3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Using PSP as computer Joystick and then controlling your computer with the PSP
Step 3Starting on PSP and testing.
Click the WifiController application inside the PC folder of the WifiController folder. Turn on your PSP. Go to game- memory stick- and then click on wifi controller. Select your connection. Then wifi controller should connect to your computer. If it does not, retry the previous steps or post it in your comment. After this, on control panel (classic view), and click on game controllers. Then click on PPJoy Virtual Joystick 1 and then Properties. After this, pressing buttons on your PSP will make the axes, buttons, or point of view hat move. Try out these and calibrate the PSP analog stick. Your PSP has successfully been connected to your computer. Now to make your PSP a computer mouse and keyboard.
27 comments
Feb 27, 2010. 12:49 AMPsPgAmEr96 says:
 It say data is corrupted . Alittle help here , pls .
Jan 1, 2010. 3:18 AMddvniek says:
Hi, can anyone PLEASE help me?????? Everything works fine untill I run the app on my PSP. It finds my internet and configures it, but then it said this :
WiFiController: Connecting to Access Point.
Connection state 0 of 4: Idle.
Connection state 2 of 4: Starting up.
Connection state 6 of 4: Idle.
What now????
Nov 20, 2009. 6:12 PMxMIKEABx says:
when i try this it gets to step to and it hasnt turned to step 3... does this take awhile? or am i doing something wrong?
Oct 1, 2009. 9:04 PMyoungBIGman says:
mine is wificontroller: connecting .... connection state 1 of 4 connection state 2 of 4 do you need internet connection for connect pc??? or you just need pc with a wifi...i cannot connect with my pc..
Sep 2, 2009. 7:20 PMfjeena says:
hey... i have a slight problem i hope some1 can help me out... im currently running v5.00 m33-6 cfw on my psp slim.. i followed all the steps carefully, but when i try to run the wifi controller on my psp it just says 8002014C error, "The game could not be started" can any1 help me out? i even disabled all the plugins and tried changing the kernel to 1.5... please people im a real newbie and i would really like to get this thing working... thanx
Jul 14, 2009. 3:44 PMintheroom says:
It works on PSP 2000 with FW 5.03. Though, for that I had to arrange somethings for myself, things that weren't written here. Like for an example running the file WiFi Controller inside the PC folder.
Jul 24, 2008. 6:52 AMSendaii says:
A heads up: This DOES NOT work on the PSP Slim and Lite. I tried it on mine running 3.90 M33-3 CFW and I got an 8002014C error, "The game could not be started". Running it through eLoader also crashes the software.
Jun 3, 2009. 4:36 PMReCreate says:
it worked on mine. I think your psp Came with some different main board that causes that problem
Aug 21, 2008. 12:44 PMpsphacker says:
yes
Jul 25, 2008. 11:37 PMArchive555 says:
Sony created an entirely different motherboard for PSP's when the slim version came out. It has a microprocessor on it specifically designed to combat homebrew on PSP's. There are ways to overcome it, but I won't say here.
Oct 14, 2008. 10:51 AMaminul.1994 says:
when i start the programme in the psp , it works fine until the part when it searches for my internet. it finds my internet and configures it . when it says wificontroller: connecting .... connection state 1 of 4 connection state 2 of 4 connection state 3 of 4 ..... after that it freezes and deosnt move what do i do and im sure i didnt miss anything out
Apr 16, 2009. 4:30 AMconradev says:
it happened to me to, and with a lot of other apps
Feb 14, 2009. 4:42 AMBlacksheepinator says:
I have followed every instuction to the letter, but when i get to PSP testing and select the Wii controller, it just tells me the information is corrupt.
Dec 29, 2008. 3:22 AMbb420 says:
up down left right keys dont work for me, but the analog stick works can anyone help?
Sep 3, 2008. 3:53 AMjusticewarriors says:
my test of the game controller part failed. i nid help here on this. from the psp it is connected but when i test the controller, the axis doesn't moves. any idea how to make it work?
Dec 29, 2008. 3:08 AMbb420 says:
my axis doesn't move at all to can you tell me what to do ? thanks
Sep 3, 2008. 7:19 PMjusticewarriors says:
sorry, i found out that i missed out a step. anyway great guide, and easy to follow. and the latest version works on psp slim and lite as well. thx
Oct 18, 2008. 6:59 AMaminul.1994 says:
i got the latest version but still it freezes :( what do i do ...
Oct 7, 2008. 9:51 PMFluidmachine says:
Hey there, I can't seem to get my Wifi application running. I tried all the different game folders, etc. And still nothing. Also, I am currently running V4.01 M33-2 firmware. Any help would be appreciated. Thanks!
Jun 7, 2008. 6:01 PM466267 says:
how do u find your proxy settings etc... because idk that's that part im stuck at... for my infrastructure wifi mode. Proxy settings(port number and and wuts the adress??) ur ip adress? and how to u find ur port number for the proxy server on infrastructure wifi mode ? plz message me at Johnnyboi_vang@hotmail.com
Jun 2, 2008. 2:46 PMNotn4 says:
mine says wifiController: sceNetApctlConnect returns 80110601
Aug 26, 2007. 9:55 PMantiflag180 says:
hi guys.... i have the same error es bobwa.. y go to game then memory stick and i find the wifi controller.. when I press X to open it.. it says that the data is corrupted and won't open... i am running 3.03 firmware.... should i get a downgrade or update it ? i think a downgrade would be better but i don't trust them very much :S hope you can help me....
May 19, 2007. 2:54 AMmidgetmafia5290 says:
when i go to game on my psp, it says there are no games
Jun 4, 2007. 3:48 PMesotericguy says:
Is your PSP homebrew-capable?
May 21, 2007. 8:46 PMmidgetmafia5290 says:
I know that but there are no games in the memory stick
Apr 7, 2007. 8:29 PMbobwa says:
On step 3. When i Turn on my PSP and Go to game memory stick and click on wifi controller is saids "This game cannot be started. The data is corrupted". I Clicked the WifiController application inside the PC folder of the WifiController folder and turned it on but still said "This game cannot be started. The data is corrupted".how do i fix this?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:nateh202
