Using Ferrofluid to Demonstrate Magnetic Fields
1,601
13
Published
Introduction: Using Ferrofluid to Demonstrate Magnetic Fields
Curious about dancing ferrofluid as dark as a black hole? Of course you are! Keep reading! Unfortunately, the phenomenon of magnetism is hardly perceptible in daily life. Although magnetic field lines offer a conceptual aid for understanding, it still remains unclear how magnetic fields manifest in space. In our set-up we tried to show visually the effects of magnetism in a way you could only dream of (until today) and in this instructable we will learn you how to make it yourself! The basic principle is making 2 highly densed coils, connected to a DC Power Supply and adjustable resistors. By adjusting the resistance, the current through the coils will alter, which in turn alters the magnetic field strength. Be aware: soldering is required! Also a slightly important side note: ferrofluid is a very sticky substance which cannot be removed easily (read: almost impossible).
Good luck, be careful, but more importantly: enjoy!
Step 1: Stuff and Tools
First, gather all the things needed for the set-up. Essential building parts are:
  1. 2 steel bolts (diameter 1.2 cm, length 15 cm)
  2. 0.5 mm diameter conducting copper wire
  3. 2 adjustable resistances (between 50Ω and 100Ω)
  4. A wooden plate (around 25 x 25 cm)
  5. 2 wooden blocks (height: around 20 cm)
  6. 2 screws (minimum)
  7. 2 stand clamp holder
And the following tools:
  1. 2 DC Power Supplies (maximum of 30 V & 1A)
  2. A soldering iron
  3. A glue gun
Step 2: Wrapping the Coils
The most essential part of this project is winding the coils, so let's do that first. You will be needing the wire and the bolts. To achieve at least a magnetic field strength of 0.5 T - bearing in mind that the power supply can generate a maximum current of 1A - 4000 windings per meter is chosen.
In order for the coil to work, the wrapping does not have to be done very precisely, but try to count while doing it! Overlapping wires while wrapping should not be a problem. Make sure that the steel is not showing at any place and that the 'thickness' of the wiring covering the steel is the same at every point.
The thing is: the coil works even though the thickness of the wiring is not uniform over the whole length of the bolt. However, if you wind the coil very carefully and make sure that the thickness is uniform, the magnetic field will be more uniform.
Almost done? Check if the thickness of the coil is uniform!
Finally: make sure you leave a piece of wire (about 20 cm) at each end to attach to the power supply and the resistor.
Step 3: Connecting the Coil to the Blocks
Now that we have the finished coils with a steel core, we can start putting everything together by mounting the coils to the wooden blocks.
Drill a hole in the wooden blocks and secure the adjustable stand clamp holders in place with their accompanying bolts. The hole should be approximately at half the height of the wooden blocks; the exact height does not matter since the final height of the coils can be adjusted easily with the stand clamp holders.
Glue the wooden blocks to the wooden plate at the 'halfway line' of the plate like pillars. Place the blocks with the clamps facing each other at an equal distance from the center of the plate on the 'halfway line'.
Step 4: Soldering Components
Note! The copper wire of the coil has a thin enamel layer (insulating layer) around it, so scour this layer off the copper wire for good connection.
Connect the adjustable resistors to the coils by soldering one piece of wire each to the right tab of the variable resistors. To be able to connect the coils to the power supply, another piece of wire must be soldered to the middle tab of the resistor.
For extra aesthetics it is possible to make a nice dial out of cardboard or paper to read the ohmage of the variable resistor.
Glue the variable resistors face-up on the wooden plate. Make sure there is enough space under and around the resistors as these can get hot.
Step 5: Finishing Touches
For the finishing touches a perplex plate needs to be attached to the top of the wooden blocks for putting the ferrofluid on top, while the coils remain visible.
The ferrofluid needs to be put in a plastic container. This fluid is very nasty and is very hard to remove from your hands and clothes.
Dont forget to turn off your glue gun and soldering iron.
Step 6: Using the Set-up
For using the set-up the wires from a, the coil, and b, the variable resistor, need to be connected to a DC power supply. By turning these on and cranking the voltage way up, spikes in the ferrofluid should appear. If not, check if your variable resistor is turned down. By regulating the resistance, the height of the spikes is directly affected by the change of current through the coil.
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    3 Discussions
    This is pretty cool! Do you buy the ferrofluid somewhere, or is that something you can make?
    You can buy ferrofluid (available online) or you can make it yourself.
    Ferrofluid is a colloidal suspension of ferrous, which contains iron, and a liquid.
    "There are generally two ways you can make ferrofluid.
    The more expensive way (around $100 per cartridge of magnetic primer
    toner and some vegetable oil), and the cheaper way which is a little
    more difficult to make, but will only cost you about $10. You’ll need
    about 10 cassette tapes, some acetone, a strong chemical resistant
    bucket (this is very important), plastic wrap, vegetable oil, and
    magnets. Earth magnets are the better choice because neodymium magnets
    aren’t as good at stripping ferric oxide off of the tapes. To make,
    you’ll want to step outside as inhaling acetone is not favorable. You’ll
    break apart your cassettes and throw the tapes in your chemical
    resistant bucket. You’ll mix your acetone in, cover it with plastic
    wrap, and let it sit for an hour. When you come back you’ll have a fine
    black powder in the bottom of the bucket, and your tapes will look clear
    now. Wrap your magnet in plastic wrap and push your tapes to the side.
    Collect the ferric oxide with the magnet and place the powder in a small
    container off to the side to dry. Once it’s dry, add your vegetable oil
    (approx. 1.5 tsps of vegetable oil to 1 tsp of ferric oxide) and then
    you have your ferrofluid!"
    Source: makezine.com
    Topic Link: https://makezine.com/2014/10/07/diy-ferrofluid/
    Nice setup! Do you have a video of it in action?
