Using Google Docs
122
Posted in TechnologyWebsites
Introduction: Using Google Docs
This is the screen that will come up if you've found Google Docs. To get to this screen, simply type in Google Docs into the Google search bar, then click on the first result. After that, you're going to click on the button in the middle of the screen. After that, you'll open the blank document, unless you want to use a template.
Step 1: Share a File With Others
To share a document, you will go to the upper right hand corner, where it says "Share." Click on that, and you will see this screen. Simply enter the names of other people who have access to Google Docs, or share through an email.
Step 2: Edit the Document
To edit the document, go to the upper right hand corner, which is usually set on "editing." If it is automatically set on editing, then you are editing the document as is. You are already on that mode. To switch it back, simply click on "editing."
Step 3: Suggesting on the Document
To make suggestions on the document, simply click on "suggesting." Suggesting is for people who are either working with others on the document or are unsure about leaving something in the document and want to make sure that they remember. When you suggest something, it will be left underlined in green. You can choose to accept or reject the suggestion later.
Step 4: Viewing the Document
Let's say that you don't want to accidentally suggest or edit things. You can turn on viewing, which prevents you from doing just that. To turn this on, simply click on it at the side of the screen.
Step 5: Inserting
To insert something, simply click on "Insert" at the top of the screen. You can insert a variety of things just by clicking one or two buttons.
Step 6: Opening a Pre-Written Document
To open a pre-written document, click on "File" and then "Open." This will give you access to documents saved to your computer.
Step 7: Formatting Your Document
To format your document, click on "Format" and then select from a variety of options. Formatting simply means adding superscript, subscript, strikethroughs, and etcetera.
Step 8: Emailing the Document
To email the document, go to "File" and look near the bottom of the tab. You can email to someone new, or you can email to collaborators.
Step 9: Keep Calm When Your Document Doesn't Save
It's okay! I promise, your document saved. Here's how to tell. Google Docs saves everything from the moment that you start typing. In that sense, it is even more reliable than Microsoft Word. If you accidentally click out of the site, then just know that everything will still be there.
Step 10: The Importance of Google Docs
So, why is this relevant? Well, using Google Docs is relevant because I just got onto Indeed and typed in "Using Google Docs" in the job search. More than 200 jobs popped up. Obviously, you'll need more than this one skill, but Google Docs has become huge for careers.
Step 11: Video Explaining Steps
Please watch this video if you're still struggling to understand the steps!
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Microcontroller Contest
    2 Comments
    Such a great collaboration tool, thanks!
    Chad
    Great information on how to use Google Docs!
