Step 2Build the circuit.
Get the accompanying horns that come with the servo and pick the one with TWO arms.
Unscrew the old horn and replace the new one...if you already have it in well then...GREAT!
Once the switch is soldered and the motor is mounted test it out... if it starts rotating one way then flip the switch...if it works...
GREAT!
Now hot glue the slide switch to the motor. Make sure that if its going on the right side of the servo with the horn on its left the 68Kohm resistor is closest to the end of the servo.
If its on the left follow the exact opposite.
OIL the SLIDE SWITCH!!!
Add Comment
