Using a Toothbrush Charger to Power an LED With Induction
4,362
27
5
Posted
Introduction: Using a Toothbrush Charger to Power an LED With Induction
This is a fun little experiment that takes about 5 minutes and demonstrates some of the electrical properties of induction. I was inspired when I saw an old toothbrush dock charger sitting in the trash. I'm now wirelessly getting about 4-5V DC! Fun stuff.
Sorry for the slightly blurry images, my camera isn't the best for close-ups.
These chargers power the battery inside your tooth brush wirelessly. How do they do this? It's all about induction. The dock sends out an alternating magnetic pulse that is harnessed by the toothbrush and stored in the batteries. Pretty cool. Oh, the wonders that surround us daily.
What we're doing is replacing the toothbrush with a coil and LED. I wrapped the little prong (I think that's the core, but if it isn't then at least it's circular) with enameled, or magnet copper wire. I didn't count turns, but I covered the prong and wrapped it several layers deep. Because the electricity that we receive from our makeshift transformer is AC, we must convert it! Using our diode, we can block half of the AC waves and make it DC. Just connect the diode to one end of the wire with the stripe on the other side. The opposing diode lead is now positive and the other end of your coil is negative. Unfortunately we only get half of the electricity that we can pull from the coil. If you use a bridge rectifier instead of a single diode you can harness it all! If any of this is confusing, just freshen up on how AC current works and what a diode does.
Now that you have "rectified" your current, you have a steady DC voltage of 4-5V! What are you going to do with it? The possibilities are endless.
I put an LED and a resistor in series and got that to work fantastically! I haven't tried it, but you have the power of the wall socket at your disposal--you can probably run a small motor if your magnet wire is thick enough.
You've done it! A simple and (maybe) free step-down, air-core transformer that took all of five minutes to make!
I think it's pretty cool. Feedback much appreciated. This is my first Instructable--I hope to make more soon!
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    5 Comments
    The LED itself is a diode, you can just use the right resistor without the need to rectify.
    Actually, you need to rectify. Theoretically you're right, but a normal LED can only handle about 5 reverse volts. What you could do to put it directly is to put another diode in parallel with the LED "reversy biased", that it would rectify a part of the current. This is a good deal for a bunch of leds, but for other applications it's better to use a bridge rectifier.
    Good point. If you're using an LED then you have no need or the single diode! However, if you want to power something else, you need it there, so I just included it. On topic, do you know how much reverse voltage a general LED can take? Thanks for your comment.
    You need 4 diodes to turn ac into dc all your doing is canceling out one phase on the ac cycle
    Yes, I am aware. I mention in the instructable that a bridge rectifier would be more efficient. But this is what I had so I just have deal with using only one cycle.
