3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Using Silicone-based pastes to create quick makeup FX
Step 2Mixing it up
Mixing it up
Sculpt Gel comes with three components-clearly marked as parts A, B and C. Parts A and B are the two silicone components which need to be mixed together thoroughly to cure. They have been pigmented two different flesh tones to avoid confusion as to which is which. Part C is purely a softener, and is clear.
Using a clean spatula or wooden tool for each material to avoid cross-contamination, scoop out equal sized blobs of parts A and B onto a clean surface.
You can mix these two parts together and use it as is, or add some part C to soften the mixture further. That is basically it. A palette or a ceramic tile is good to mix on, as these can easily be cleaned and reused using a little alcohol on a cotton wool pad or tissue. Now, let's take a look at how this material is used in a makeup.
3 comments
Jun 10, 2009. 9:29 AMwedgekahr says:
looks like mashed potatoes
Oct 17, 2009. 8:56 AMjaxterg says:
it look like mashed potato with ketchup
Oct 7, 2011. 5:50 AMNelyan says:
Guys, what on earth do you put your mashed potatoes? All of this looks to me more like snot and slime than something that was formely a potato. :D
(To the maker of this 'ible, great job, I'd try this out if only I can find sculpt gel-retailer somewhere in Europe.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
104
Author:stuartbray(Learn Prosthetic Makeup)
I create and teach makeup effects and prosthetics for a living. I love The B52's, good sarcasm and boring things like history, science and Radio 4.
