Using MT8870 DTMF Decoder With Arduino
37,540
25
14
Posted
Introduction: Using MT8870 DTMF Decoder With Arduino
DTMF DECODERS Are used to detect DTMF TONES Genrated by mobile phone DTMF Keypad.
In this project we are going to decode the DTMF Tones into 4bit Output and this output is given to the arduino which detects the keypress and displays it on LCD
Step 1: Components Used
The components that I have used are easily available locally in most of the cities or you can also buy it online
Step 2: Circuit Diagram
Use the above Circuit Diagram and build the circuit.You can change it according to your need
Step 3: Giving DTMF Input to Circuit
The input is given by a mobile phone with a 3.5mm jack which provides the DTMF signals to MT8870 decoder
Step 4: Programming the Arduino
I used USBasp to program arduino u directly program it using usb it is better to use usbasp if you are building the circuit on breadboard
Step 5: Arduino Code
Use the code to program arduino
it uses hex codes for numbers pressed on dialpad of mobile
The Hex Codes For Keypress Are As Follows
1 = 0x01
2 = 0x02
3 = 0x03
4 = 0x04
5 = 0x05
6 = 0x06
7 = 0x07
8 = 0x08
9 = 0x09
0 = 0x0A
# = 0x0C
Step 6: Getting Output on LCD
The decoded key shown on a LCD Module In this picture the # key is pressed on mobile phone and it is also shown on LCD Module
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
if we wanna to interface to dtmf and arduino .so will be the requremeny libraries
11 Comments
Hello,
Very nice project. But I would like to ask if it is possible to add a sequence at startup, where you should "login" first then give commands to the arduino.
This way will be safer in use this project!
Thanks a lot.
My bad - theres a perfect image in the zipped files I just wasn't smart enough to look.
Is it possible to get a clearer image of the circuit layout. I can't quite read it but i really want to build it.
Thanks
I use 9170B decoder is it orrect or not
i also use this decoder and this code works properly...
hello sir plz tell me what type arduino use and what the process to burn the program in it.
it available in Arduino IDE to Compile .
Pin is function for Atmel microcontroller which reads the state of a specific pin
C Means The PortC Of Microcontroller
its the analog input port of Arduino the function pin reads the state of portC or Analog port
Can u pls guide me what is PINC and the program is compiling with this. In Which module the PINC variable available ?
