Using One Analog Pin to Read 4 Buttons - Arduino
2,523
40
Posted in TechnologyArduino
Introduction: Using One Analog Pin to Read 4 Buttons - Arduino
The idea is to read the resistanse differense between them using resistors.
The buttons are connected in such way that each button add the resistors of the buttons before him to a serial out put.
I used 4 220ohm resistors and 4 buttons.
int sensorPin = A0;
int sensorValue = 0;
void setup() {
  pinMode (sensorPin, INPUT_PULLUP);
  Serial.begin (9600);
void loop() {
  sensorValue = analogRead(sensorPin);
  sensorValue =  (map (sensorValue, 18,44, 1, 5));
  if (sensorValue < 5 ) Serial.println (sensorValue);
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    3 Comments
    Can someone please explain how this line works?
    why couldn't you make a voltage divider before each button. Since this is a 10-bit adc, your 1024 steps could be chopped up into analog ranges for each button press.
    Well this takes me back.. Old VCRs used too use this method... Old top load VCRs with 30' " wired" remotes. If a switch gets worn out and develops enough resistance it will mimic the next highest resistance switch next too it.
