The first thing most will think of is photoshop. It's excellent, but expensive. And if you want to download a trial it's hundreds of megabytes. Personally I use GIMP (GNU image manipulation program). It is excellent; lightweight (under 20 megabytes), will run on many operating systems, has many useful tools, is very user friendly and has heaps of included gradients, fonts and textures!
Where can I get GIMP?
http://www.gimp.org/
Installers are available for linux/unix, windows and mac operating systems. The system requirements are fairly low, and it will download quickly with an average internet connection.
I'm going to take you through the ABC of editing an image. If you want to learn to do something that's been missed, check the tool guide at the end or just ask!
Remove these ads by
Signing UpStep 1Work in layers
We had been assigned in photography to edit a photo of Lourdes (Madonna's daughter..) to make it slightly less....you'll see. Not an easy task. I decided to see what I could do with GIMP in comparison to the more expensive (free vs. how bloody much?) and larger photoshop.
Also note that I am using the latest windows version of GIMP.
The first thing you should do when editing images is to work in layers. This allows you to edit specific parts of an image without touching other parts. It also allows you to completely scrub a massive amount of stuff ups instantly. Great!
Creating a new layer is simple. Simply select the "Layer" drop down bar and click New Layer, or hold down Ctrl + Shift + N. You'll be greeted by a box asking you for the dimensions of the layer, the type and what you would like to name it. If you are working with a photo as a background leave the type as transparent. Then set the name to the part of the feature you are editing.
Once you have finished working in the layer you can select "merge down" to flatten the image with the layer below it. Make sure you are completely happy with what you did first.
6
comments
Add Comment
illuminatis
says:
nonickname (author)
says:
osgeld
says:
Add Comment
