Let's face it: molding is an expensive hobby. Materials aren't cheap, tools are expensive, and it takes time to make good molds. It's worth it though to see your army of mass produced thing-a-ma-jigs.
But let's say you only need to make one casting. Do you just want to try this hobby?, Do you really want to track down specialty silicone from obscure vendors in your area? Is it even available?
Here's how to make your own molding silicone from what you can find at your local big box store.
You will need the following materials:
100% Silicone caulking
Liquid Glycerine
Acrylic paint
Mineral Spirits
Plastic Cups and Silverware
Mold Release (Also Optional, but highly recommended)
UPDATE: Cornstarch helps molds to try faster.
UPDATE!: Thanks to JDUFFY54, he has provided the following helpful additions to this recipe.
JDUFFY54: I found that using 2 parts cornstarch, 2 parts silicone caulk, and one part mineral spirits works well, more than doubles the ammount of molding stuff you get per caulk tube, and dries compleatley in under an hour. Not to mention, cornstarch is cheaper than caulk, so half the mold is cheaper. I haven't done a lot with it yet, but I have made some test molds which turned out excellent.
Step 1: Gather your materials
Cost: $3-$5
Caulking is available in all types and brands, but what you need is simply 100% Silicone caulking. Any brand will do, so buy whatever on sale. I prefer the white kind rather than clear, as it's easier to tell when it's thoroughly mixed. This forms the bulk of your mold. Get a caulking gun too, if you don't have one already.
Liquid Glycerin
Cost: Usually $5-$6
Liquid Glycerin is available in the pharmacy as a either a skin protectant, or as a laxative. You may even be able to find it in prefilled syringes. Either way, may sure it's liquid glycerin you're getting, as the suppositories are completely useless to you. This is to add moisture to the mold and allow it to dry throughout. Without this, the molding doesn't work.
Acrylic paint
Cost: $2-$3
Any acrylic paint of any color will do. I use hobby paint because that's that I have lying around. You don't need much of it, so buy as little as possible. This is used to give a consistent color during mixing.
Plastic Cups, Silverware, and Straws
Cost: $3-$5
I always use disposable plastic cups to mix my silicone. The silicone won't stick to the cup after it's cured, and you can throw it away when you're done. The straws are helpful if you don't have any pipettes or eyedroppers.
Mineral Spirits
Cost: $5-$6
Mineral spirits thin out the silicone,, making ti easier to work with. While not strictly necessary, I find that I get slightly better impressions with it, and it seems to cure faster. The downside is that mineral spirits combined with the acetic acid in the silicone cause some pretty noxious fumes. So do this outside.
Mold Release (also optional, but highly recommended)
Cost: $5-$6
This item may be harder to find in your area, and is not strictly necessary unless you're making two part molds.. It does make demolding a lot easier though. You can find it at nearly any craft store like Michael's or Hobby Lobby. This isn't used for making the silicone, it's for getting your molds to release once you're done.
Now that we've got our materials, let's head home and get cracking.
Step 2: Measuring
1oz caulk : 3 drops glycerin : 1 drop paint : .5 oz mineral spirits
A standard tube of caulking is 10oz, so you should get that much molding material out of a single tube. The recipe for an entire tube would be:
10oz Silicone, 30 drops glycerin, 10 drops paint, 5 oz mineral spirits.
Measuring without a scale
A scale isn't strictly necessary to pull off this project, but it is helpful.
To measure silicone without a scale, cut the entire tip off your caulk, and prime it to the top. A standard caulking tube has 20cm of caulk in it, so make your lines at 2cm distances. I say centimeters because it's actually something like 8" and who the heck has 1/5 dividers on their ruler?
To measure mineral spirits, use a shot glass. Half a shot glass is 1oz.
Drops can be done with a straw. Dip your straw into the glycerin, then place your finger over the open end. Squeeze out your drops as necessary.
Step 3: Mixing and Setting
To mix your molding material add the ingredients in the following order:
1. Measure out your Silicone into plastic cup (1oz)
2. Add appropriate amounts of Glycerin (3 drops)
3. Add appropriate amounts of Paint (1 Drop)
4. Add appropriate amounts of Mineral Spirits (.5oz)
5. Mix with plastic silverware until the paint is dispersed through the mixture with no white left. I like to use a knife, some prefer a spoon.
6. Scoop silicone into casting box. I say scoop because this material does not pour like molding silicone. If you're trying to make a two part mold, you're going to have to add pressure to fill in the gaps.
7. Cure times depend on heat and moisture, but is generally 2-4 hours.
That's all there is to it! Follow the directions of some of the other casting instructables, and you should have a mold that you can make your own things with.
Visit Our Store »
Go Pro Today »
3 oz of silicone,
9 drops glycerin,
3 drops paint,
1.5oz mineral spirits.
I poured (scooped really) it into a wood frame about 1 inch tall, 2 inches wide, and 4 inches across. I also made a small glob (maybe half an ounce) off to the side which also hasn't cured yet.
I had it in my garage for the first day and I thought maybe it was too cold or humid, so I brought it inside and it still hasn't cured after another day.
http://www.therpf.com/f9/can-you-use-silicone-caulk-mold-4634/
Here is what I mixed up:
2 oz of silicone (I had extra last time so I figured I only needed 2 ounces)
12 drops of glycerin
NO paint and NO mineral spirits.
I then stirred it for about 5 minutes (similar to the last time) and glopped it onto my parts (Again about 1 inch deep). After 24 hours I removed the mold from my wooden frame and found that it did much better than the first batch, but still hadn't cured all the way through. I gave it another 15 hours (just a couple minutes ago) and found that it was closer to cured, but STILL wasn't fully cured.
I think pulling it out of the wooden frame helped to get some air in there, but even if I had given it a couple more days I'm not sure if it would have fully cured.
I've now ruined the mold as I pulled it apart when it was still gooey and wrecked the surface where the part was.
I'm not sure what I did wrong. Lonecoon said he's made molds an inch thick with no problem. Maybe its the silicone I'm using?
Here is what I'm using:
GE Silicone II Kitchen and Bath White 100% Silicone (home depot)
Barr Oderless Mineral spirits (home depot)
Humco Glycerin Skin protectant (Meijer)
Generic Acrylic paint (Meijer)
I've been reading on these sites:
http://www.myheap.com/chapter-8-silicone-caulk-molds.html
They say NOT to use colored silicones and instead opt for clear, though they say the colored silicones DO work. Also they specifically call out GE Silicone II saying that it WILL work. I have seen some information saying that I need to get 100% Silicone RUBBER, not 100% Silicone. I guess I need to go back to the store and see if I can find that. I'm at a loss at this point. The only thing I can say is that most likely the mixture I made of Silicone and Glycerin WILL work as long as you do it in layers about 1/4" thick (boo).
to cast some items, and I have a question
Can this mold be used to cast poliester resins on it?
(so, just FYI people, Acrylic paint is much cheaper :) )
