Using a Digital Camera as a Second pair eyes and magnifying glass.
  • last photo ←
I discovered recently while doing a small electronic project that my eye sight was not up to scratch as I first thought.
Unfortunately, I thought I could work past my short comings and I proceeded with putting my project together.
This resulted in my project not working as well as I wished and also caused me to have to delve into some simple diagnostics. Such as searching for bridged solder joints and dry joints. But as I was already having trouble with my eye sight I ponder how I was going to resolve this problem. I tried a magnifying glass but the magnification was not up to spec. All the other device I had to help with my eye sight was rather fiddly and hampered my ability to resolve the issues I had at hand. Then it came to me to use my Digital Camera. Please don't point out how my electronic skills suck - I am too aware of this and it is very obvious.
Step 1What you will need..
- A computer - with a photo editing software application.
- I am using Windows Vista Photo Gallery. It comes with Vista.
- One Digital Camera - I am using a cheap 4Mega Pixel Camera with 3 x optical zoom.
  **It must be capable of doing macro photography.
- And a well lighted area to take your picture.
- And some props or supports to hold your circuit or what ever you are going to magnify. I didn't build any special device to hold the camera. All I used was what was available at the time.
11 comments
Mar 14, 2010. 12:14 PMfrollard says:
I've been using a similar technique for a while now - using my digicam to read faraway billboards (like the phone number on the pizza joint 3 blocks away from 19 stories up at my friend's house, support 'local' business)...
Uuber zoom is good.
Noteworth mention:  Digital zoom is crap for taking good photographs, BUT, with jpeg compression accounted for, it actually makes for BETTER close-up shots!  I don't have sample images around here, but I did a zoom shot from about 10 feet of my laptop power supply, full zoom + digital zoom, and it saved a crystal clear shot with wonderful readable text, at 'full' interpolated resolution.  I did another shot at full optical no digital zoom, and the supply took up about 5-10% of the target image.  The text was small enough that even at 12 megapixel, the jpeg compression turned it into a big goobery block of barely readable white and dark blocks.  Repeat experiment at full wide angle and crop/zoom = completely unreadable.
Mar 16, 2010. 12:39 AMLance Mt. says:
If your camera is capable, there is a neat trick i've been u8sing for a while now.
I use the camera, and zoom in to 5.5x Zoom, taking a photo. I then go and view the photo, and using the same button to zoom i can zoom in to a further 10x zoom.
Although its only a 6megapixel camera (Antique old thing), i can effectively see some detail at 15.5x zoom.
  Gooooood stuff.
Mar 30, 2010. 3:28 AMKryptonite says:
Damn, mine can't do that.
Mar 15, 2010. 1:45 PMstephenniall says:
Handy ! one method i used to use is to scan the item with a scale rule behind it
Mar 16, 2010. 8:05 AMstephenniall says:
yeah ! the only problem i had was that the Solder sometimes shone brightly
Mar 14, 2010. 10:19 AMKiteman says:
That's a useful tip.
Thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:spiderfurby
