Using TI's Cc3000 With AT 1284p
6,823
10
Published
Introduction: Using TI's Cc3000 With AT 1284p
It took me a few extra hours to figure out how to get TI's cc3000 to work with the ATMega 1284p configured to run with the Arduino ISP.
Hopefully this will save the next pour sap from spending the extra time searching the Internet and deciphering the various posts.
Step 1: Getting Started...
First I want to point out that nearly all of what I'm sharing is work from others. I'm simply aggregating the information and showing the modifications I had make to get things working.
The reason I entered into this endeavor is because the ATmega1284p is such a great chip! It fits perfectly between the 328p (Uno) and the 2560P (Mega). It's got tons of memory for things like addressable RGB LEDs (such as Adafruit's excellent NeoPixel strips - http://www.adafruit.com/products/1138), more GPIO and serial ports then 328p and is a fraction of the cost of the 2560P.
I am using the nifty Adafruit cc3000 breakout with built in antenna found here: http://www.adafruit.com/products/1469
This leads me to use the Adafruit library for said breakout but more on that later...
Step 2: Setting Up Your Arduino ISP...
It's important to point out that the Arduino ISP doesn't support the 1284p "out of the box" but fear not! This is super easy and won't hurt a bit.
When searching the internet for 1284p and Arduino you will most likely find quite a few different flavors. There are now a few different boards that have been created using the 1284p. This includes "Goldilocks", Wildfire, among others. I chose to go with the "Mighty 1284p with Optiboot" and so far am pretty happy.
I found this initial setup here: http://maniacbug.wordpress.com/2011/11/27/arduino-...
Following maniacbug's excellent directions you should be able to get the circuit built and the bootloader installed.
Step 3: Connecting the Cc3000...
Few things that are important to note...
There are a variety of pins that can be used for the cc3000. However there appears to be some hard-coding done in the library for the CS pin. If you want to use something other then pin10 (which also happens to be RX1) then you will have to figure that out.
Otherwise the only other pin that is a must is the IRQ pin. This must be connected to one of the three interrupt pins.
As you can see I choose int2 (D2 on the "mighty 1284p with Optiboot" pin mapping) for my IRQ pin, D5 for my enable pin (also called VBAT), and D10 for my CS pin.
Again, these pins may vary if you use a different bootloader with a different pin mapping.
Step 4: Modifying the Adafruit Cc3000 Library...
When I was trying to figure this out I found what finally solved my issue in this post:
http://forum.freetronics.com/viewtopic.php?f=36&t;=...
I say finally because just making this change to the Adafruit_CC3000.cpp file did NOT completely solve my issue.
It got things mostly working until I realized that the change listed in the post was for the Goldilocks bootloader and did not reflect the interrupt pin numbers for the "mighty 1284p with Optiboot". As you can see below between the Start support of 1284p and End support for 1284p, the pin number is followed by the interrupt number.
My actual edits to the Adafruit_CC3000.cpp file look like this:
#include "Adafruit_CC3000.h"
#include "ccspi.h"
#include "utility/cc3000_common.h"
#include "utility/evnt_handler.h"
#include "utility/hci.h"
#include "utility/netapp.h"
#include "utility/nvmem.h"
#include "utility/security.h"
#include "utility/socket.h"
#include "utility/wlan.h"
#include "utility/debug.h"
#include "utility/sntp.h"
uint8_t g_csPin, g_irqPin, g_vbatPin, g_IRQnum, g_SPIspeed;
static const uint8_t dreqinttable[] = {
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined (__AVR_ATmega328__) || defined(__AVR_ATmega8__)
2, 0,
3, 1,
/* start support for 1284p */
#elif defined(__AVR_ATmega324P__) || defined(__AVR_ATmega644P__)|| defined(__AVR_ATmega1284P__) || defined(__AVR_ATmega324PA__) || defined(__AVR_ATmega644PA__)
2, 2,
11, 1,
10, 0,
/* end support for 1284p */
#elif defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2561__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1280__)
2, 0,
3, 1,
21, 2,
20, 3,
19, 4,
18, 5,
#elif defined(__AVR_ATmega32U4__) && defined(CORE_TEENSY)
5, 0,
6, 1,
7, 2,
8, 3,
#elif defined(__AVR_AT90USB1286__) && defined(CORE_TEENSY)
0, 0,
1, 1,
2, 2,
3, 3,
36, 4,
37, 5,
18, 6,
19, 7,
#elif defined(__arm__) && defined(CORE_TEENSY)
0, 0,
1, 1,
2, 2,
3, 3,
4, 4,
5, 5,
6, 6,
7, 7,
8, 8,
9, 9,
10, 10,
11, 11,
12, 12,
13, 13,
14, 14,
15, 15,
16, 16,
17, 17,
18, 18,
19, 19,
20, 20,
21, 21,
22, 22,
23, 23,
24, 24,
25, 25,
26, 26,
27, 27,
28, 28,
29, 29,
30, 30,
31, 31,
32, 32,
33, 33,
7, 4,
3, 0,
2, 1,
0, 2,
1, 3,
#endif
Step 5: Configuring Buildtest Example...
This is the easy part!
Open the buildtest.ino example and adjust the following lines to look like mine:
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 2 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 4
#define ADAFRUIT_CC3000_CS 10
And presto! You're done. Your cc3000 will now work as advertised on the Mighty1284p with Optiboot.
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    3 Comments
    From what I understand the CC3200 has a user processor on board, whereas the CC3100 requires an external SPI/UART host..
    Any thoughts on how the CC3000 compares with the CC3100 or CC3200? Is it worth upgrading to either, does either migrate better from a CC3000?
    Dear writer,
    Thanks for the excellent post on CC3000 connecting to ATMEGA644. I have used your example to get things hooked up. Howver, I found that DHCP is not working after the CC3000 has connected to my wifi.
    Would you happen to have any idea or experience on how to solve this (it works fine with Uno and ATMEGA2560)?
    Thanks in advance,
    Hans
    You know if you included some more info like some words from
    Adafruit CC3000 WiFi Breakout with Onboard Ceramic Antenna -
    say in the title or at least the text you might get more views
