This is a common technique used in most landscape photography.
You will need:
- a camera that allows you to manually adjust settings
**NOTE: All photographs used in this tutorial were shot and retouched by myself
Remove these ads by
Signing UpStep 1: Calculating Hyperfocal Distance
*The circle of confusion is just that: confusing. There is much debate over the "proper" circle of confusion among different cameras and lenses, listed on www.dofmaster.com, including a circle of confusion calculator, which you can view by clicking the link below.
http://www.dofmaster.com/digital_coc.html#coccalculator
Once the hyperfocal distance is calculated, the depth of field will extend from half the hyperfocal distance to infinity, making the whole image focused, producing a great depth of field.
The second image is a more visual example of the equation, and much easier to understand.
Visit Our Store »
Go Pro Today »
You can get a very large depth of field setting the diaphragm at its minimum (largest number). This is valid when you have enough light to catch the photo, and there are not fast movements in the scene. The field depth is directly proportional to the distance of the main object, too. It is to say: if the object is near, the field depth will be littler than if it is far. Hence, you should set the focus (and the main object) not too near.
