Using Silicone-based pastes to create quick makeup FX
Sculptgel and Third Degree are both great silicone based materials which can be used directly on the skin to create three dimesional makeup effects for fun, Halloween, low budget movies or to create work for a portfolio. This instructable shows you a step by step makeup of how this great material can be used. No need for sculpting or moulding, no latex allergies and no mess!
Incidentally, if you like this kind of thing why not check out the free mini ecourse on my site-sign up quick and easy at LearnProstheticMakeup.com!
Step 1The material
The material
Two-part platinum silicone pastes may sound technical and off putting to some, but these materials are very simple to use. This article aims to show you a simple method for using Sculpt Gel.
There are similar materials such as Third Degree, which behave in the same fashion owing to the fact that it is also a two-part silicone based product. The main difference with this kind of material compared to wax is that you need to measure out equal amounts, mix them and apply them to the skin before it sets (or cures) with a working time of 4-5 minutes. You can cover larger areas by adding additional mixes, as it will bond well to itself. Unlike wax, it does not damage easily.
The only thing you need to remember is avoid contact with latex! Platinum silicones are usually very sensitive, and exposure to latex (in a dried or liquid form) can result in the silicone not curing properly. This is known as inhibition, and usually occurs on a surface someone has touched using latex gloves. As a result, if you do ever need to wear gloves make sure you use Vinyl and not latex!
43 comments
1-40 of 43next »
Jun 10, 2009. 9:29 AMwedgekahr says:
looks like mashed potatoes
Oct 17, 2009. 8:56 AMjaxterg says:
it look like mashed potato with ketchup
Oct 7, 2011. 5:50 AMNelyan says:
Guys, what on earth do you put your mashed potatoes? All of this looks to me more like snot and slime than something that was formely a potato. :D
(To the maker of this 'ible, great job, I'd try this out if only I can find sculpt gel-retailer somewhere in Europe.)
Oct 2, 2011. 11:16 AMwearetheprodigy says:
WOW! all of your instructables for halloween makeup are so realistic! you are a ledgend, wish i coukd do stuff like this for a job and be as good as you are at it:) not being clingy just thought id tell you:)
Jan 19, 2011. 10:45 AManibioman says:
this is so horrifying and amazing
Nov 1, 2010. 11:14 AMvegalyre says:
what is "skin illustrator"?
Oct 29, 2010. 11:29 AMmicahdear says:
Love it!!! Great job!!!
Oct 10, 2010. 1:10 PMxmusicxfreak82x says:
What type of fake blood was used to make this? I want to have some that looks very realistic, and I'm not sure of what would be the best one.
Aug 18, 2010. 9:45 AMcorsairgryl says:
Skin-Tite is available from Smooth-on in the US, behaves the same as Scupltgel and I have worn full head silicone prosthetics for several hours, bit hot &sweaty but my skin was as smooth as just having a facial treatment
Jun 11, 2009. 4:26 AMchamunks says:
Just a few questions. Are there any alternatives to this company/brand if so why did you pick this one? Two: Can you peel the silicone off and re-use them if you so desired as you would if you made a mask or is this a different sort of material. I would assume that stuff doesent breath well for your skin
Nov 2, 2009. 8:16 PMbitterbug says:
The "skin breathing" thing is a myth, as is the legend of the actress on the set of Goldfinger. You can double check on Snopes and Wikipedia.
Several other species do it but not humans :)
The two big things to worry about are toxicity and heat. If there are toxins in the makeup/mixture, well you shouldn't be applying it anyway and certainly not over the whole body. Only use safe agents.
Heat is where things can go wrong with a full body appliance. Stay hydrated, and monitor temperatures. If you can't sweat through your makeup or radiate heat away your temp will spike. The proteins in the brain can start to cook at temps as low as 45 celsius, so remember to keep cool. :)
Jun 12, 2009. 12:33 PMchamunks says:
Thanks for the reply :)
Oct 17, 2009. 9:00 AMjaxterg says:
were can i get sculpt gel and cheap
and wat do i use 4 da blood fake blood or shall i get my own real blood
Oct 21, 2009. 11:11 AMjediknight1234 says:
For diy fake blood use Karo syrup (corn syrup) and food coloring. Add colroing to syrup until you reach the desired color. :)
Oct 27, 2009. 10:35 PMjpbeyer says:
You can also use plain old Hershey's chocolate syrup with red food color.  Then you can lick your lips and really gross people out..LOL
Oct 27, 2009. 10:36 PMjpbeyer says:
You can also go to Monster Club.com and they handle it but it's not cheap.  Should last a long time though.
Oct 19, 2009. 2:28 PMuhsnamih says:
hi nice tutorial
by the way where to find material in canada
Oct 18, 2009. 9:12 PMmskk says:
Hi if you want this stuff go to www.smooth-on.com, it has everything you need.
Oct 13, 2009. 2:39 AMSkrunge says:
Thank you for a great Instructible. I would love to give it a go, however I am based in upcountry North Thailand and I would need to source items from local hardware stores or equivalent. Can you recommend any alternatives to the professional silicones and make-ups you use.
For example, is there any way to use something like silicone sealant, as used in Aquariums etc?
Jul 9, 2009. 4:35 PMastrong0 says:
i can't find the sculpt gel any where all i got when i googled it was porno advertisements
Jul 10, 2009. 8:13 AMastrong0 says:
kick a$$ !thanks!!
Jun 28, 2009. 2:31 PMWillZurMacht says:
Thank you for that Instructable, which is, I must say more real than reality itself ! I pulled a nasty prank at school, the day before the summer holiday. I came with a gruesome make-up that made my face look like I had been badly bitten by some wild animal. I put on a hood so as to hide my face and force the teachers to ask me to uncover. It had a tremendous impact ! Thank you again !
Jun 14, 2009. 10:08 AMwatergeorg says:
Very real-looking! There is another, easier way. The only thing you need is a chain saw and guts!....
Jun 11, 2009. 5:38 AMhondo2160 says:
You can also get a material called 'Skin Tite' from Bentley in the UK. You can contact them at 011 44 1562 515121 http://www.smooth-on.com/index.php?cPath=1193
Jun 10, 2009. 12:36 PMMariselam says:
Great work! I was just wondering where I could purchase the sculpting gel? and if i cant get that same kind what would be the best substitute?
Jun 11, 2009. 4:48 PMMariselam says:
Thanks!
Jun 11, 2009. 7:22 AMKrell Metal says:
Just looked this up and it is quit expensive - $20 for two ozs. I would love to try this stuff out but for now I'll have to stick with the old morticians wax.
May 26, 2009. 8:30 AMBardouv says:
The first picture almost made me throw up. Well done. You should feel very proud!
Jun 9, 2009. 12:32 AMFashim says:
lol?
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
95
Author:stuartbray(Learn Prosthetic Makeup)
I create and teach makeup effects and prosthetics for a living. I love The B52's, good sarcasm and boring things like history, science and Radio 4.
