Using gelatin for moulds and prosthetics
 by marshon
Featured
Step 7: Pour the plaster
Once you are ready mix up some Plaster of Paris or casting plaster (I use Crystacal-R). Dental casting plaster is also good. If your head is made of plaster, then you need to add a mould release agent before starting on the negative mould. Use Vaseline or one of the silicone release sprays.
Plaster for casting is available at most art shops, or craft shops, or off the net. I ignore the fancy mixing formulae, two parts powder to one part water (by volume) will generally give good results every time. One cup of water to two of plaster. Start by getting a quick even layer of plaster all over the mask. If you use a brush be careful not to disturb the surface of the plasticine. I like the messy aspect of it all and get stuck in with my hands and fingers.
Once you have a base of plaster down, start slowly adding to the initial coat. If it all gets a bit out of hand, leave it for 20 minutes to set and then mix up some more plaster and add to the dried stuff. Slowly, slowly catchey monkey. You can add plaster bandage or scrim net to strengthen and support the plaster as you go. Eventually you want a mould at least 3/4" or 20mm thick.
Let the plaster dry for an hour. Another cup of tea and another smoke helps here.
After an hour you can de-mould. Start by pulling away the fence. this will leave a ledge around the upper plaster mould. Grip the edge with your fingers and gently ease the upper cast off the head. It doesn't matter if some of the plasticine comes away with the cast or stays stuck to the head.
Carefully clean away and remove ALL TRACES of the plasticine from both the head and the mould. When fitted back together this will leave a void into which will go our gelatin. Congratulations, you have just made a two part mould.
lvegetables says: Mar 20, 2012. 7:04 PM
i have had some issues with this step.
at first i was using a plaster life cast, with a clay prosthetic, and cooking spray as the release agent. unfortunately the plaster (having not been sealed) absorbed the release agent and all was lost..
did another life cast and tried again, this time sealing the plaster and applying a release agent... and the plaster came off but it was cracked and un-usable. i was able to save the clay prosthetic..
so i realized that i haven't been making the clay fence or making the plaster thick enough.. and i shall try again!!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
