3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Used Tired Raised Garden & Tree Ring
Step 3Cutting Away the Sidewall with Jigsaw
Now all you have to do is cut around the tire! We didn't use a special blade. The general purpose blade works just fine.
You should also note that it isn't necessary to remove both sidewalls. We've tried this both ways and have found that the tire is much more stable if you only remove one side. Also, you have a trough that allows a little water to pool into a reservoir which helps with fluid retention and watering. Another benefit is the way this second sidewall will hold the landscape fabric and soil without allowing it to run out the bottom.
2 comments
Apr 6, 2010. 10:05 AMorigamifox says:
You don't say anything about what to do with the sidewall once you have removed it.  I have found that you can invert the sidewall and place inside the tire, over your landscape cloth.  This will help hold the landscape cloth in place inside the tire.
Jun 25, 2009. 9:42 AMxnotxp says:
You can make your own special blade: a knife edge blade. Take an old saw blade and grind a knife edge on the back edge and then use it with the knife facing forward. This cuts nicely and doesn't catch (but will get dull) when you hit the wires. It is better around the wire belts, cuts smooth edges in the rubber, and eliminates most of the saw dust but it's not necessarily easier. Use a hard steel blade instead of bimetal which is softer on the back edge.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:auntwrenny
