Using Bread to Sweat a Leaking Copper Pipe by badpanda
Featured
This Instructable shows how to use white bread and standard pipe sweating techniques to repair a leaking copper pipe.  There are a ton of excellent instructions online and here at Instructables for pipe sweating, this isn't meant to replace those, but rather to show a trick I learned over a decade ago for sweating a pipe that is actively leaking.  Normally you hope that by cutting off your mains and draining your lines you can eliminate any water leaking from the pipe you're trying to sweat.  Sometimes you can get any extra out by using a shop vac.  But sometimes you're screwed and a persistent drip will make it nearly impossible to do a proper solder because boiling water coming through a seam doesn't allow for the solder to set where it should.  This is a cheap work around.  There are commercial products that produce a similar result, usually wax plugs or other things that melt away as you sweat.  That might work, but I have to imagine some wax is left behind because by the time you turn the water back on the wax won't be liquid anymore, but I digress.
I apologize if my pictures are a little dark or blurry.  I had to do this in the dark while it was raining on my back, but we don't usually get to pick when these things happen, so I'm just glad I remembered to take photos at all.
Tools and Materials:
Pipe Cutter
Couplers (correct diameter)
Extra length of pipe (correct diameter)
Flux
Torch
Non Lead Solder
Hunka Bread
Step 1: The Situation
If you saw my last Instructable on making Motorcycle Saddle Bags out of 40MM Ammo Cans  there was a step in which we sprayed down the cans with paint stripper and then rinse them with the hose.  Well, if you've ever watched somebody walk off with a garden hose that hasn't been secured to anything other than the faucet itself, you know what's about to happen especially if that faucet is sticking way out.  Some copper is about to get mangled.  Secure your hoses between you and the faucet.  Then maybe you won't ever need this bread trick.
In this case I noticed a pretty good twist in the pipe right against the wall and a small crack that was leaking water, and this is right above my main.  There are other Instructables on patching pipes, making the cuts, and sweating so I'll move fast through those parts.  I'm not trying to compete with those and they are excellent, I'm just showing a trick for doing it when leaky.  So I punched out a bit of wall and cut out the bad section with a pipe cutter.  Use a pipe cutter, as much fun as power tools are, they and copper piping do not go well together... you will not get straight cuts and straight cuts are crucial to prevent leaks.  Most copper pipe cutters cost less than 10 bucks.  I bought one today for 8.50 after realizing what a disaster my grinders metal cut off wheel was making. Use standard sweating techniques to put a new pipe section in and the couplers needed, right up until the last bit which never quite quit leaking.  I tried for about 5 minutes to sweat this piece on before realizing it would be impossible and remembered this trick my old boss taught when I was a kid working a summer job.
MaskMarvl says: Nov 30, 2012. 7:49 AM
Great tip... I could have used this a while back. :)
sharpstick says: Oct 10, 2012. 3:59 AM
Great trick.
I'm a lousy solderer too. I had a friend come over to do some vertical pipe caps recently because I didn't trust my own skills to get the solder to run uphill into the joint. He brought over presoldered fittings. (Maybe they were only pretinned. At any rate, they worked much better. I've never seen them in the home amateur hardware stores, so I suspect they came from a plumbing supplies store.)
badpanda (author) says: Aug 30, 2012. 7:59 PM
Thanks for the comment, glad to know people are still reading this trick. When I was 17 I worked for an old school Mormon carpenter who built custom homes, and I'm not talking "custom" like it's thrown around today where you get to pick your paint colors and flooring, I'm talking Southern Living magazine deep south plantation style custom, with stables and guest quarters and such, and he only built or restored one house at a time. He showed me that trick when restoring a historic cabin for a professor at UGA. I went into the Marines after that job and he wrote me at boot camp and again after I shipped overseas, a real great guy who showed me a lot of tricks of the trade that have stayed with me for 20 years and come in useful innumerable times.
Takelababy says: Feb 7, 2012. 4:12 PM
My hubby, a welder, asked for a piece of bread to sweat a barely dripping copper connection. We don't eat white bread so I handed him a piece that had various cracked grains in it. It worked, he did a beautiful job but upon turning the tap on, no water. He was stumped. I don't know why I removed the tap aerator but there was the bread, a solid mass, the grains having swelled solid. We were laughing so hard he could barely see to dig the mass out of the spout. So don't use whole grain bread.
streetrod5 says: Oct 1, 2011. 10:00 PM
My favorite plumbing trick! I've used this for a few years, and it's great when you don't want to wait 3 hours for all the water to drain.
Just watch your fingers when shoving the bread down the pipe; I've cut my fingers twice - now I like to use a blunt-nosed object like the fat end of a punch, or a wood dowel.
Wonderbread or white bread is the best; if bread is dry or has nuts/berries/twigs, it will be harder to ball up and shove down the pipes. And it will take longer to break down; you'll be digging junk out of aerators for days!
heathbar64 says: Sep 28, 2011. 6:45 PM
I've used the bread trick before and it really does work. I ate the crusts off first because i was afraid they would plug up stuff too well. ( besides I was hungry)
Only problem was I plugged up the shower head with bread when I turned the water back on. Should have taken it off before I flushed the pipes.
sconner1 says: Sep 14, 2011. 11:27 AM
Great tip.
badpanda (author) says: Sep 15, 2011. 8:20 PM
Thanks!
rimar2000 says: Sep 10, 2011. 10:31 AM
Interesting, thanks for sharing.
Years ago I used ground paprika to fix a leak in the car's radiator. It is an old road trick. It works!
badpanda (author) says: Sep 10, 2011. 11:47 AM
Thanks... good tip with the paprika, did you just pour some into the radiator and it sealed the leak or what? I haven't heard that one.
rimar2000 says: Sep 10, 2011. 1:01 PM
Yes, you must put a soup spoon of paprika (Spanish: pimentón molido) in the hot water when the motor is running. After a few seconds the little flakes of paprika clog the leak. The fix is valid for some hours or days, you must fix "really" the leak soon.
rimar2000 says: Sep 11, 2011. 5:48 AM
Obviously, that works only for little leaks, that are more frequent.
Lorddrake says: Sep 12, 2011. 4:40 AM
so it is kind of like cracking an egg into the radiator to stop a leak .. it is by no means a long term solution to the leak, but it should get you to where you need to go to get the leak truly fixed .
rimar2000 says: Sep 13, 2011. 6:44 AM
That of egg I didn't know. It is easier to get an egg than paprika, I suppose.
Lorddrake says: Sep 13, 2011. 7:21 AM
sounds like the paprika will work if it is added to the radiator regardless of the temperature of the radiator. The egg only works if the radiator is hot.
sorry about getting the commets off track badpanda. Great instructable.
badpanda (author) says: Sep 13, 2011. 9:43 AM
It's all good... spread the knowledge.
badpanda (author) says: Sep 12, 2011. 11:23 AM
Thanks guys.
ahooper says: Sep 12, 2011. 1:33 PM
Use silver solder instead and you will get a better joint. Also it would not be a good idea to do this on the main feed to the hot water cylinder. Another option also would be to sleeve the joint so as to make it stronger.
As for radiators. I have used Egg, Pepper and once when I got really desperate curry powder. The egg one is simple, separate the white and drop it in to the radiator. fire up the engine and it will clog the hole. Same deal with the powders as they mix with the water and are ejected out the hole eventually clogging it.
Something people forget to do that makes this fail however is to put a match stick under the pressure part of the radiator cap so your radiator will not build up pressure to blow the seal out. It is a temporary fix.
badpanda (author) says: Sep 12, 2011. 2:18 PM
Thanks... in this application I did use the sleeve, referred to as a coupler in the instructions... were you referring to something else I don't know about? What I used is a collar about 2" long made for the 1" diameter pipe I had crack here. I used silver solder here too... the lead free variety, just because I assumed it's bad to have lead anything in your plumbing/water.
The match stick knowledge on the radiator fix is something I definitely would not have known but makes total sense. Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
