Using Serial UART 16 × 2 LCD on Arduino
16,563
16
Posted
Introduction: Using Serial UART 16 × 2 LCD on Arduino
The serial UART 16×2 LCD allows you to control a parallel based LCD
over a single-wire serial interface. The serial LCD takes care of all the HD44780 commands allowing seamless integration with any micro that can communicate over a wide range of TTL serial baud rates. The
Communication with Serial 16×2 LCD requires 5V TTL serial at a default baud rate of 9600bps (8-N-1). You can adjust the baud to any standard rate between 2400 and 38400bps. The power, ground and RX pins are all broken out to a 4-pin 2.54mm pitch header.
Serial 16×2 LCD has the ability to dim the backlight to conserve power if needed. There is also a potentiometer on the backpack to adjust the contrast.
Step 1: Step 1: Parts List
  1. 1 arduino uno
  2. 1 Serial UART 16 × 2 LCD
  3. Several DuPont wires
Step 2: Step 2: Wiring Diagram
  1. Serial UART 16×2 LCD GND -> Arduino GND
  2. Serial UART 16×2 LCD 5V -> Arduino +5V
  3. Serial UART 16×2 LCD Rx -> Arduino D3
Step 3: Step 3: Test Code
#include <SoftwareSerial.h>
#define txPin 2
SoftwareSerial LCD = SoftwareSerial(0, txPin);
// since the LCD does not send data back to the Arduino, we should only define the txPin
const int LCDdelay=10; // conservative, 2 actually works
// wbp: goto with row & column
void lcdPosition(int row, int col) {
LCD.write(0xFE); //command flag
LCD.write((col + row*64 + 128));
//position delay(LCDdelay);
void clearLCD()
LCD.write(0x01); //clear command.
delay(LCDdelay);
void backlightOn()
//turns on the backlight
LCD.write(0x7C); //command flag for backlight stuff
LCD.write(157); //light level.
delay(LCDdelay);
void backlightOff() {
//turns off the backlight
LCD.write(128); //light level for off.
delay(LCDdelay);
void serCommand() { //a general function to call the command flag for issuing all other commands LCD.write(0xFE);
void setup() {
pinMode(txPin, OUTPUT);
LCD.begin(9600);
backlightOn() ;
clearLCD();
lcdPosition(0,0);
LCD.print("Hello world from LinkSprite!");
void loop() {
Step 4: Step 4:
Serial UART 16×2 LCD display successfully:Hello World from LinkSprite.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
2 Comments
I want to drive 10 Nos 16x2 displays using Arduino. What do I need ? These are for displaying contents of a rack where different spares are kept.
Hi, Thanks for the instructables! I'm using this kind of lcd display together with a wave shield and I would like text to scroll at the same time as an audio file is playing. How wold you make it autoscroll? Thanks!
