I am also having this problem happen to me so if you have an answer please forward it on to me. Thank you.
Jul 14, 2009. 3:22 PMmager_overload says:
getting the same error
1-40 of 109next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:walamoonbeam
