In this instructable a simple way is shown on handling these altoid tins.
The approach is to freeze water in the tin, and then do the cutting and drilling. The ice supports the metal resulting in perfect cuts.
These instructions were originally posted by me on http://www.wikihow.com/Use-Altoid-Tins-As-Cases-for-Electronics
Remove these ads by
Signing UpStep 1Freeze and cut
2) Fill with water and place it in the freezer overnight.
3) Next day you will have a tin with solidly frozen ice. Moisten your cutting pattern (printed or hand-drawn paper) and place it on the bottom of the can. The paper will instantly stick to the can!
4) Use the paper pattern to cut the metal with a chisel or to drill holes with a drill. The ice will support the thin metal and prevent it from buckling or bending.
5) If necessary place the can in the freezer again if the ice starts melting. The ice block in the can be seen in the image through the rectangular cut.
6) Once you have all the holes cut, place the can in warm water to melt and remove the ice. File/sand any rough edges.
15
comments
Add Comment
Add Comment
