3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Used Tired Raised Garden & Tree Ring
Ever wonder what to do with those old tires? Do you want to have a garden without the need to till soil? We have found that used tires make GREAT raised garden beds!
Caution!
Please note that we are using some serious saws to cut the tire. It's important that you are familiar with and comfortable using power tools to make these projects. While the cuts are not difficult, the tires do have steel wires in the sidewall that can be resistant to sawing initially. BE CAREFUL AND WATCH WHERE YOU PLACE YOUR HANDS/FINGERS!
Step 1MATERIALS:
- Used tires:
We saved our tires when we replaced them. This actually saved us the cost of the disposal fee! We also asked a couple of friends to save their tires for us as well since we knew we'd need several for various gardens.
- Sharp Knife:
You will want to use a sharp knife but not one that would bother you if it's used in your garden.
- Jig Saw:
This saw is used to cut the side off the tire.
- Dual Saw:
This is the saw we used to cut a slit in the side of the tire. It cuts through the steel bands easily. Again, BE CAREFUL!
- Landscape Fabric:
You could also use several layers of newspaper to create a weed/grass block.
- Garden Soil:
You can purchase garden soil, compost material, or find a friend/acquaintance who needs to have soil hauled away.
42 comments
1-40 of 42next »
Dec 5, 2011. 5:31 PMMerriWinter says:
I like the idea of using newspaper in the bottom of the tyre - thanks. I have used tyres in my garden for the last year or so mainly because I have had a large area of new bed to 'better'. The soil is a heavy clay that need loads of compost and since we live on the slopes of a river, carting kitchen waste to the official compost site it just too labour intensive. So.... I have planted some tyres in my bed and use them as compost sites until they have served their purpose and are then moved to another site. BTW, I used a small bladed kitchen knife to cut the rims off. It works pretty well but only if you keep a tin of water near by and keep dipping it into the water - no electric saw needed.
Oct 12, 2010. 4:46 AMtim_n says:
Just looking at putting in some fruit trees - looks like a great idea even though I'm not mowing, it'll stop the climbers from so easily getting a hold
Thanks!
May 28, 2010. 6:11 AMkirnex says:
 An awesome idea for an easy raised bed!  Thanks for sharing it!
Can I just offer an idea with regard for it?  If you could, you might want to consider lining your planter with a layer of cement/concrete, even hypertufa or ferrocement.  I know it sounds strange, but I mention this for a couple of reasons:
1) Rubber (especially tire rubber) contains chemicals which will most assuredly break down more quickly with such constant, unlimited exposure to the sun and elements.  Those chemicals will, in turn, be absorbed by your plants.  Not only can it impact the health of your plants, but especially if you are growing edibles in this environment you would not want to ingest plant matter which has been grown this way. The cement/concrete or other similar
matter offers a layer of protection against this.
2)  Concrete, cement, hypertufa and ferrocement (the latter two of which are created utilizing cement) contain lime, which will naturally (with exposure to water) leech at a minimal rate into the soil and provide a natural source of lime to your plants.  This is especially beneficial if you are growing plants which prefer a base environment.  If you want to grow plants which prefer an acidic environment, you would simply use a liberal amount of peat moss in your soil mixture (I'd use as much as possible--even a ratio of 3 parts peat to 1 part soil or compost would be fabulous).
Hope this gives prospective tire-gardeners something to consider.  I am absolutely all for repurposing items in any way you can, it's always good to consider the long-term effects of such a practice on not only the environment, but also your own health.
Apr 6, 2010. 10:05 AMorigamifox says:
You don't say anything about what to do with the sidewall once you have removed it.  I have found that you can invert the sidewall and place inside the tire, over your landscape cloth.  This will help hold the landscape cloth in place inside the tire.
Mar 19, 2010. 5:30 AMappieh58 says:
I think that I will give it a try....
I have seen this before, but with very large tires only, without removing the sidewall.
Thank you for sharing this great gardening information
Grtz Albert
HomeAndGarden
Mar 14, 2010. 7:50 PMyodaandmoody says:
This is a great idea I needed a raised garden and using tires we already have for it worked out super of course I did put my own spin on this idea.Thank you for sharing. I love being able to recycle and have fresh vegtables, herbs and flowers .I have one area done and working on another when I am finished I will have 10 raised bed gardens from your original idea. Thank you. Bonnie
Jun 22, 2009. 2:46 PMunderwhelmed says:
Jun 25, 2009. 7:27 AMserpensphile says:
Yes...go read the article like Undershelmed suggests, then go read the comments below the MotherEarth article.
Jul 1, 2009. 4:33 AMserpensphile says:
LOL! If you read the comments directly below that specific MotherEarth article, they tear it to shreds! There is no data that shows that tires leach or produce toxins that are going to destroy the environment. This just shows you how many lemmings are jumping off the "green" cliff. Many more to follow too I'm afraid! What has happened to people actually THINKING instead of taking everything they hear second and third hand as FACT?
Nov 15, 2009. 5:42 AMunderwhelmed says:
Actually, I was searching for an article published years ago on using tires for this exact purpose, and found that it was not in the archives.
The fact that some flak who is in the tire industry posted a conflicting comment is not proof enough for me that using old tire for food production is safe. I am not a "green" person, but I see no reason to poison myself or others just to be contrary.
Just because the tire manufacturers are now making tire mulch instead of actually recycling their tires, does not mean it is safe.
And as far as cliffs go, I hope you find yours soon.
Jun 24, 2009. 6:08 PMRahdzhillaxxx says:
Many years ago I used to work in one of the companies down in Ninnesee (I wont give them a full ten) that makes the rubber for Firestone tires. I'm sure its still done the same today as it has always been done. a conveyor line getting all the carbon powder, neoprene, chemicals and plastic baggies of oils and such poured onto ( By very hot dirty, VERY DIRTY men)then timed to go into a heated mixing vat for about 5-7 minutes (only long enough for a couple guys to lift nearly a thousand pounds of ingredients back onto the belt. Then when it hits the right temp and mix time its dumped down onto two steele rollers and rolled and mixed again BY HAND! there is a gap between the rollers of about half an inch and you take a blade from the side you cut into the edge making a big roll as the rollers spin, being careful not to get sucked into the gap(lotsa one armed guys there) then once its an even texture it gets a slice cut and onto more rollers and cutters and so on and so on. These guys live in this stuff 10 hrs or so a day. I only spent a few weeks doing it through a slave, ahem, Temp service, for 6.75 an hour. that job was THE hardest and most dangerous I've ever tried (and did ok at too) Over the years I was the MIKE ROWE of the temp agencies and saw a LOT of weird stuff but tire rubbe once its been round the roads is probably just as safe to use as a planter as any other synthetic pcb/bha/ holocost leeching plastics or concretes(also very dirty and chemically crazy) used today. most of the treated lumber or railroad ties or any number of things are INHO less safe than tires. But I could also be harboring a full twin of cancer in me and not know it too.(that might come from either the involutary testing in the military or the radio waves when I was in Radio
Nov 15, 2009. 5:48 AMunderwhelmed says:
Actually, as most tires are now made in China, I am sure things are different now.
I would also surmise that as today's tire have improved wear characteristics over tires from years ago, that different compounds have been added to the mix to accomplish this. What are they, and how do they degrade when not used as intended, but rather put in dirrect contact with dirt? Who knows, as the manufacturers do not have to divulge their "Trade Secrets."
Jul 4, 2009. 3:46 PMrippa700 says:
A word of caution about using tyres are tree rings. We have a farm where this was done 20 years ago and I am really struggling to remove tyres from the larger trees as they are getting strangled. See my blog www.wheatlandfarm.co.uk/blogtyreingwork.html - we finally used a reciprocating saw to cut the tread and sidewalls and had to cut a wide access hole in the sidewall to get the bolt-cutters in to cut the bead. All this in undergrowth on dirt so not easy to hold the tyre steady. Be warned and cut the tyre before using it.
Jul 3, 2009. 11:05 AMmamashawn says:
You could also use a box cutter to remove the sidewalls. You do have to make two or three passes around the tire, pushing on the sidewall as you go to help open up the cut. Not at all difficult. Just an option for those who may not have a jigsaw.
Jun 29, 2009. 8:52 PMrseethawake says:
i have made this recently. and in my project , i turned side wall removed tire bad side. i just cant explain it due to my poor english. so i add an immage of it . now it is not look like a tire.
Jun 28, 2009. 9:04 PMIyer2711 says:
of course your project is very nice but more so is your words of caution. Almost like a friend. Thank you :)
Jun 25, 2009. 10:31 AMrandygl says:
Good idea! I would use for flowers only though. I would have a concern with toxins in the tire leaching into the soil and then into any vegetable plant.
Jun 25, 2009. 9:42 AMxnotxp says:
You can make your own special blade: a knife edge blade. Take an old saw blade and grind a knife edge on the back edge and then use it with the knife facing forward. This cuts nicely and doesn't catch (but will get dull) when you hit the wires. It is better around the wire belts, cuts smooth edges in the rubber, and eliminates most of the saw dust but it's not necessarily easier. Use a hard steel blade instead of bimetal which is softer on the back edge.
Jun 25, 2009. 9:40 AMourmoneypit says:
Used tires can safely be used for all sorts of similar projects. One can even build a retaining wall with them. A huge retaining wall was built in South America by this method and the project was a success. Some folks combine the planter with the retaining wall and this is something I plan to do. Seems like a great way to cultivate. One caution, however: the metal in the tires can leach toxic chemicals into the ground over time. I personally would not use any tire where the cut metal was exposed and could leach in this way.
Jun 23, 2009. 12:39 PMartoftexas says:
This is a GREAT Project! Thanks so much for submitting something that recycles those old tires and even makes use of the part of the tire you cut out! I have been wanting to put in raised beds and am going to do this as soon as possible. We have crape myrtles all around our driveway and it will make them so much more attractive to put a tire ring around them. We are going to paint ours with the paint that you can use on outdoor plastic furniture to dress them up a little. Maybe I'll add a picture when we are done. Thanks again!
Jun 23, 2009. 2:49 PMartoftexas says:
There are trade-offs with being in the South tho'. I am in the TX Hill Country and we are lucky to have two growing seasons but the heat in the summer can be a killer! You just have to get up super early to get anything productive done in the gardening or do it anytime after 7 pm. Our lack of water the past two years has been real hard on our pasture but luckily we have a well and can water when it is really bad. We bought like fifteen crape myrtles when we first bought our house ten years ago and have a huge circular drive with a park like set up in the center. We surrounded the circular drive with crape myrtles and it is amazing how heavy the branches get with blooms!! I love our raised beds that my husband made with large rocks (we have tons of rock on our property!). He worked really hard to make the center area beautiful and we have a small water feature and an old above ground swimming pool that we converted to a koi/goldfish pond! I really love all the ideas I get on Instructables. This site ROCKS! P.S. I have to admit I miss the fall colors and crisp mornings in the north but I praise God I don't have to deal with snow anymore!!
Jun 22, 2009. 12:42 PMUncle Kudzu says:
as a variation on this theme, i've cut out only one sidewall and used a drill with a holesaw bit to make drainage holes in the other sidewall. (i had no use for the cut sidewall and didn't want two from every tire.) my plan was to make a small berm of modified stacked tires. it's great to see folks trying to find uses for the mountains of tires we're constantly generating. keep up the good work!
Jun 22, 2009. 9:42 AMthepelton says:
I recall reading about something like this in Mother Earth News about 30 years ago. The man that posted it was wheelchair bound, and was growing potatoes in stacks of tires. He harvested his potatoes by knocking over the stacks and pulling the potatoes out of the tires.
Jun 22, 2009. 7:37 AMGoodhart says:
GREAT instructable!, and very detailed explanation.
I had only one bit of trouble though. I was not familiar with a dual saw, so naturally, I Googled it, and most of the entries I came up with were a specialized saw that was a bit out of my price range ( as noted here ).
Is this what you mean by a dual saw or is it something else?
Jun 22, 2009. 8:36 AMGoodhart says:
Yeah, I have been forced, by lack of finances, to be a lot more eclectic, sadly; since many times that means it takes a lot longer. :-) but I understand what you mean.
Jun 22, 2009. 7:53 AMgsport george says:
Nice work, but... In areas with a decent amount of rainfall it might be an idea to add some gravel or other drainage layer in the dip in the lower sidewall before putting the soil on top, I can imagine that area becoming waterlogged and leading to problems.
Jun 22, 2009. 1:20 AMNotACat says:
It might seem obvious, but it took me a couple of goes to realise that the "tree-ring" in Step 5 is made from that first side-wall you cut off in Step 3. At first I thought you'd made it from a second tyre turned inside-out somehow. Maybe for those of us stricken with the Monday-morning thick, you could make this more explicit?
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:auntwrenny
