3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Using an DC Adapter for Battery Powered Device
This Instructable will show you how to use a DC adapter instead of batteries. This will not only reduce battery expense and e-waste  but also provide consistent performance. Most battery device are used momentarily and draw up to a few watts so it will have little, if any effect on your electrical bills. Because this project uses bamboo, you won't need a lot of plastic.
Step 1Cost Comparison of Power Sources
Based on the tables, electricity gives you more bang for your buck than alkaline batteries. AA batteries cost $330 per kWh and electricity costs $0.10 per kWh which is more than 3000 times as much!
Source: http://www.buchmann.ca/Article1-Page1.asp
4 comments
Feb 3, 2012. 1:40 PMovestein says:
4x1.5v = 6v. Why 9v?
10.6v? messure the connection on the "battery" when the light is on.. it need's a load device.
Jan 30, 2012. 3:20 PMnotstarman says:
This design needs a current limiting resistor to imitate the internal resistance of the cells you have in line.
Jan 29, 2012. 8:12 PMl8nite says:
why do you need the extra fake batteries? Won't just the adapter battery work?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:hanlin_y
