Step 3Using the scope and editing components
Once the component is in the scope (At the bottom of the program), you can select what is viewed in the scope such as if i use the LED for example i can make the scope view its Current by right clicking the scope at the bottom and deselecting "Show Voltage". This will show only the current; as "Show Peak Value" is still selected, this allows you to see the peak amount used by the LED, this can be useful if designing PWM circuits etc.
To Edit a component such as a Resistor, right click the resistor and go on "Edit". A small box should appear which in it says: Resistance (ohms) with a box next to it and a slider bar underneath. The desired resistance can be put into that box to change the components resistance. This box varies with each component.
comments
Add Comment
Add Comment
