Use your laptop as an Xbox/Xbox 360 "Wireless Adapter" on Windows XP/Vista, and Mac OSX
Step 3Repair the Ethernet Connection
This is simple. Right click the Ethernet Cable icon in the task bar, and hit "Repair"
Pictures say it all.
Right click the non blurred icon. Then hit repair. It shouldn't have a red X though.
87 comments
1-40 of 87next »
Aug 21, 2011. 9:21 PMcstill says:
This worked for my bluray player!
Thanksss!!!
Aug 2, 2011. 2:05 PMMicah667 says:
ok it repaird an everything but it still wont connect to network..
Jun 9, 2011. 5:25 PMwoodmass14 says:
i only know how to do this on windows 7 and vista plug usb from laptop into xbox/ps3 Make sure Xbox/ps3 settings are for ethernet only :D
go to start and type in "view network connections" click on it
After that you should have local area connection and wireless network connection
Highlight them both and right click one of them and there will be something called bridge connections click on it "make sure everything is enabled in network connections"
and then try the network setup on both ps3/xbox :DDDDDD
Jun 27, 2011. 6:34 PMnickhines910 says:
thank youuu
May 17, 2011. 2:55 PMphantomjunkie says:
Following this instructable gave me the following message on the XBox360 when I tried to test the connection to XBox Live:
"Your network does not have a sufficient MTU setting. Xbox LIVE requires a minimum MTU setting of 1364."
I looked it up and found out that I need to open some ports. So after checking the two boxes on the "Sharing" tab of Vista/7, I clicked on the "Settings" button and checked/added the following ports:
Port 88 (UDP)
Port 3074 (UDP and TCP)
Port 53 (UDP and TCP)
Port 80 (TCP)
For the ports that list both UDP and TCP, I added the port twice, making sure one was for TCP and one was for UDP (adding UDP to the end of that port name to differentiate between the two). Port 80 was covered under "Web Server (HTTP)" so I didn't have to add that one individually.
After making sure these ports were added and checked, I was able to connect to XBox Live with no problems.
Mar 2, 2011. 2:24 AMlbagg says:
can anyone help me i have vista and when i right click the wireless network then click properties there is no sharing tab so i have no option. can anyone help me with this?
Dec 31, 2010. 9:21 PMchukyx007 says:
if you want to renew our ip address just right click the internet connection and hit repair.
Dec 18, 2010. 8:27 AMStorm Smurf says:
After I checkmark the "Allow other users to connect through this computers internet connection" and press okay, I get this message:
Internet connection sharing cannot be enabled
A LAN connection is already configured with the IP address that is required for automatic IP adressing
I'm running an ad-hoc connection and using another laptop instead of a router right now. Do you have any suggestions for me?
Oct 13, 2010. 8:56 PMkdeedeedee says:
I did it all, and on the Xbox, i just get
Cant obtain ip from modem/router.
Help?
Apr 24, 2010. 7:45 PMsmithaustin2009 says:
Anybody know how to repair the connection on windows 7? I don't have that icon.
Aug 14, 2010. 11:31 PMKopolis777 says:
Sorry, right click the taskbar and click properties then do as my other comment said.
Aug 14, 2010. 11:30 PMKopolis777 says:
Right click the task bar and there should be a check box in one of the tabs. Then right click the icon and click Diagnose and Repair.
Dec 12, 2010. 11:36 AMfuzzy04 says:
Hey I couldn't find that icon at all do you know where else it would be?
Jul 13, 2010. 10:00 AMTheUFear says:
Same here mate but probably that isn't even "X"d cuz its pretty new but still am not sure and i need an answear for that too.
Apr 29, 2010. 4:05 PMTheAntiHeroHimself says:
would any crossover cable work? Like this one, by example?
http://www.amazon.com/Category-Shielded-Hospital-CROSSOVER-Ethernet/dp/B002M57U9K/ref=sr_1_3?ie=UTF8&s=automotive&qid=1272581137&sr=8-3
If so, where can i purchase one?
Mar 22, 2010. 12:09 PMbr0thers1narms says:
every step works exceot from step 3 it doesnt let me repair my ethernet connetion ?
Feb 18, 2010. 8:09 PMmiaboy001 says:
is this step for windows xp 2
Jan 4, 2010. 10:20 AMTidusx3 says:
Refresher for Vista Users!!!!
I just fiddled with this and it WORKS!
1. Plug Crossover from Xbox to Laptop (Make sure Xbox is OFF)
2. Hit Start > Type Run in the Search Bar.
3. Brings up a little window, Type " ncpa.cpl " into that window. Run
4. Brings up Network Connections.
5. Right-Click your Wireless Connection > Properties > Sharing tab
6. Click "Allow other network users to connect through this computer's Internet connection" > OK
7. You probably don't have to, but Repair for giggles.
8. Turn on your Xbox.
Jan 13, 2010. 9:59 AMfredfa says:
basically i have wireless laptop a normal ethernet cable and xbox 360. after reading many blogs including this one i realised i could potentially play xbox live on it using my laptop etc. After literally hours of testing and trying different ways of doing things im left with 2 bad things and never able to actually access xbox live. first time i would go to manage network connections and then my wireless network connection right click properties then sharing. i would then check both boxes allow it to identify and then test xbox live connection. it would be succesful until it reaches xbox live where i am to recieve i message saying test failed.. "your console is connected to the internet but can't connect to xbox live, your router or ISP may be blocking access to xbox live" so now i am to try and bridge the connections.. in order for vista to let me bridge i must go and uncheck the boxes i have just checked in the sharing section. so now i bridge the connection and all seems succesful until i try again to test xbox live. and this time i cant even get onto the internet! I have taken off every firewall. can someone please help me? do i need a crossover cable? or am i just doing things wrong. neither the bridgeing or checking the 'allow other users to connect throught this computers internet connection' seem to work! HELP PLEASE!!! thanks
Jan 8, 2010. 3:16 PManimal0307 says:
Kudos Man. Took my 360 longer to boot up then it do make the changes.
Apr 4, 2010. 12:09 PMstatefan858 says:
same here
Jan 7, 2010. 4:43 PMsamysamyking says:
Thanks so much for the guide. You just saved me 50 bucks.
Jan 2, 2010. 3:06 PMprdk21 says:
okay so i did all the steps and it doesnt work...i plugged the crossover cord to my laptop, and checked the box that says "allow other network users to connect through your computer" and then my wireless went out...i clicked repair and it didnt work...
Dec 26, 2009. 6:34 PMMW2 madness says:
 onemore thing first step u say plug it into your computer :S do you mean your laptop
Jun 28, 2009. 11:00 AMpablopenguin24 says:
what do you do if there is still a red x?
Dec 26, 2009. 6:36 PMMW2 madness says:
 repair it
Dec 26, 2009. 2:33 PMMW2 madness says:
 sounds preety good im going to buy a ethernet cable tomorow and hopefully is going to work does this prevent Laggs and stuff for example on MW2
Dec 26, 2009. 10:35 AMgecco9327 says:
so....after i do step two...i check the box that says "allow other network users to connect blah blah"  and so after i check that, the icon with the two computers and the red x dissapears....and my xbox still cant find my laptop...what did i do wrong? what am i supposed to do?
please respond!
Dec 25, 2009. 5:52 PMGmodvids says:
 Its says:
Network Could not be connected
The device hooked up is not responding
i think it says something like that
PLZ HELP!
Dec 15, 2009. 5:10 PMJewlox says:
Hey man i was wondering if you could help me out
A LAN connection is already configured with the IP adress that is required for automatic IP adressing
If this thread isnt dead id love a response
Dec 5, 2009. 8:45 PMjosenetwork says:
my laptop says i have a Local Area Connection. are the I adresses on the 360 and laptop supposed to match?
Oct 30, 2009. 8:24 AMbuddahz says:
yoooooo thanks alot, and i mean alot for this walamoonbeam...its been so long that i have not been online, it feels great to speak and conversate with my people..thanks again, this was real informative..God bless bro..
Aug 8, 2009. 9:50 AMloco22cba says:
i have a problem, the ehternet cable icon appears with a caution sign, not the red X but a caution sign.. when i click repair it tells me that it "cannot refresh the ip".. PLEASE HELP
Aug 8, 2009. 1:19 PMcoolroho says:
same here but mine says between internet and xbox live
Jul 16, 2009. 9:07 AMBabyjb says:
Hi, i passed all the internet connections but when it is updating it says error!! i tried everything but nothing seems to work, what am i doing wrong?
Jul 8, 2009. 10:02 PMjosshhyy says:
now it wont connect the ip address what is going wrong
Jul 8, 2009. 9:49 PMjosshhyy says:
when ever it tries to connect to xbox live it fails any ideas why???
1-40 of 87next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:walamoonbeam
