Mod Film for use in super old cameras (620 film)
  • last photo ←
There's a lot of awesome old cameras out there, most use 620 film, which is hard to come by these days, or extremely expensive. This instructable details how to mod your cheap 120 film for use in older 620 era cameras, without having to do the whole darkroom thing.
all you need is sandpaper, a knife and some brute force
Step 1Getting some backround info
I got a hold of a Kodak Tourist, a film camera made in the 40's.
I wanted to use it to take some pictures; its an awesome camera that supposedly kicks out high-res shots. So after going to a camera store, i found out that the film it uses (620) hasn't been made for 30 years. Knockoff film is available, but its expensive (20$ for 1 roll of like 8-10 pictures, + the cost of developing = ridiculous)
I found a guide online for 're-spooling 120 film onto 620 spools, although this looked like a quick alternative, i found out it was nearly impossible, as it involves moving things around in the dark, without touching the film. I attempted doing it in the daylight on exposed film, and i failed miserably.
Then i realized, the only reason it was necessary to 're-spool' was that the spools were slightly larger than 620's . Thanks evil corporations.
The camera's are pretty much useless without the film, so if you break something, chances are no one was going to use it again anyway.
11 comments
Nov 4, 2010. 5:12 PMcrudworks says:
I've been working off of the guide you mentioned to mod a 120 spool for my 620 kodak box brownie; shame the take up mechanism keeps ripping the spool to shreds :(
Gonna try Brandon121233's plastic tutorial to make a sleeve for it to fit.
I'd suggest to anyone wanting to make a 620 spool to grab some Kodak 120 spools (Pictured in instructable) from the bins of a photography department as they're much easier to cut to shape if you use the grove.
Nice instructable/camera Dane.
Feb 3, 2010. 11:37 AMMother Natures Son says:
I've got an old Kodak TLR which takes 620 film, and I'd like to figure out a way to use it with 35mm. The 35 mm canister is too large to fit in the 620 bay. Any suggestions?
Feb 17, 2009. 5:11 PMClayton H. says:
I was able to score a Kodak Vigilant Jr. Six-20 off of ebay. I like the bellows but they are a pain to take care of. Also i was wondering, Can you roll the film onto the moddified 120 rols instead of the 620?
Feb 18, 2009. 1:10 PMClayton H. says:
Well what i'm asking is that in the cammera do you NEED to put it on a 620 roll after you take a picture. like you have two spools one with unexposed film rolled on it and another with nothing on it and what i'm asking is if you need the infeed spool to be a 620 spool or can it be a modiffied 120 spool.
Dec 28, 2008. 9:34 AMkylemcdonald says:
Very nice. How did you find the old 620 spool? Was it left in the camera? Even if you don't have a scanner, you should just take digital photos of the results :)
Jan 10, 2009. 9:42 AMImageMaker says:
Most old 620 cameras come with an empty spool left from the last roll of film. Occasionally you find one with an old roll of film still loaded; not only do you then get *two* 620 spools, but you can sometimes recover images from the exposed frames on the film! I've got around twenty of them, after getting an eBay lot of old darkroom supplies that included a dozen or so, but you can also buy loose 620 spools on eBay for around $3 to $5 each.
BTW, respooling isn't hard *if you already process your own film and are used to handling film in the dark* (hint: roll the film onto another 120 spool, either in the darkroom or in a camera, before trying to spool it backward onto a 620), but even though I have respooled, I find it much easier to modify my 120 rolls. I use a heavy nail clipper to cut the rim, and for most of my 620 cameras I don't need to sand the thickness of the spool flange (that is, the extra 1/16" of overall length doesn't cause a problem).
I recommend processing your own film from these cameras anyway, since there aren't many places left that will process 120 film locally (much less black and white); if the film is sent off somewhere you're very unlikely to get your 620 spool back, and the cut-down 120 spool won't work on the takeup side in most 620 cameras.
Dec 28, 2008. 5:40 AMPhil B says:
My mother had a Kodak Tourist camera I inherited, but no longer have. The negatives were bigger, but the lens on hers was not all that sharp, as I remember. I got a Yashica D twin lens reflex as soon as I could afford it. It used 120 film. We still had some 620 film or I found 620 on sale for much less than 120 film and I made the conversion the in reverse by drilling out 620 spools to fit into my 120 camera. Your innovation is clever.
Dec 27, 2008. 8:03 PMLinuxH4x0r says:
Nice! My dad has an old russian camera that hasn't been used in decades.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Emperor Dane
Im a Student at RPI in Troy NY. The best part of college is most definatley 'Spelunking' or dumpster diving for parts in the elctrical engineering dumpster.
