In recent months, a number of new developments promises to bring us a step closer to a LED-powered world.
Taking its cue from the ATX system which powers our computers, a new line of "Green-mode" adapters will convert any voltage from 100v to 240v, AC or DC, to run combinations of 1- or 3-watt LEDs in numbers from 1 to 7. These modules are under 1" in length and can actually be inserted inside the base of a household light-bulb.
Here, I've chosen a conversion module designed to power a single 3-watt LED at about 700mA, but have attached it to 8 x 100-milliAmp "Superflux" LEDs in parallel, which allows me to simplify heat-sinking and light dispersion.
The entire assembly can fit on a board 1.5" on each side.
Remove these ads by
Signing UpStep 1
The 3-watt design means that there is no voltage over 5-volts on any of the LEDs, and they are completely isolated from the mains.
The large "MHX" capacitor seen in the images is used to filter the input, so its wire leads do carry high voltage. Cover them with electrical tape to be safe.
The "Green-mode" design rectifies and smooths out the mains voltage and uses it to drive an oscillator at about 100KHz. This square-wave is applied to a small flyback transformer which converts it to a much lower voltage . The currents in and out and the temperature are measured 100000 times a second and the oscillator is turned off until proper operation is restored.
Seriously, the lumen/watt output of LEDs go down the harder you drive them - a complete reversal to what we've learned with incandescent bulbs.
So, not only would 8 LEDs allow me to run things a bit cooler, it actually produces a tiny bit more light than 7 LEDs would!
Thanks
It was a great pleasure seeing you work. Dear Friend as i'm not a professional in electronics I want some help from you please can you design me a simple drawing for making about 5 to 10 watt Powerful led tube for 220V power supply so that i can fully light up the room.
Also Please tell me the details of the parts and their specifications. I'll be very thankful to you.
(if i apply 1, 3 , 5, 10, 20, 30, 50 Watt LED's) what shall be the drawing.
Thanking You
Adit Pal
I have found there are many tricks to choosing the correct light. Certain manufacturers and certain bulbs tend to make more "spot light" while others are very good at diffusing light and are ideal for more "flood" or general lighting requirements.
The great thing about these bulbs is generally speaking, most of them are dimmer compatible which relieves us of the problem of most CFLs not being compatible with dimmers.
One of the fairly unknown things in general is that these lights are better for the health of you and your property! They are at large flicker-free unlike CFLs so they don't tend to give people headaches or inflict irritability. They put out a more stable linear spectrum of light which is closer to sunlight than fluorescent light could ever be. The part that's also great for your property is that they don't emit xrays or plastic-yellowing UV spectrum unlike CFLs. AND THEY CONTAIN NO MERCURY!!! :)
Now having recently acquired bulbs for as lot as $10 each, I am confident once people find out how superior these bulbs have become, they will soon start flying off the shelves when they reach the ever-sweet $5 mark. I also believe that 2012 will be the year the LED lighting revolution really kicks into high-gear.
However, a couple of the claims you're making regarding CFLs over LEDs are simply untrue. We're all familiar with the older, flickering fluorescent light tubes as the bulb or ballast nears the end of its life. These used magnetic ballasts that fired 120 times per second. However, all electronic ballasts and ALL CFLs use high-frequency power supplies that fire the bulb thousands of times per second, far faster than any human can perceive as "flicker". Furthermore, MANY LED fixtures ALSO fire the LEDs some thousands of times per second, so any flicker effects from one would be similar in the solid state LED model.
You also claim a more stable spectrum of light from white LEDs. This is also false. Both types of light start by generating short wavelength light (UV or deep blue), which is then converted by phosphorescent material into longer wavelengths. Phosphor technology is well-established, and what you're essentially claiming is that the exact same phosphors somehow create a better looking or more natural looking light when a different excitation source is used. Neither one is all that close to sunlight - all phosphor base lights are much weaker in the red end of the spectrum, and all "warm white" phosphors are less efficient than the "cool" ones and have shorter useful lifetimes, and this is also equally true for both CFLs and LEDs.
I've ordered the parts and will try building it. Instead of the 0.5W superflux, I've ordered these 0.5W strawhats. They have the same angle as the superflux (120-140 degree), but a bit bigger at 8mm. Price is a bit more if you buy bulk on ebay, 62 cents for the cool white strawhat compare to the 59 cents for the cool white superflux. But the best thing about the stawhat is the brightness.... cool white superflux produce about 55k mcd while the stawhat give 110k mcd, and for the same current too! May need bigger pcb, but we'll see :)
Again, MANY THANKS. Check out http://www.amazon.com/Flex-Strip-White-Ribbon-Meter/dp/B002DIZVBA/ref=sr_1_105?ie=UTF8&s=home-garden&qid=1247960685&sr=1-105 for a good source of SMD LED Ribbon
I wanted a warm white light so I used these LEDs. Not only is the light still "glare-y", the color is a sickly pale yellow-green. I'd stay away from those LEDs.
Finally, regarding the eye's sensitivity to color, our eye's are most sensitive to green. For example, see this Wikipedia article.
I look forward to trying this again with better LEDs.
leds?
