3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Using AC with LEDs (Part 4) - The New Technologies
Some of the roadblocks in general acceptance of LED in the home has been the relative high cost per lumen and the complicated and clumsy power conversion systems.
In recent months, a number of new developments promises to bring us a step closer to a LED-powered world.
Taking its cue from the ATX system which powers our computers, a new line of "Green-mode" adapters will convert any voltage from 100v to 240v, AC or DC, to run combinations of 1- or 3-watt LEDs in numbers from 1 to 7. These modules are under 1" in length and can actually be inserted inside the base of a household light-bulb.
Here, I've chosen a conversion module designed to power a single 3-watt LED at about 700mA, but have attached it to 8 x 100-milliAmp "Superflux" LEDs in parallel, which allows me to simplify heat-sinking and light dispersion.
The entire assembly can fit on a board 1.5" on each side.
Step 1
The module can be obtained here for about US $3.00 in single quantities, shipping included.
The 3-watt design means that there is no voltage over 5-volts on any of the LEDs, and they are completely isolated from the mains.
The large "MHX" capacitor seen in the images is used to filter the input, so its wire leads do carry high voltage. Cover them with electrical tape to be safe.
The "Green-mode" design rectifies and smooths out the mains voltage and uses it to drive an oscillator at about 100KHz. This square-wave is applied to a small flyback transformer which converts it to a much lower voltage . The currents in and out and the temperature are measured 100000 times a second and the oscillator is turned off until proper operation is restored.
103 comments
1-40 of 103next »
Feb 18, 2009. 1:25 PMnolte919 says:
Is there a reason you went with 8 LEDs instead of 6 or 7 seeing as the output from the driver is 650 - 700 mA?
Jan 24, 2012. 3:36 PMstp715a says:
I want to drive 80 x 100-milliAmp "Superflux" LEDs in parallel. Do you know if DX has a driver for that? Also, any suggestions on all parallel or series-parallel is appreciated.
Thanks
Jul 31, 2011. 10:46 AMadi1977 says:
Hello My Friend
It was a great pleasure seeing you work. Dear Friend as i'm not a professional in electronics I want some help from you please can you design me a simple drawing for making about 5 to 10 watt Powerful led tube for 220V power supply so that i can fully light up the room.
Also Please tell me the details of the parts and their specifications. I'll be very thankful to you.
(if i apply 1, 3 , 5, 10, 20, 30, 50 Watt LED's) what shall be the drawing.
Thanking You
Adit Pal
May 30, 2011. 10:16 AMmcarrell says:
I recently converted nearly my entire household over to LEDs of various configurations and from various makers including Phillips, Feit, and others..
I have found there are many tricks to choosing the correct light. Certain manufacturers and certain bulbs tend to make more "spot light" while others are very good at diffusing light and are ideal for more "flood" or general lighting requirements.
The great thing about these bulbs is generally speaking, most of them are dimmer compatible which relieves us of the problem of most CFLs not being compatible with dimmers.
One of the fairly unknown things in general is that these lights are better for the health of you and your property! They are at large flicker-free unlike CFLs so they don't tend to give people headaches or inflict irritability. They put out a more stable linear spectrum of light which is closer to sunlight than fluorescent light could ever be. The part that's also great for your property is that they don't emit xrays or plastic-yellowing UV spectrum unlike CFLs. AND THEY CONTAIN NO MERCURY!!! :)
Now having recently acquired bulbs for as lot as $10 each, I am confident once people find out how superior these bulbs have become, they will soon start flying off the shelves when they reach the ever-sweet $5 mark. I also believe that 2012 will be the year the LED lighting revolution really kicks into high-gear.
Jun 18, 2011. 7:17 AMstarphire says:
Congratulations on making that switch. I've worked in the LED lighting business for several years, and they are indeed superior to CFLs in some ways, and still getting better.
However, a couple of the claims you're making regarding CFLs over LEDs are simply untrue. We're all familiar with the older, flickering fluorescent light tubes as the bulb or ballast nears the end of its life. These used magnetic ballasts that fired 120 times per second. However, all electronic ballasts and ALL CFLs use high-frequency power supplies that fire the bulb thousands of times per second, far faster than any human can perceive as "flicker". Furthermore, MANY LED fixtures ALSO fire the LEDs some thousands of times per second, so any flicker effects from one would be similar in the solid state LED model.
You also claim a more stable spectrum of light from white LEDs. This is also false. Both types of light start by generating short wavelength light (UV or deep blue), which is then converted by phosphorescent material into longer wavelengths. Phosphor technology is well-established, and what you're essentially claiming is that the exact same phosphors somehow create a better looking or more natural looking light when a different excitation source is used. Neither one is all that close to sunlight - all phosphor base lights are much weaker in the red end of the spectrum, and all "warm white" phosphors are less efficient than the "cool" ones and have shorter useful lifetimes, and this is also equally true for both CFLs and LEDs.
Dec 4, 2010. 9:01 AMunni.0p says:
I HAVE ONE 3 W LED SENT ME A DIAGRAM AC LIGHT
Aug 19, 2010. 10:33 AMdilisi says:
Great Instructable!
May 24, 2009. 9:46 PMarirang777 says:
Thanks for sharing the knowledge, qs. I was able to put together your device: I used a hard drive plate as a mount. Cool as a cucumber for two weeks 24/7 now. The only hot element is the diode; you can not touch it more than few seconds. This basement corridor had three night lights but the light was still eerie. This device is able to light the whole thing, better and brighter, at a fraction of the three night lights consumption. The next step for me is to adapt a "motion sensor" to the circuitry and try a 8' linear array of LEDs along the corridor instead of a cluster for more light distribution. Wonder if there is a standard mount for the LEDs. One more Q, qs: If I want to use same LEDs but in an automotive setup, what could be your formula for max number of LEDs, maybe some esquematics? Thanks again!
Mar 2, 2009. 4:41 PMalex-sharetskiy says:
the thing is, that LEDs and flourecents put out harsh light, it's not soft...
Mar 10, 2009. 5:52 PMchamunks says:
Couldnt you simply use a candy wrapper or something to add a light filter to remove some of the harshness? Would probably be cheaper than buying more expensive "warm" LED's on the market. Sure you would lose some efficiency but i mean 3watts in comparison to the 15 watt florescent or the 60 watt incandescent equivalent your getting really greedy if you think filtering a few colours would be really all that bad.
Mar 10, 2009. 6:27 PMalex-sharetskiy says:
it still would be farily harsh...
Mar 3, 2009. 6:27 PMgeeklord says:
milk jug diffuser?
Mar 3, 2009. 6:35 PMalex-sharetskiy says:
you'll have white light, not "warm" yellow/white light
Mar 4, 2009. 5:42 AMgeeklord says:
but it will make it less harsh, right? You can use them as cheap diffusers for cameras, so I thought it might work here.
Mar 4, 2009. 7:39 AMalex-sharetskiy says:
it should work
Mar 9, 2009. 11:35 AMjunits15 says:
it would be better i you could find some warm white superflux leds
Mar 10, 2009. 3:36 PMgeeklord says:
yea, it took me a little while to see what he was talking about. My family just bought some "harsh" white flourescent lights for our living room, and I don't really mind them.
Mar 10, 2009. 3:40 PMjunits15 says:
I personally HATE flourescent light, I prefer the look of incandescant much better
Mar 10, 2009. 5:54 PMgeeklord says:
Has anyone done a survey on that? That would be interesting...
May 17, 2009. 6:43 AMpfred2 says:
Me too fluorescent is nasty light.
May 21, 2010. 10:41 AMpopcanguy says:
excellent instructable, simple yet useful.  Thanks for the great work :)
I've ordered the parts and will try building it.  Instead of the 0.5W superflux, I've ordered these 0.5W strawhats.  They have the same angle as the superflux (120-140 degree), but a bit bigger at 8mm. Price is a bit more if you buy bulk on ebay, 62 cents for the cool white strawhat compare to the 59 cents for the cool white superflux.  But the best thing about the stawhat is the brightness.... cool white superflux produce about 55k mcd while the stawhat give 110k mcd, and for the same current too! May need bigger pcb, but we'll see :)
Sep 4, 2009. 8:03 AMcaboteria says:
More experience: I built a module with 2 drivers and 2 rows of 8 lvehk leds in sockets (i.e. two independent arrays, each driven by one driver). I put it in an enclosed fixture and it worked for a while but it got hot enough in the summer so the LED's all burned out. It looks as if with 8 of the superflux LED's per driver you need some airflow to cool the LED's or they'll overheat, at least if you live in a warm climate. I'm going to try again but this time I'll let the module hang from the fixture instead of being enclosed in the fixture's glass globe. I think I might try it with a few more than 8 LED's per driver also to reduce the current through each LED.
Aug 8, 2008. 3:49 PMbuckaroo169 says:
Awesome, a multitude of thanks for the link to the driver module. To many builders just know they "got it from somewhere' but do not give source.
Again, MANY THANKS. Check out http://www.amazon.com/Flex-Strip-White-Ribbon-Meter/dp/B002DIZVBA/ref=sr_1_105?ie=UTF8&s=home-garden&qid=1247960685&sr=1-105 for a good source of SMD LED Ribbon
Jul 18, 2009. 4:43 AMcaboteria says:
I've made a few of these now and they work great! About the only thing that can go wrong, which is unfortunately really easy to do, is to damage the LED's by putting too much heat into them when you assemble the bulb. They'll work for a while but then start to flicker and eventually burn out, and once a few burn out then the others get much more current so they tend to go, too. I'd strongly recommend that anyone who's unsure of their soldering skills (or are sure that they have no soldering skills, like me ;) use soldertail sockets and then plug the LED's into the sockets. It's a little more expensive up front but at least for me much cheaper long-term. An easy way to tell if this happened (at least with the LVEHK led's) is if the led's are slightly different color - some more yellow, some more blue. They should all be exactly the same but color changes seem to be a good leading indicator of heat damage that will cause them to fail prematurely. The only trick to using the sockets is that a typical DIP socket is wider than the LVEHK led's but if you space the sockets with one empty protoboard row between them then you can plug each led so that it's making a bridge between two sockets.
Jul 12, 2009. 1:33 PMacmefixer says:
At first I thought that the LEDs were connected in series but then I checked one and realized that the pins are connected together internally in the LED. So they really are all connected in parallel. I connect LEDs in parallel when they're on a Joule Thief, because I figure the high current pulse makes their internal resistance help even out the current between LEDs. But I assume that the output of the power module is DC, so there's no pulse. I'm disappointed to find that these superflux LEDs I got from LVEHK have gone dim after 2000 hours. I think I'm gonna reduce the current to 20 mA or less to get longer lifetime.
Jul 3, 2009. 9:56 AMturbonut48 says:
I've been looking for this type of info for a long time. Your explanations are really good. I've got the parts on order and can't wait to build something. Probably start out with a small nightlight for an extremely dark hallway at night.
Jun 28, 2009. 9:04 AMsumatra says:
I built this using the same LED driver but different LEDs (more below). The driver put out a very constant 632 ma no matter how many LEDs I used. I was expecting more, maybe 800 ma. I'm curious to know if others found the same result.
I wanted a warm white light so I used these LEDs. Not only is the light still "glare-y", the color is a sickly pale yellow-green. I'd stay away from those LEDs.
Finally, regarding the eye's sensitivity to color, our eye's are most sensitive to green. For example, see this Wikipedia article.
I look forward to trying this again with better LEDs.
Jun 30, 2009. 7:52 PMsumatra says:
Have you used any warm white LEDs that you found to give a pleasing light, not harsh and with the proper incandescent-like color? Thanks.
Jun 28, 2009. 11:03 AMmrmarshall1 says:
doyou know of a power supply lke the one you used that would be able to power two of these http://www.seoulsemicon.com/en/product/prd/zpowerLEDp7.asp
leds?
Jun 28, 2009. 11:07 AMmrmarshall1 says:
sorry about the missing letters my keyboard is faulty.
Jun 18, 2009. 6:19 AMblazingpencilsdotcom says:
Confused about the photos here in step 4, the description in both composite photos is the same so they contradict each other. I assume the bluish side is the LED's, and am looking for warm-light LED solutions and variable color-temperature solutions with mixing/dimming. Got suggestions? Thanks!
1-40 of 103next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:qs
