3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Using Paper, Resin, and Fiberglass to be the Master Chief!
Step 7Prepping for paint
Prepping for paint
So far, you've cut, folded, glued/taped, resined and fiberglassed. If you're here, then you have skills. I'm so proud! :sniff:
So now we need to make your piece look pretty for painting. I'll bet you 100 bucks that the outside of your piece was not smooth after the resin set up. So you're gonna want to sand it down, and thanks to the fiberglass, the piece has the strength to take a good sanding. So here's a little sanding 101. Start by hitting the piece with a coat of primer to highlight the problem areas. You'll want to use medium grit sandpaper with a sanding block. Sand in a circular motion over drips, runs, and anything else that stands out. If you come down to the fiberglass when sanding an area, you might want to stop sanding that spot. Go any further and you'll get a hole. So sand all the areas you can without perforating your piece, aiming to keep it more smooth than flat.
Now wipe/blast all the dust off, mix some resin, and coat the outside again . This will re-coat the exposed fiberglass, and add integrity back to the piece. Once it's cured, prime it. The 2nd resin coat should have fixed most of the irregularities, but if you see problem areas, sand em down. You shouldn't be seeing fiberglass. In case you are, apply bondo to the smaller sanded areas, instead of putting runny resin on it. It's less messier and more direct for smaller areas. But if your piece is still covered in nasty spots, resin it again.
3 comments
May 24, 2012. 9:30 AMcochinosanchez says:
If you're willing to spend a few extra bucks, what I would have added is to apply a layer of Bondo body filler to help get rid of the larger imperfections. Then I would have primed it and sanded it down.
Sep 19, 2008. 3:37 PMelite14 says:
pretty much I have a buttload of copper from grinding on my arms, the hairs cling to it. So hopefully that will keep the dust away. LOL I Love this my friend will be uber jealous. also thats a repulsive name,_(your name here)
Nov 5, 2007. 6:30 PMbigpenis says:
(removed by author or community request)
Nov 5, 2007. 7:37 PMnerfer192 says:
thats a repulsive name,___________(your name here)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:Jake Turner(Jake Turner)
Where to start... I get bored and reach for either a soldering iron or a keyboard. I have a short attention span. I love working with electronics, eating pizza, and making all sorts of things. I've be...
more »
