Step 5Resining the Pepakura
So to start, find an area that you can stink up with chemicals. A garage or covered outdoor area will work. Follow suit by donning a glove or two and a facemask/respirator. Lay out a few sheets of newspaper(one on top of the other) on your workplace to catch any drips. Make sure your Pepakura piece is fully taped/glued together. Once you've made sure it won't come apart during resining, you can mix up the resin in a container. I use the lid from a quart can of resin, lined with aluminum foil. Follow your resin's instructions for mixing in hardener. I use 6 tablespoons of resin at a time, because I can use it up before it gets useless. Once you have it mixed, dip a 1-inch wide brush(or an old spatula) into the resin and coat the Pepakura. Coat it all over(except the inside), and if you still have some left over, brush it where you started on the first layer. Try not to let any runs or drips form, that makes for extra sanding to do later.
A trio of wuick questions:
How strong is the resin/fiberglass combination?
Can it withstand being bumped, scraped and hugged?
Is the final product water proof/water resistant?
Keep up the good work,
C.
You may be thinking of molding which I'm not familiar with, but in that case you could.
