You can also view this tutorial directly on Delicious Drips.http://deliciousdrips.com/sculpeyonvinyltoy/
Materials:
1. Super Sculpey (available for around $11 at an art supply store)
2. DIY Toy (you can purchase a bunch of different types at Delicious Drips)http://store.deliciousdrips.com/collections/d-i-y-2
3. Oven/Heat gun/hair drier
4. Varnish (optional)
5. Acrylic paint
6. Paint brushes
7. Dremel tool (optional)
Remove these ads by
Signing UpStep 1
2. Get your grind on: To remove the vinyl that resides where the mouth should be, DLi$h used a Dremel with a router bit to carve the mouth out. Once the vinyl was removed, he finished it with a sanding bit to get all the excess shavings off.
3. Sculpey Time: DLi$h took a big chunk of Sculpey and then stretched it out to make an oval disk. He then rammed the disk into the Munny's mouth and formed it so that it wrapped around the eges of the toy to create lips. Once the lips were in place, he sealed the edges of lips to form a nice tight vacuum fit on the toy. That's one of the coolest things about Super Sculpey; It doesn't require any kind of adhesive. it basically holds to the toy by itself. Be sure to seal the edges of the Sculpey onto the toy so that the Sculpey has lots of surface area on the actual vinyl. It should almost create a suction to the toy surface.
I was thinking of trying one, but my guy needs big hair =)
I was gonna try to make Moss from "the IT Crowd" with his funky fro
http://deliciousdrips.com/startingyourowntoyline/
