Here, we will look at getting our LEDs to work without a transformer and build a simple light that is integrated into an expansion bar.
WARNING: For countries with 110v mains, we'd be working with voltages of 150 volts! For Europe and other countries, we are talking about 300 volts or more! At these levels, electricity is lethal! Do not continue unless you are comfortable with working with high voltages and are aware of the precautions to take!
AC supplies are quoted in rms (root-mean-square) values. The PEAK voltage is sqrt(2) * Vrms, which is about 1.4 * Vrms
Step 1: Some background
150 / 20mA = 7500-ohms (we should subtract the voltage of the LED from 150v first, but the difference is minor)
7500-ohms? Not too bad... But then let's consider the power rating of this resistor, using the Power rule: P = (V2) / R, we get:
150 * 150 / 7500 = 3 watts, and that's a pretty hefty resistor. Brits with 240v mains will need a 17000-ohm resistor rated for almost 7-watts. And these will be running HOT!
Fortunately, by substituting a capacitor for the resistor, we can get the same reduction on voltage without the (or as much) heat. Capacitors delay the phase angle of AC which we can use to oppose itself, much like receding waves on the shore cancelling out some of the force of incoming ones.
Step 2: Our circuit
C = 1 / (2 * pi * f * X) where f is the mains frequency
which is .4uF for 110v 60Hz, and .2uF for 240v 50Hz.
Instead of watts like resistors, capacitors are rated by volts, we have to make sure we get caps rated for AT LEAST 250-volts (States) and 450-volts for 200-volt countries.
WARNING: Capacitors with insufficient voltage ratings may explode!
This very simple design will drive 2 - 16 LEDs without any changes. Just put the same number of LEDs in each branch, and make sure you hook them up with opposing current flow.
Step 3: A non-lethal installation
Use a .4uF (.33 to .5uF) capacitor and attach your device to the 2 leads of your telephone junction box (usually the red and green wires), and it will flash when you get a call.
NOTE: this ONLY works on home phone circuits - PBX and Central phone systems are totally incompatible.
Step 4: Making the socket expansion light
Parts:
Socket Expansion - check to make sure it has a screw-in back. I got mine (a 'Noma') at Target (Radio Shack seem to have a similar one as well). Obviously you have to get one that is suited for the power system in your country.
Capacitor - (US, 110v 60Hz) any value from .33uF to .47uF 250-volts MINIMUM!
(Others 200-240v 50Hz) .15uF to .22uF 400-volts MINIMUM!
Resistor - 1000-ohm (1K) 1/2W. I did not have a 1/2W resistor, so I took 3 x 3300-ohm 1/2W resistors and wired them in parallel to get a 1100-ohm 3/4W resistor
LEDs - 14 pieces of high-brightness, 20mA 5mm (T-3) White
Heat shrink tubing
Step 5: Preparing the LEDs
Rank them in brightness and place the brighter ones in the middle.
Step 6: Preparing the Socket
Mark out 2 rows of 7 points, 3/8" apart on masking tape. Center it on the end you decided on and start 14 holes with a 1/16" bit. Expand, using a 3/64" bit. Smooth the holes SLIGHTLY - it should hold the LEDs snug.
Step 7: Installing the LEDs
Bend the LEDs in an "L" shape (short wire on the appropriate side) and snug them into the bottom row.
Spread the wires about 30o to cross it's neighbor's. Solder lightly to keep in place, but DO NOT TRIM ENDS.
We will be assembling the LEDs in a lattice - see the second image. Except for the end units, each LED should have a lead touching 3 other LEDs.
It helps by pre-forming the LEDs for the top row so it can clear the "X" junction. (See image)
When you are finished, CAREFULLY reposition the leads to make room behind for the resitor(s) and capacitor. Make sure the solder joints are solid and no wire is shorting out.
Step 8: Finishing touches
Space IS tight, so only use as much wire as is needed.
The long green bundle under the cap is the resistor assembly.
The cap is linked to the other end of the LEDs with the red wire.
The big arrow is to make sure I don't start operating on the wrong end of the patient!
Make sure everything is tight and reassemble.
Visit Our Store »
Go Pro Today »
thanking you in advance.
LED strips are organized in modules, each has 3 led in series with a resistor, then all the modules are paralel. in terms os voltage they the led strip is 12vDC
can we build a simple Capacitor circuito to feed the all strip?
Paulo
As noted, the design here is not very efficient and is suitable for low power, multiple-LED applications. The "LED strip" will further cut into this efficiency as they lose another 20% in the resistor. Better to invest in a 12-volt wall-wart for $5 on eBay and use that.
However, it is completely feasible to cut 15 pieces off the strip and (re-) connect them in series. Then they will run off (a rectified) 120vac mains.
thanks!
marC:)
I tested with 0.22uF 630V non-polar Caps, one 1K ½W resistor, two white led wired in parallel, it work, so my query is, if I would like to add another 2 x 7 LED in parallel, do I still need another set of C & R ? Is there any limitation number of parallel row added to the circuit ? Thx in advance : )
I just built & replaced one of my table lamp with 2 rows of 7 White LED & it works : )
My question is, if I wish to add another 2 rows of 7 White LED, do I still need another RC set or I just parallel connect to the existing circuit ? Is there any limitation ?
Btw, if I want to filter out the flicker effect, add one Bridge Rectifier to it correct ? (400V rated @ 1.5A) ?
"Decide the end you wish to work on - whether you want the light to shine UP or DOWN. Then plug it in where you plan to use it and mark the top and bottom."
Some electricians (at least in the U.S.) always install receptacles with the ground up, others with the ground down, and many like to mix it up. It would be a shame to go through whole project and then find out your UP light was shining DOWN!
Once again, nice job, and definitely on my to-do list.
For higher power lights, this is not a good circuit, take a look at some of my earlier answers and check out both parts 1 and 4 of this series
A well-matched transformer system can be 80% efficient and off-line (Switched) circuits even higher; using a capacitor (or any other method) to limit current flow is much less efficient, although it slowly increases with the number of LEDs.
At the point where the total Vf of the LEDs equal the equivalent DC voltage, about 52 for 117vac, we can direct connect the LEDs and the efficiency then becomes 100%.
The image below is a light just announced by Phillips which uses a cluster of 96 LEDs to operate directly off rectified 230v mains.
Please reread the values for 220vac carefully! The values you supplied will seriously overdrive the LEDs and permanently damage them. The capacitor value is calculated as: ( 0.02 / ( 2 * pi * f * ((V * 1.4)-Vf) ), so it's not a linear relationship and certainly not directly proportional to the number of LEDs you want to use!
For 220v supplies, you can have up to 15 LEDs in each branch without changing the basic values, so you can easily have your 20 by putting 10 in series, in 2 opposing chains. See my response to lurkingdevil for an explanation of this.
erm..
can tell me why we need to add the 1k resistor ?
thanks
I once tried this same circuit without the resistor. The capacitor was fine, but a string of LEDs got burnt out.
And it turns out, the capacitor is identical to what you show.
Oh well, 3 pairs are pretty good. Its a good first try for me.
Turbonut48
What do you think may have caused this? Cheap LEDs?
Turbonut48
Another reason may be the use of a polarized or out of spec capacitor. Make sure it is a 0.47mF (or .47uF or 470nF, which are all equivalent) non-polarized unit.
Many thanks.
Xc= 1 / (2 * pi * f * C)
Therefore the Capacitance for any desired Reactance, by solving for C,is
C = 1 / (2 * pi * f * Xc) in Farads
For f=60Hz and Xc=6500-ohms, I get 408E-9 or 0.408uF on my calculator, while f=50Hz and Xc=16000-ohms, yield a C of 198.8E-9 or about 0.2uF
Hope this helps!
if ur c is .4uF for 110v, then ur reactance would be Xc = 6.63k ohms right??? so
using the formula for the impedance above Z=1k + j6.63k
= 6.7k< -81.42 ohms right???
so if u calculate the total current I = (110 v/.707)/(6.7k<-81.42 ohms)
will give us
=(155.58<0 volts)/(6.7k<-81.42 ohms)
I = 23.22 < 81.42 mA...am i right????
pls correct me if im wrong hhehehehe i just want to confirm i really like to play with these things to but im just confused heehehe and what would be the voltage drop across the resistor????hahhhahahhahapls reply tnx....
The combined voltages of the LED is only a small fraction of the total AC voltage, and, if the capacitor is over .22uF, the current through the LEDs will be much higher that the rated 20mA. While it may not destroy the LEDs outright, it will seriously degrade its life-expectancy.
You will probably find each LED to be just as bright even if add 12 more LEDs to your circuit (bridge+resistor+cap). Again, the v-drop of 12 LEDs is about 40-volts, which is about 15% of the total voltage, and should not lower the light output noticeably.
Unless you plan on opening the circuit and playing with it after it's assembled, the 1M resistor will not affect safety.
